[rtems-tools commit] tester: Swap Xilinx ZynqMP BSPs to secondary UART
Joel Sherrill
joel at rtems.org
Sat Jan 16 00:17:59 UTC 2021
On Fri, Jan 15, 2021, 6:09 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> -----Original Message-----
> From: Chris Johns <chrisj at rtems.org>
> Sent: Friday, January 15, 2021 17:10
> To: Kinsey Moore <kinsey.moore at oarcorp.com>; Development <devel at rtems.org>
> Subject: Re: [rtems-tools commit] tester: Swap Xilinx ZynqMP BSPs to
> secondary UART
> > On 16/1/21 1:46 am, Kinsey Moore wrote:
> >> This change only applies to the aarch64 variants since they're brand
> new and I didn't want to disturb existing users of the ARM/Xilinx-Zynq and
> ARM/Xilinx-ZynqMP BSPs.
> > Sure. I am wondering if the change works on FreeBSD because my testing
> on other
> > BSPs showed it does not work. I am wondering if this change works on
> FreeBSD for
> > the aarch64 qemu?
> My testing thus far on Qemu with the AArch64 BSP shows normal output on
> the primary UART instead of the secondary UART for both RTEMS' internal
> testsuite as well as the LibBSD tests. I did rebuilds from scratch earlier
> today for some other changes and verified that the Qemu output was good.
> I've got them running in CI as well, but that only covers the RTEMS tests.
Chris was asking about the qemu version and if the command works on FreeBSD
hosts.
> Kinsey
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210115/3cbf71b0/attachment.html>
