[rtems-docs commit] c-user: Generate Timer Manager documentation
Thu Jan 14 17:28:23 UTC 2021
On Wed, Jan 13, 2021 at 6:21 PM Chris Johns <chrisj at rtems.org> wrote:
> On 13/1/21 9:45 pm, Sebastian Huber wrote:
> > On 11/12/2020 01:35, Chris Johns wrote:
> >> On 10/12/20 4:41 pm, Sebastian Huber wrote:
> >>> On 10/12/2020 03:24, Chris Johns wrote:
> >>>> On 9/12/20 7:20 pm, Sebastian Huber wrote:
> >>>>> Module:    rtems-docs
> >>>>> Branch:    master
> >>>>> Commit:    d716c79070901195912526c6e49d43defad00bdd
> >>>>> Changeset:
> http://git.rtems.org/rtems-docs/commit/?id=d716c79070901195912526c6e49d43defad00bdd
> >>>>> Author:    Sebastian Huber<sebastian.huber at embedded-brains.de>
> >>>>> Date:      Wed Dec  2 08:17:12 2020 +0100
> >>>>> The documentation is a consolidation of the comments in Doxygen
> markup
> >>>>> and the documentation sources in Sphinx markup.  The documentation
> was
> >>>>> transfered to interface specification items.  The documentation
> source
> >>>>> files were generated from the items by a script.
> >>>>> Update #3993.
> >>>>>    c-user/timer/directives.rst   | 992
> >>>>>    c-user/timer/introduction.rst |  57 ++-
> >>>>>    2 files changed, 674 insertions(+), 375 deletions(-)
> >>>>> diff --git a/c-user/timer/directives.rst
> b/c-user/timer/directives.rst
> >>>>> index d9b9877..d65f263 100644
> >>>>> --- a/c-user/timer/directives.rst
> >>>>> +++ b/c-user/timer/directives.rst
> >>>>> @@ -1,463 +1,729 @@
> >>>>>    .. SPDX-License-Identifier: CC-BY-SA-4.0
> >>>>>    +.. Copyright (C) 2020 embedded brains GmbH (
> http://www.embedded-brains.de)
> >>>>>    .. Copyright (C) 1988, 2008 On-Line Applications Research
> Corporation (OAR)
> >>>>>    +.. This file is part of the RTEMS quality process and was
> automatically
> >>>>> +.. generated.  If you find something that needs to be fixed or
> >>>>> +.. worded better please post a report or patch to an RTEMS mailing
> list
> >>>>> +.. or raise a bug report:
> >>>>> +..https://docs.rtems.org/branches/master/user/support/bugs.html
> >>>>> +.. For information on updating and regenerating please refer to:
> >>>>> +..https://docs.rtems.org/branches/master/eng/req/howto.html
> >>>> We need a solution. I would prefer we resolve this before we add any
> more
> >>>> instances of these links.
> >>> I understand that cross-document links are a problem, however, these
> two links
> >>> are in comments and thus don't show up in the generated documents. A
> link to the
> >>> bug reporting should always point to the latest information since
> there is only
> >>> one bug reporting procedure in the project at a time. The link to the
> howto
> >>> could be branch-specific.
> >> Yes I agree. My concern is a change in how master is hosted breaks the
> links.
> >>>> Suggestions?
> >>> We could add a script which performs some post processing after
> creation the of
> >>> the release branches.
> >> What about ....
> >> https://www.rtems.org/support/bugs.html
> >> If a redirect can be set up we could insulate these links from the
> location they
> >> are.
> > I would like to fix the header. What should I do now with the link
> > From an RTEMS Project point of view it would be good to have a permanent
> link to
> > the bug reporting page.
> Yes. Joel is one for this as he knows Drupal.
It would be nice to set up something indirect, like mentioned above, or
maybe https://bugs.rtems.org
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210114/868e5010/attachment.html>
