[PATCH] STM32H7 doc update
Robin Müller
robin.mueller.m at gmail.com
Thu Jan 21 12:52:45 UTC 2021
I'd just like to bump my patch. The last changes were just the formatting
changes from the code review.
Kind Regards
Robin
On Tue, 12 Jan 2021 at 12:36, Robin Mueller <robin.mueller.m at gmail.com>
wrote:
> Added doc for board variation, added some fixes
> from code review. (typo and line width formatting)
> user/bsps/arm/stm32h7.rst | 18 +++++++++++++++++-
> 1 file changed, 17 insertions(+), 1 deletion(-)
> diff --git a/user/bsps/arm/stm32h7.rst b/user/bsps/arm/stm32h7.rst
> index 3eee511..e1b9d8c 100644
> --- a/user/bsps/arm/stm32h7.rst
> +++ b/user/bsps/arm/stm32h7.rst
> @@ -11,16 +11,32 @@ This BSP supports the
> The BSP is known to run on these boards:
> * `STM32H743I-EVAL 2 <
> https://www.st.com/en/evaluation-tools/stm32h743i-eval.html>`_
> +* `STM32H743ZI-Nucleo <
> https://www.st.com/en/evaluation-tools/nucleo-h743zi.html>`_
> Clock Driver
> -The clock driver uses the `ARMv7-M Systick` module.
> +The clock driver uses the `ARMv7-M Systick` module. The HSE (external
> +oscillator) value can also be different for different evaluation or
> custom
> +boards, so it is recommended to check the default values of the BSP.
> Console Driver
> The console driver supports the on-chip UART and USART modules.
> +Different board variations use different GPIO pins and blocks for the
> default
> +communication UART and it is recommended to check whether the default
> +configuration provided is valid in the BSP.
> +To specify that the BSP should be built for the STM32H743ZI-Nucleo board,
> +users can supply ``STM32H743ZI_NUCLEO == True`` to ``config.ini`` when
> +building the BSP.
> +Alternatively, users can supply the configuration structs defined in
> ``hal.h``
> +in the applicaton for other boards. For the console driver, the
> +``stm32h7_usartX_config`` structs are used to configure the GPIO pins and
> other
> +parameters. The default implementations can be found in
> +``bsps/arm/stm32ht/console`` in the RTEMS sources.
> Network Interface Driver
> 2.23.0.windows.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210121/d2181f79/attachment.html>
