Phrases for CONSTRAINTS section in the directive documentation
Chris Johns
chrisj at rtems.org
Sat Jan 23 22:44:47 UTC 2021
On 23/1/21 12:19 am, Gedare Bloom wrote:
On Fri, Jan 22, 2021 at 5:55 AM Andrew Butterfield
> <Andrew.Butterfield at scss.tcd.ie <mailto:Andrew.Butterfield at scss.tcd.ie>> wrote:
> Hi Sebastian,
> I'd prefer 2.
> The directive may be called from an interrupt context
> (substituting "must", "must not", as appropriate)
> Yes, I agree. (Use of "in" is ambiguous here, because "called in" has a meaning
> in colloquial speech that differs from the intent here.)
"The directive may be called from within an interrupt context."
A context is a area, region or bounded "space" (what this means) so I suggest
"from within"? And this also lets you use "this call cannot be made from outside
an interrupt context".
