[PATCH] Improve file header comment in generated files
Wed Jan 20 23:47:31 UTC 2021
On Wed, Jan 20, 2021 at 5:33 PM Chris Johns <chrisj at rtems.org> wrote:
> On 21/1/21 10:23 am, Joel Sherrill wrote:
> > On Wed, Jan 20, 2021 at 5:01 PM Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>> wrote:
> >     On 19/1/21 5:01 pm, Sebastian Huber wrote:
> >     > diff --git a/c-user/config/bdbuf.rst b/c-user/config/bdbuf.rst
> >     > index 06399e0..5a3360f 100644
> >     > --- a/c-user/config/bdbuf.rst
> >     > +++ b/c-user/config/bdbuf.rst
> >     > @@ -8,11 +8,15 @@
> >     >  .. worded better please post a report or patch to an RTEMS
> mailing list
> >     >  .. or raise a bug report:
> >     > -.. https://docs.rtems.org/branches/master/user/support/bugs.html
> >     <https://docs.rtems.org/branches/master/user/support/bugs.html>
> >     > +.. https://www.rtems.org/support/bugs.html
> >     <https://www.rtems.org/support/bugs.html>
> >     > -.. For information on updating and regenerating please refer to:
> >     > +.. For information on updating and regenerating please refer to
> the How-To
> >     > +.. section in the Software Requirements Engineering chapter of the
> >     > +.. RTEMS Software Engineering manual.  The manual is provided as
> a part of
> >     > +.. a release.  For development sources please refer to the online
> >     > +.. documentation at:
> >     > -.. https://docs.rtems.org/branches/master/eng/req/howto.html
> >     <https://docs.rtems.org/branches/master/eng/req/howto.html>
> >     > +.. https://docs.rtems.org <https://docs.rtems.org>
> >     >  .. Generated from spec:/acfg/if/group-bdbuf
> >     This looks good. We need the bugs.html page working.
> >     Joel, what is the status of that page?
> > I answered on another thread. This would need to be an Apache redirect to
> > where we want. It is an Amar issue AFAIK. I can't do anything about it.
> Amar does not track the devel email so I suggest you raise a ticket and
> then
> directly ping him.
> > Even if we want to change the URL going forward (which would be good),
> > this would still need to work.
> Yes so does the change go in and then the link gets left hanging until
> Amar or I
> clean it up or does the change become dependent on the server side of
> things
> getting sorted and so there is some focus placed on this area of the
> project?
> > FWIW I have no recollection of what was on this page.actually had on it
> > or where it directed to on the old setup. I can't find it on the Wayback
> Machine.
> I cannot find a historical support path in the old web site. There is this
> page
> from 2003 ...
> https://web.archive.org/web/20030618104931/http://www.rtems.org/bugs.html
> Maybe the link is changed to ...
> https://www.rtems.org/bugs.html
We are chatting at the same time as this thread but that doesn't exist now.
I can
create it.
Let's just chat to resolve this and post the result.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210120/d4cab09a/attachment.html>
