Phrases for CONSTRAINTS section in the directive documentation
    Gedare Bloom
    gedare at rtems.org
    Fri Jan 22 13:19:44 UTC 2021
On Fri, Jan 22, 2021 at 5:55 AM Andrew Butterfield <
Andrew.Butterfield at scss.tcd.ie> wrote:
> Hi Sebastian,
> I'd prefer 2.
> The directive may be called from an interrupt context
> (substituting  "must",  "must not", as appropriate)
Yes, I agree. (Use of "in" is ambiguous here, because "called in" has a
meaning in colloquial speech that differs from the intent here.)
> Regards, Andrew
> On 22 Jan 2021, at 12:09, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> Hello,
> since there is an agreement to add a CONSTRAINTS section to the directive
> documentation, I need some standard phrases.
> 1.
> The directive may be called in interrupt context.
> 2.
> The directive may be called from interrupt context.
> 3.
> The directive can be called ... interrupt context.
> What do you prefer?
> I would use it for other contexts as well.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> <sebastian.huber at embedded-brains.de>
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
> Andrew Butterfield     Tel: +353-1-896-2517     Fax: +353-1-677-2204
> Lero at TCD, Head of Software Foundations & Verification Research Group
> School of Computer Science and Statistics,
> Room G.39, O'Reilly Institute, Trinity College, University of Dublin
>                          http://www.scss.tcd.ie/Andrew.Butterfield/
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210122/685dac4b/attachment.html>
