Standalone repository for libnetworking stack
Vijay Kumar Banerjee
vijay at rtems.org
Fri Feb 26 17:40:28 UTC 2021
Hi all,
Thanks for reviewing
On Fri, Feb 26, 2021 at 10:13 AM Joel Sherrill <joel at rtems.org> wrote:
> Some odd questions that are mostly about making this a self-contained entity with no loose ends.
> + Can the network demos be merged also?
Are we talking about testsuites tests that use legacy networking? If
so, then I have already shifted the networking01.exe and will shift
other tests using the same approach.
> + rtems-docs has the Network Users Guide which is legacy only. As a minimum, it needs to be renamed to have Legacy in the title. Better would be to convert it to markdown/asciidoc and just toss it in the legacy repo.
This is a good point! I'll probably just keep it as a README in the
net-legacy repo.
> + Gaisler needs a poke about the grlib NIC drivers. And Daniel expects it. File a ticket that it is time for them to support libbsd and assign it to him. :)
> I'm ok with Chris' proposal to give notice Grep'ing for NETWORK_DRIVER_NAME did turn up more files than I expected. Perhaps that is simply a list of driver names and attach functions for a readme in the repo. That's all that should have been in the bsp.h files.
Yes, these are mostly bsp.h files. I'll file a ticket and post to
users and devel about it. There are also quite a few with
RTEMS_NETWORKING defined.
> This is awesome work and much appreciated.
Thank you. :)
> On Fri, Feb 26, 2021 at 12:12 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Feb 25, 2021 at 6:06 PM Chris Johns <chrisj at rtems.org> wrote:
>> > On 26/2/21 4:49 am, Vijay Kumar Banerjee wrote:
>> > > The stand-alone repository is very close to completion now and I could
>> > > use the networking01 test with the standalone repo and it successfully
>> > > runs on pc-qemu.
>> > Fantastic news.
>> > > The following are the links to the branches with the
>> > > final version of the commits and I would really appreciate a review
>> > > and suggestions on what else needs to be done (I'm not sending patches
>> > > as they're big and would hit the devel limit):
>> > I am fine reviewing the changes in the repos.
>> > > RTEMS: https://git.rtems.org/vijay/rtems.git/log/?h=devel-no-libnet
>> > Looks good. The only observation is a bisect will probability break as the
>> > nfsclient depends on rpc but I am OK with now things are.
>> > I checked rtems_waf and I think it is OK dealing with no networking defined in
>> > the RTEMS opts header.
Great!
>> > > rtems-net-legacy: https://git.rtems.org/vijay/rtems-net-legacy.git/log/?h=main
>> > Would calling lnetwork.py netlegacy.py be a better match for that name? Closer
>> > to the repo naming.
Sure, I'll rename it and force push.
>> > Do the new python files need to pep8 formatted? :)
>> > [ https://gitlab.com/ita1024/waf/-/tree/master/playground/pep8 ]
pep8 does work for me when used manually but with waf module I'm
getting the following error:
File "/home/vijay/.local/lib/python3.8/site-packages/pep8.py", line
253, in maximum_line_length
if length > options.max_line_length:
AttributeError: 'Values' object has no attribute 'max_line_length'
This is strange because it looks like an error in the pep8 module itself.
I have tried different versions of pep8 and it looks like each version
has a different error. I think this needs some work from the waf side
to get it working with the new pycodestyle instead of the pep8 module.
>> > In bsp_drivers.py is there a waf node way to find the sources rather than
>> > python os walk?
>> > [ https://waf.io/apidocs/Node.html#waflib.Node.Node.ant_glob ]
I gave it a few shots but it didn't quite work out well for me. I do
get the generator from it but for some reason, it's not building. We
would also need the list of headers for the install, for which I think
os.walk might be needed.
Is this a blocker to merging? If so, then I can put more time into it
and try to get it working. If you want it as an optimization, maybe we
could merge it and file a ticket? I can take more time and fix it
later.
>> > Should the README reference rtems_waf and all the configure options it supports?
This is a good point, The README needs some update for sure. I'll
follow the README.waf from other repos and follow the same pattern.
>> > Do we need a LICENSE file?
Do we?
>> > > There are at least two things that need to be done:
>> > > 1. Shift the tests like mghttpd01 that use the libnetworking stack, to
>> > > the standalone repo like networking01
>> > OK
I'll do it along with the README and send it for review.
>> > > 2. There are still codes that use the #ifdef RTEMS_NETWORKING. What do
>> > > we want to do about those?
>> > How many BSPs/places/areas are we talking about?
>> > Would it be practical to add a cgit link to a ticket and then post an email to
>> > user and devel stating those interested in BSPs x,y,z to review the ticket? We
>> > then wait a week and after that the remaining defines are removed.
grep shows this:
cpukit/libfs/src/ftpfs/tftpDriver.c:#ifdef RTEMS_NETWORKING
cpukit/telnetd/telnetd.c:#ifdef RTEMS_NETWORKING
cpukit/ftpd/ftpd.c:#ifndef RTEMS_NETWORKING
cpukit/libtest/testbeginend.c:#if RTEMS_NETWORKING
cpukit/libtest/testbeginend.c: " RTEMS_NETWORKING"
cpukit/include/rtems/monitor.h:#if defined(RTEMS_NETWORKING)
cpukit/include/rtems/shellconfig.h:#if RTEMS_NETWORKING
cpukit/include/rtems/shellconfig.h: #if RTEMS_NETWORKING
spec/build/testsuites/samples/pppd.yml: - RTEMS_NETWORKING
spec/build/testsuites/samples/loopback.yml:- RTEMS_NETWORKING
spec/build/testsuites/libtests/telnetd01.yml:- RTEMS_NETWORKING
spec/build/testsuites/libtests/mghttpd01.yml: - RTEMS_NETWORKING
spec/build/testsuites/libtests/syscall01.yml:- RTEMS_NETWORKING
spec/build/testsuites/libtests/networking01.yml:- RTEMS_NETWORKING
spec/build/testsuites/libtests/ftp01.yml:- RTEMS_NETWORKING
spec/build/bsps/powerpc/motorola_powerpc/objqemunet.yml: - RTEMS_NETWORKING
spec/build/bsps/objnetnosmp.yml: - RTEMS_NETWORKING
spec/build/bsps/riscv/griscv/objnetnosmp.yml: - RTEMS_NETWORKING
testsuites/libtests/record01/init.c:#ifdef RTEMS_NETWORKING
bsps/powerpc/beatnik/include/bsp.h:#if defined(RTEMS_NETWORKING)
bsps/lm32/milkymist/include/bsp.h:#if defined(RTEMS_NETWORKING)
bsps/lm32/lm32_evr/include/bsp.h:#if defined(RTEMS_NETWORKING)
I can already see a small issue from my side. The networking01.yml is
there. That will go away, along with some other testsuites yml that
I'll shift now. Do we need ticket for the rest?
>> > Do we have a ticket for this task?
>> https://devel.rtems.org/ticket/3850
Thanks.
>> I'll let Vijay answer the rest.
>> > > Apart from these two points above, do the commits and the standalone
>> > > repo look OK (close to mergeable)?
>> > For me this is very close and a welcomed change for RTEMS 6. Really nice work.
Thank you!
Best regards,
Vijay
>> > Thanks
>> > Chris
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
