[PATCH 4/4] rtems-debugger-threads.c: Fix Unchecked return value error (CID #1468688)
Gedare Bloom
gedare at rtems.org
Fri Feb 26 21:56:23 UTC 2021
On Fri, Feb 26, 2021 at 2:35 PM Ryan Long <thisisryanlong at gmail.com> wrote:
> CID 1468688: Unchecked return value in snapshot_thread().
> Closes #4262
> cpukit/libdebugger/rtems-debugger-threads.c | 5 ++++-
> 1 file changed, 4 insertions(+), 1 deletion(-)
> diff --git a/cpukit/libdebugger/rtems-debugger-threads.c b/cpukit/libdebugger/rtems-debugger-threads.c
> index 5b96e5f..ee8d654 100644
> --- a/cpukit/libdebugger/rtems-debugger-threads.c
> +++ b/cpukit/libdebugger/rtems-debugger-threads.c
> @@ -170,6 +170,7 @@ snapshot_thread(rtems_tcb* tcb, void* arg)
> char name[RTEMS_DEBUGGER_THREAD_NAME_SIZE];
> bool exclude = false;
> size_t i;
> + int sc;
> * The only time the threads pointer is NULL is a realloc error so we stop
> @@ -272,7 +273,9 @@ snapshot_thread(rtems_tcb* tcb, void* arg)
> * Read the target registers into the thread register array.
> - rtems_debugger_target_read_regs(thread);
> + sc = rtems_debugger_target_read_regs(thread);
> + _Assert_Unused_variable_equals(sc, 0);
Remove this extra blank line
> if (rtems_debugger_server_flag(RTEMS_DEBUGGER_FLAG_VERBOSE))
> rtems_debugger_printf("rtems-db: sys: thd: %08" PRIx32 ": signal: %d\n",
> 1.8.3.1
> devel mailing list
> devel at rtems.org
