[rtems-docs commit] c-user: Generate Timer Manager documentation
Wed Jan 13 10:45:11 UTC 2021
On 11/12/2020 01:35, Chris Johns wrote:
> On 10/12/20 4:41 pm, Sebastian Huber wrote:
>> On 10/12/2020 03:24, Chris Johns wrote:
>>> On 9/12/20 7:20 pm, Sebastian Huber wrote:
>>>> Module:    rtems-docs
>>>> Branch:    master
>>>> Commit:    d716c79070901195912526c6e49d43defad00bdd
>>>> Changeset:
>>>> http://git.rtems.org/rtems-docs/commit/?id=d716c79070901195912526c6e49d43defad00bdd
>>>> Author:    Sebastian Huber<sebastian.huber at embedded-brains.de>
>>>> Date:      Wed Dec  2 08:17:12 2020 +0100
>>>> The documentation is a consolidation of the comments in Doxygen markup
>>>> and the documentation sources in Sphinx markup.  The documentation was
>>>> transfered to interface specification items.  The documentation source
>>>> files were generated from the items by a script.
>>>> Update #3993.
>>>>    c-user/timer/directives.rst   | 992 ++++++++++++++++++++++++++----------------
>>>>    c-user/timer/introduction.rst |  57 ++-
>>>>    2 files changed, 674 insertions(+), 375 deletions(-)
>>>> diff --git a/c-user/timer/directives.rst b/c-user/timer/directives.rst
>>>> index d9b9877..d65f263 100644
>>>> --- a/c-user/timer/directives.rst
>>>> +++ b/c-user/timer/directives.rst
>>>> @@ -1,463 +1,729 @@
>>>>    .. SPDX-License-Identifier: CC-BY-SA-4.0
>>>>    +.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>>>>    .. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
>>>>    +.. This file is part of the RTEMS quality process and was automatically
>>>> +.. generated.  If you find something that needs to be fixed or
>>>> +.. worded better please post a report or patch to an RTEMS mailing list
>>>> +.. or raise a bug report:
>>>> +..https://docs.rtems.org/branches/master/user/support/bugs.html
>>>> +.. For information on updating and regenerating please refer to:
>>>> +..https://docs.rtems.org/branches/master/eng/req/howto.html
>>> We need a solution. I would prefer we resolve this before we add any more
>>> instances of these links.
>> I understand that cross-document links are a problem, however, these two links
>> are in comments and thus don't show up in the generated documents. A link to the
>> bug reporting should always point to the latest information since there is only
>> one bug reporting procedure in the project at a time. The link to the howto
>> could be branch-specific.
> Yes I agree. My concern is a change in how master is hosted breaks the links.
>>> Suggestions?
>> We could add a script which performs some post processing after creation the of
>> the release branches.
> What about ....
> https://www.rtems.org/support/bugs.html
> If a redirect can be set up we could insulate these links from the location they
> are.
I would like to fix the header. What should I do now with the link
 From an RTEMS Project point of view it would be good to have a permanent link to the bug reporting page.
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
