[rtems-docs commit] c-user: Generate Timer Manager documentation
Wed Jan 13 21:42:40 UTC 2021
On 13/1/21 9:45 pm, Sebastian Huber wrote:
> On 11/12/2020 01:35, Chris Johns wrote:
>> On 10/12/20 4:41 pm, Sebastian Huber wrote:
>>> On 10/12/2020 03:24, Chris Johns wrote:
>>>> On 9/12/20 7:20 pm, Sebastian Huber wrote:
>>>>> Module:    rtems-docs
>>>>> Branch:    master
>>>>> Commit:    d716c79070901195912526c6e49d43defad00bdd
>>>>> Changeset:
>>>>> http://git.rtems.org/rtems-docs/commit/?id=d716c79070901195912526c6e49d43defad00bdd
>>>>> Author:    Sebastian Huber<sebastian.huber at embedded-brains.de>
>>>>> Date:      Wed Dec  2 08:17:12 2020 +0100
>>>>> The documentation is a consolidation of the comments in Doxygen markup
>>>>> and the documentation sources in Sphinx markup.  The documentation was
>>>>> transfered to interface specification items.  The documentation source
>>>>> files were generated from the items by a script.
>>>>> Update #3993.
>>>>>    c-user/timer/directives.rst   | 992
>>>>>    c-user/timer/introduction.rst |  57 ++-
>>>>>    2 files changed, 674 insertions(+), 375 deletions(-)
>>>>> diff --git a/c-user/timer/directives.rst b/c-user/timer/directives.rst
>>>>> index d9b9877..d65f263 100644
>>>>> --- a/c-user/timer/directives.rst
>>>>> +++ b/c-user/timer/directives.rst
>>>>> @@ -1,463 +1,729 @@
>>>>>    .. SPDX-License-Identifier: CC-BY-SA-4.0
>>>>>    +.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>>>>>    .. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
>>>>>    +.. This file is part of the RTEMS quality process and was automatically
>>>>> +.. generated.  If you find something that needs to be fixed or
>>>>> +.. worded better please post a report or patch to an RTEMS mailing list
>>>>> +.. or raise a bug report:
>>>>> +..https://docs.rtems.org/branches/master/user/support/bugs.html
>>>>> +.. For information on updating and regenerating please refer to:
>>>>> +..https://docs.rtems.org/branches/master/eng/req/howto.html
>>>> We need a solution. I would prefer we resolve this before we add any more
>>>> instances of these links.
>>> I understand that cross-document links are a problem, however, these two links
>>> are in comments and thus don't show up in the generated documents. A link to the
>>> bug reporting should always point to the latest information since there is only
>>> one bug reporting procedure in the project at a time. The link to the howto
>>> could be branch-specific.
>> Yes I agree. My concern is a change in how master is hosted breaks the links.
>>>> Suggestions?
>>> We could add a script which performs some post processing after creation the of
>>> the release branches.
>> What about ....
>> https://www.rtems.org/support/bugs.html
>> If a redirect can be set up we could insulate these links from the location they
>> are.
> I would like to fix the header. What should I do now with the link
> From an RTEMS Project point of view it would be good to have a permanent link to
> the bug reporting page.
Yes. Joel is one for this as he knows Drupal.
