[PATCH v2 0/4] Fix Unchecked return value Coverity errors
Ryan Long thisisryanlong at gmail.com
Fri Feb 26 22:14:51 UTC 2021
Hi,
Here's the patches with the changes.
Thanks,
Ryan
Ryan Long (4):
  printertask.c: Fix Unchecked return value (CID #1399710)
  record-client.c: Fix Unchecked return value (CID #1456677)
  getgrent.c: Fix Unchecked return value error (CID #1459004)
  rtems-debugger-threads.c: Fix Unchecked return value error (CID
    #1468688)
 cpukit/libcsupport/src/getgrent.c           |  4 +++-
 cpukit/libcsupport/src/printertask.c        | 11 ++++++++---
 cpukit/libdebugger/rtems-debugger-threads.c |  4 +++-
 cpukit/libtrace/record/record-client.c      |  4 +++-
 4 files changed, 17 insertions(+), 6 deletions(-)
1.8.3.1
