[PATCH] STM32H7 doc update
Robin Mueller
robin.mueller.m at gmail.com
Tue Jan 12 11:35:58 UTC 2021
Added doc for board variation, added some fixes
from code review. (typo and line width formatting)
user/bsps/arm/stm32h7.rst | 18 +++++++++++++++++-
1 file changed, 17 insertions(+), 1 deletion(-)
diff --git a/user/bsps/arm/stm32h7.rst b/user/bsps/arm/stm32h7.rst
index 3eee511..e1b9d8c 100644
--- a/user/bsps/arm/stm32h7.rst
+++ b/user/bsps/arm/stm32h7.rst
@@ -11,16 +11,32 @@ This BSP supports the
The BSP is known to run on these boards:
* `STM32H743I-EVAL 2 <https://www.st.com/en/evaluation-tools/stm32h743i-eval.html>`_
+* `STM32H743ZI-Nucleo <https://www.st.com/en/evaluation-tools/nucleo-h743zi.html>`_
Clock Driver
-The clock driver uses the `ARMv7-M Systick` module.
+The clock driver uses the `ARMv7-M Systick` module. The HSE (external
+oscillator) value can also be different for different evaluation or custom
+boards, so it is recommended to check the default values of the BSP.
Console Driver
The console driver supports the on-chip UART and USART modules.
+Different board variations use different GPIO pins and blocks for the default
+communication UART and it is recommended to check whether the default
+configuration provided is valid in the BSP.
+To specify that the BSP should be built for the STM32H743ZI-Nucleo board,
+users can supply ``STM32H743ZI_NUCLEO == True`` to ``config.ini`` when
+building the BSP.
+Alternatively, users can supply the configuration structs defined in ``hal.h``
+in the applicaton for other boards. For the console driver, the
+``stm32h7_usartX_config`` structs are used to configure the GPIO pins and other
+parameters. The default implementations can be found in
+``bsps/arm/stm32ht/console`` in the RTEMS sources.
Network Interface Driver
2.23.0.windows.1
