[PATCH] Improve file header comment in generated files
Joel Sherrill
joel at rtems.org
Thu Jan 21 00:00:07 UTC 2021
rtems.org/bugs.html is now in place. Chris has reviewed.
If there is another URL referenced by existing code, let me know so we can
address that.
--joel
On Wed, Jan 20, 2021 at 5:47 PM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Jan 20, 2021 at 5:33 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 21/1/21 10:23 am, Joel Sherrill wrote:
>> > On Wed, Jan 20, 2021 at 5:01 PM Chris Johns <chrisj at rtems.org
>> > <mailto:chrisj at rtems.org>> wrote:
>> > On 19/1/21 5:01 pm, Sebastian Huber wrote:
>> > > diff --git a/c-user/config/bdbuf.rst b/c-user/config/bdbuf.rst
>> > > index 06399e0..5a3360f 100644
>> > > --- a/c-user/config/bdbuf.rst
>> > > +++ b/c-user/config/bdbuf.rst
>> > > @@ -8,11 +8,15 @@
>> > > .. worded better please post a report or patch to an RTEMS
>> mailing list
>> > > .. or raise a bug report:
>> > > -.. https://docs.rtems.org/branches/master/user/support/bugs.html
>> > <https://docs.rtems.org/branches/master/user/support/bugs.html>
>> > > +.. https://www.rtems.org/support/bugs.html
>> > <https://www.rtems.org/support/bugs.html>
>> > > -.. For information on updating and regenerating please refer to:
>> > > +.. For information on updating and regenerating please refer to
>> the How-To
>> > > +.. section in the Software Requirements Engineering chapter of
>> the
>> > > +.. RTEMS Software Engineering manual. The manual is provided as
>> a part of
>> > > +.. a release. For development sources please refer to the online
>> > > +.. documentation at:
>> > > -.. https://docs.rtems.org/branches/master/eng/req/howto.html
>> > <https://docs.rtems.org/branches/master/eng/req/howto.html>
>> > > +.. https://docs.rtems.org <https://docs.rtems.org>
>> > > .. Generated from spec:/acfg/if/group-bdbuf
>> > This looks good. We need the bugs.html page working.
>> > Joel, what is the status of that page?
>> > I answered on another thread. This would need to be an Apache redirect
>> to
>> > where we want. It is an Amar issue AFAIK. I can't do anything about it.
>> Amar does not track the devel email so I suggest you raise a ticket and
>> then
>> directly ping him.
>> > Even if we want to change the URL going forward (which would be good),
>> > this would still need to work.
>> Yes so does the change go in and then the link gets left hanging until
>> Amar or I
>> clean it up or does the change become dependent on the server side of
>> things
>> getting sorted and so there is some focus placed on this area of the
>> project?
>> > FWIW I have no recollection of what was on this page.actually had on it
>> > or where it directed to on the old setup. I can't find it on the
>> Wayback Machine.
>> I cannot find a historical support path in the old web site. There is
>> this page
>> from 2003 ...
>> https://web.archive.org/web/20030618104931/http://www.rtems.org/bugs.html
>> Maybe the link is changed to ...
>> https://www.rtems.org/bugs.html
> We are chatting at the same time as this thread but that doesn't exist
> now. I can
> create it.
> Let's just chat to resolve this and post the result.
>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210120/6b37b52b/attachment-0001.html>
