[PATCH rtems 1/2] libblock: Add rtems_bdbuf_peek()
Christian MAUDERER christian.mauderer at embedded-brains.de
Fri Jan 22 14:07:53 UTC 2021
Am 22.01.21 um 14:59 schrieb Gedare Bloom:
> On Fri, Jan 22, 2021 at 6:24 AM Christian Mauderer
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     Adds a peek function that allows (for example) a file system to suggest
>     the next blocks that should be used for read ahead. This can increase
>     the read speed of fragmented files.
>       cpukit/include/rtems/bdbuf.h             |  21 ++++
>       cpukit/include/rtems/diskdevs.h          |  27 ++++-
>       cpukit/libblock/src/bdbuf.c              |  80 +++++++++++----
>       cpukit/libblock/src/blkdev-print-stats.c |  28 ++---
>       testsuites/fstests/fsdosfswrite01/init.c |  51 +++++-----
>       testsuites/libtests/block14/block14.scn  |  37 ++++---
>       testsuites/libtests/block14/init.c       | 124 +++++++++++++++++------
>       7 files changed, 264 insertions(+), 104 deletions(-)
>     diff --git a/cpukit/include/rtems/bdbuf.h b/cpukit/include/rtems/bdbuf.h
>     index fbb4fc05e9..0cde571816 100644
>     --- a/cpukit/include/rtems/bdbuf.h
>     +++ b/cpukit/include/rtems/bdbuf.h
>     @@ -539,6 +539,27 @@ rtems_bdbuf_read (
>         rtems_bdbuf_buffer** bd
>     + * Provide a hint to the read ahead mechanism which blocks should
>     be cached
>     + * next. This overwrites the default linear pattern. You should use
>     it in (for
>     + * example) a file system to tell bdbuf where the next part of a
>     fragmented file
>     + * is. If you know the length of the file, you can provide that too.
>     + * Before you can use this function, the rtems_bdbuf_init() routine
>     must be
>     + * called at least once to initialize everything. Otherwise you
>     might get
>     + * unexpected results.
>     + * @param dd [in] The disk device.
>     + * @param block [in] Linear media block number.
>     + * @param nr_blocks [in] Number of consecutive blocks that can be
>     pre-fetched.
>     +void
>     +rtems_bdbuf_peek (
>     +  rtems_disk_device *dd,
>     +  rtems_blkdev_bnum block,
>     +  uint32_t nr_blocks
>        * Release the buffer obtained by a read call back to the cache.
>     If the buffer
>        * was obtained by a get call and was not already in the cache the
>     release
>     diff --git a/cpukit/include/rtems/diskdevs.h
>     b/cpukit/include/rtems/diskdevs.h
>     index 85d157dcd5..d7529cbe89 100644
>     --- a/cpukit/include/rtems/diskdevs.h
>     +++ b/cpukit/include/rtems/diskdevs.h
>     @@ -58,6 +58,11 @@ typedef int (*rtems_block_device_ioctl)(
>       #define RTEMS_DISK_READ_AHEAD_NO_TRIGGER ((rtems_blkdev_bnum) -1)
>     + * @brief Size value to set number of blocks based on config and
>     disk size.
>     +#define RTEMS_DISK_READ_AHEAD_SIZE_AUTO (0)
>        * @brief Block device read-ahead control.
>     @@ -71,7 +76,8 @@ typedef struct {
>          * @brief Block value to trigger the read-ahead request.
>          * A value of @ref RTEMS_DISK_READ_AHEAD_NO_TRIGGER will disable
>     further
>     -   * read-ahead requests since no valid block can have this value.
>     +   * read-ahead requests (except the ones triggered by @a
>     rtems_bdbuf_peek)
>     +   * since no valid block can have this value.
>         rtems_blkdev_bnum trigger;
>     @@ -82,6 +88,14 @@ typedef struct {
>          * be arbitrary.
>         rtems_blkdev_bnum next;
>     +   * @brief Size of the next read-ahead request in blocks.
>     +   * A value of @ref RTEMS_DISK_READ_AHEAD_SIZE_AUTO will try to
>     read the rest
>     +   * of the disk but at most the configured max_read_ahead_blocks.
>     +  uint32_t nr_blocks;
>       } rtems_blkdev_read_ahead;
>     @@ -110,10 +124,19 @@ typedef struct {
>          * @brief Read-ahead transfer count.
>     -   * Each read-ahead transfer may read multiple blocks.
>     +   * Each read-ahead transfer may read multiple blocks. This counts all
>     +   * transfers (with and without size).
>         uint32_t read_ahead_transfers;
>     +   * @brief Read-ahead transfers with given size.
>     +   * Number of times a read ahead transfer has been given a size.
>     This is the
>     +   * case for read ahead transfers that are caused by a peek.
>     +  uint32_t read_ahead_transfers_with_size;
> A little bit wordy. Maybe you just want to count the number of peeks?
I thought about that too. But in theory, someone could add another
mechanism that uses the size. For example it would be possible to do the
normal read ahead with that too.
But if you prefer, I can rename it to "read_ahead_peeks". I would avoid
removing the read_ahead altogether because it belongs to this mechanism.
>          * @brief Count of blocks transfered from the device.
>     diff --git a/cpukit/libblock/src/bdbuf.c b/cpukit/libblock/src/bdbuf.c
>     index a7d471507c..02acf11f54 100644
>     --- a/cpukit/libblock/src/bdbuf.c
>     +++ b/cpukit/libblock/src/bdbuf.c
>     @@ -2018,6 +2018,23 @@ rtems_bdbuf_read_ahead_reset
>     (rtems_disk_device *dd)
>         dd->read_ahead.trigger = RTEMS_DISK_READ_AHEAD_NO_TRIGGER;
>     +static void
>     +rtems_bdbuf_read_ahead_add_to_chain (rtems_disk_device *dd)
>     +  rtems_status_code sc;
>     +  rtems_chain_control *chain = &bdbuf_cache.read_ahead_chain;
>     +  if (rtems_chain_is_empty (chain))
>     +    sc = rtems_event_send (bdbuf_cache.read_ahead_task,
>     +                           RTEMS_BDBUF_READ_AHEAD_WAKE_UP);
>     +    if (sc != RTEMS_SUCCESSFUL)
>     +      rtems_bdbuf_fatal (RTEMS_BDBUF_FATAL_RA_WAKE_UP);
>     +  rtems_chain_append_unprotected (chain, &dd->read_ahead.node);
>       static void
>       rtems_bdbuf_check_read_ahead_trigger (rtems_disk_device *dd,
>                                             rtems_blkdev_bnum  block)
>     @@ -2026,18 +2043,8 @@ rtems_bdbuf_check_read_ahead_trigger
>             && dd->read_ahead.trigger == block
>             && !rtems_bdbuf_is_read_ahead_active (dd))
>     -    rtems_status_code sc;
>     -    rtems_chain_control *chain = &bdbuf_cache.read_ahead_chain;
>     -    if (rtems_chain_is_empty (chain))
>     -      sc = rtems_event_send (bdbuf_cache.read_ahead_task,
>     -                             RTEMS_BDBUF_READ_AHEAD_WAKE_UP);
>     -      if (sc != RTEMS_SUCCESSFUL)
>     -        rtems_bdbuf_fatal (RTEMS_BDBUF_FATAL_RA_WAKE_UP);
>     -    rtems_chain_append_unprotected (chain, &dd->read_ahead.node);
>     +    dd->read_ahead.nr_blocks = RTEMS_DISK_READ_AHEAD_SIZE_AUTO;
>     +    rtems_bdbuf_read_ahead_add_to_chain(dd);
>     @@ -2112,6 +2119,24 @@ rtems_bdbuf_read (rtems_disk_device   *dd,
>         return sc;
>     +void
>     +rtems_bdbuf_peek (rtems_disk_device *dd,
>     +                  uint32_t nr_blocks)
>     +  rtems_bdbuf_lock_cache ();
>     +  if (bdbuf_cache.read_ahead_enabled)
>     +    rtems_bdbuf_read_ahead_reset(dd);
>     +    dd->read_ahead.next = block;
>     +    dd->read_ahead.nr_blocks = nr_blocks;
>     +  rtems_bdbuf_unlock_cache ();
>       static rtems_status_code
>       rtems_bdbuf_check_bd_and_lock_cache (rtems_bdbuf_buffer *bd, const
>     char *kind)
>     @@ -2952,18 +2977,33 @@ rtems_bdbuf_read_ahead_task
>     (rtems_task_argument arg)
>               if (bd != NULL)
>     -          uint32_t transfer_count = dd->block_count - block;
>     +          uint32_t transfer_count = dd->read_ahead.nr_blocks;
>     +          uint32_t blocks_till_end_of_disk = dd->block_count - block;
> Use "until" or "til" with one l. "Till" means something else (like a
> cashier's register).
OK. Thanks for the correction.
>                 uint32_t max_transfer_count =
>     bdbuf_config.max_read_ahead_blocks;
>     -          if (transfer_count >= max_transfer_count)
>     +          if (transfer_count > blocks_till_end_of_disk) {
>     +            transfer_count = blocks_till_end_of_disk;
>     +          if (transfer_count > max_transfer_count) {
>                   transfer_count = max_transfer_count;
>     -            dd->read_ahead.trigger = block + transfer_count / 2;
>     -            dd->read_ahead.next = block + transfer_count;
>     -          else
>     -            dd->read_ahead.trigger = RTEMS_DISK_READ_AHEAD_NO_TRIGGER;
>     +          if (transfer_count == RTEMS_DISK_READ_AHEAD_SIZE_AUTO) {
>     +            if (transfer_count >= max_transfer_count)
> I think this can only be == by this point?
Just in the line above, I set it to "blocks_till_end_of_disk". It's
basically to keep the old behavior. But with that it can be bigger then
max_transfer_count.
Maybe it's better if I do the check for RTEMS_DISK_READ_AHEAD_SIZE_AUTO
first and do the other checks only in the else case. I'll change that.
>     +              transfer_count = max_transfer_count;
> Then, this is redundant.
>     +              dd->read_ahead.trigger = block + transfer_count / 2;
>     +              dd->read_ahead.next = block + transfer_count;
>     +            else
>     +          } else {
>     +            ++dd->stats.read_ahead_transfers_with_size;
>                 ++dd->stats.read_ahead_transfers;
>     diff --git a/cpukit/libblock/src/blkdev-print-stats.c
>     b/cpukit/libblock/src/blkdev-print-stats.c
>     index 8edf24fd8c..8e07e97b68 100644
>     --- a/cpukit/libblock/src/blkdev-print-stats.c
>     +++ b/cpukit/libblock/src/blkdev-print-stats.c
>     @@ -40,25 +40,27 @@ void rtems_blkdev_print_stats(
>            printer,
>     "-------------------------------------------------------------------------------\n"
>            "                               DEVICE STATISTICS\n"
>       "----------------------+--------------------------------------------------------\n"
>     -     " MEDIA BLOCK SIZE     | %" PRIu32 "\n"
>     -     " MEDIA BLOCK COUNT    | %" PRIu32 "\n"
>     -     " BLOCK SIZE           | %" PRIu32 "\n"
>     -     " READ HITS            | %" PRIu32 "\n"
>     -     " READ MISSES          | %" PRIu32 "\n"
>     -     " READ AHEAD TRANSFERS | %" PRIu32 "\n"
>     -     " READ BLOCKS          | %" PRIu32 "\n"
>     -     " READ ERRORS          | %" PRIu32 "\n"
>     -     " WRITE TRANSFERS      | %" PRIu32 "\n"
>     -     " WRITE BLOCKS         | %" PRIu32 "\n"
>     -     " WRITE ERRORS         | %" PRIu32 "\n"
>       "----------------------+--------------------------------------------------------\n",
>       "--------------------------------+----------------------------------------------\n"
>     +     " MEDIA BLOCK SIZE               | %" PRIu32 "\n"
>     +     " MEDIA BLOCK COUNT              | %" PRIu32 "\n"
>     +     " BLOCK SIZE                     | %" PRIu32 "\n"
>     +     " READ HITS                      | %" PRIu32 "\n"
>     +     " READ MISSES                    | %" PRIu32 "\n"
>     +     " READ AHEAD TRANSFERS           | %" PRIu32 "\n"
>     +     " READ AHEAD TRANSFERS WITH SIZE | %" PRIu32 "\n"
>     +     " READ BLOCKS                    | %" PRIu32 "\n"
>     +     " READ ERRORS                    | %" PRIu32 "\n"
>     +     " WRITE TRANSFERS                | %" PRIu32 "\n"
>     +     " WRITE BLOCKS                   | %" PRIu32 "\n"
>     +     " WRITE ERRORS                   | %" PRIu32 "\n"
>       "--------------------------------+----------------------------------------------\n",
>            media_block_size,
>            media_block_count,
>            block_size,
>            stats->read_hits,
>            stats->read_misses,
>            stats->read_ahead_transfers,
>     +     stats->read_ahead_transfers_with_size,
>            stats->read_blocks,
>            stats->read_errors,
>            stats->write_transfers,
>     diff --git a/testsuites/fstests/fsdosfswrite01/init.c
>     b/testsuites/fstests/fsdosfswrite01/init.c
>     index e5d8e5d6dd..e87289cf6d 100644
>     --- a/testsuites/fstests/fsdosfswrite01/init.c
>     +++ b/testsuites/fstests/fsdosfswrite01/init.c
>     @@ -126,34 +126,37 @@ static void test_normal_file_write(
>         const char *file_name )
>         static const rtems_blkdev_stats complete_existing_block_stats = {
>     -    .read_hits            = 0,
>     -    .read_misses          = 0,
>     -    .read_ahead_transfers = 0,
>     -    .read_blocks          = 0,
>     -    .read_errors          = 0,
>     -    .write_transfers      = 1,
>     -    .write_blocks         = 1,
>     -    .write_errors         = 0
>     +    .read_hits                      = 0,
>     +    .read_misses                    = 0,
>     +    .read_ahead_transfers           = 0,
>     +    .read_ahead_transfers_with_size = 0,
>     +    .read_blocks                    = 0,
>     +    .read_errors                    = 0,
>     +    .write_transfers                = 1,
>     +    .write_blocks                   = 1,
>     +    .write_errors                   = 0
>         static const rtems_blkdev_stats complete_new_block_stats = {
>     -    .read_hits            = 3,
>     -    .read_misses          = 2,
>     -    .read_blocks          = 2,
>     -    .read_errors          = 0,
>     -    .write_blocks         = 3,
>     -    .write_errors         = 0
>     +    .read_hits                      = 3,
>     +    .read_misses                    = 2,
>     +    .read_blocks                    = 2,
>     +    .read_errors                    = 0,
>     +    .write_blocks                   = 3,
>     +    .write_errors                   = 0
>         static const rtems_blkdev_stats partial_new_block_stats = {
>     -    .read_hits            = 3,
>     -    .read_misses          = 3,
>     -    .read_blocks          = 3,
>     -    .read_errors          = 0,
>     -    .write_errors         = 0
>     +    .read_hits                      = 3,
>     +    .read_misses                    = 3,
>     +    .read_blocks                    = 3,
>     +    .read_errors                    = 0,
>     +    .write_errors                   = 0
>         int                             rv;
>     diff --git a/testsuites/libtests/block14/block14.scn
>     b/testsuites/libtests/block14/block14.scn
>     index 7170522579..48c22b716d 100644
>     --- a/testsuites/libtests/block14/block14.scn
>     +++ b/testsuites/libtests/block14/block14.scn
>     @@ -6,19 +6,30 @@ action 3
>       action 4
>       action 5
>       action 6
>     +action 7
>     +action 8
>     +action 9
>     +action 10
>     +action 11
>     +action 12
>     +action 13
>     +action 14
>     +action 15
>                                      DEVICE STATISTICS
>     - MEDIA BLOCK SIZE     | 0
>     - MEDIA BLOCK COUNT    | 1
>     - BLOCK SIZE           | 2
>     - READ HITS            | 2
>     - READ MISSES          | 3
>     - READ AHEAD TRANSFERS | 2
>     - READ BLOCKS          | 5
>     - READ ERRORS          | 1
>     - WRITE TRANSFERS      | 2
>     - WRITE BLOCKS         | 2
>     - WRITE ERRORS         | 1
>     + MEDIA BLOCK SIZE               | 0
>     + MEDIA BLOCK COUNT              | 1
>     + BLOCK SIZE                     | 2
>     + READ HITS                      | 4
>     + READ MISSES                    | 7
>     + READ AHEAD TRANSFERS           | 6
>     + READ AHEAD TRANSFERS WITH SIZE | 3
>     + READ BLOCKS                    | 13
>     + READ ERRORS                    | 1
>     + WRITE TRANSFERS                | 2
>     + WRITE BLOCKS                   | 2
>     + WRITE ERRORS                   | 1
>       *** END OF TEST BLOCK 14 ***
>     diff --git a/testsuites/libtests/block14/init.c
>     b/testsuites/libtests/block14/init.c
>     index b4e73aadc9..24441c4fe8 100644
>     --- a/testsuites/libtests/block14/init.c
>     +++ b/testsuites/libtests/block14/init.c
>     @@ -29,9 +29,9 @@
>       const char rtems_test_name[] = "BLOCK 14";
>     -#define ACTION_COUNT 7
>     +#define ACTION_COUNT 16
>     -#define BLOCK_COUNT 6
>     +#define BLOCK_COUNT 14
>       #define DISK_PATH "/disk"
>     @@ -42,50 +42,104 @@ typedef struct {
>           rtems_bdbuf_buffer **bd_ptr
>     +  void (*peek)(
>         rtems_status_code expected_get_status;
>         rtems_status_code (*release)(rtems_bdbuf_buffer *bd);
>       } test_action;
>       static const test_action actions [ACTION_COUNT] = {
>     -  { 0, rtems_bdbuf_read, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>     -  { 1, rtems_bdbuf_read, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>     -  { 2, rtems_bdbuf_read, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>     -  { 4, rtems_bdbuf_get, RTEMS_SUCCESSFUL, rtems_bdbuf_sync },
>     -  { 5, rtems_bdbuf_read, RTEMS_IO_ERROR, rtems_bdbuf_release },
>     -  { 5, rtems_bdbuf_get, RTEMS_SUCCESSFUL, rtems_bdbuf_sync }
>     +  /* normal read ahead */
>     +  { 0, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>     +  { 1, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>     +  { 2, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>     +  /* re-read a cached block */
>     +  /* cause some writes */
>     +  { 4, rtems_bdbuf_get, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_sync },
>     +  { 5, rtems_bdbuf_read, NULL, RTEMS_IO_ERROR, rtems_bdbuf_release },
>     +  { 5, rtems_bdbuf_get, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_sync },
>     +  /* interrupt normal read ahead with a peek */
>     +  { 9, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>     +  { 13, NULL, rtems_bdbuf_peek, 0, NULL },
>     +  { 10, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL,
>     +  { 11, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL,
>     +  { 12, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL,
>     +  /* peek with hit */
>     +  { 6, NULL, rtems_bdbuf_peek, 0, NULL },
>     +  { 6, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>     +  /* (wrong) peek with reading different block */
>     +  { 8, NULL, rtems_bdbuf_peek, 0, NULL },
>     +  { 7, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
>     -#define STATS(a, b, c, d, e, f, g, h) \
>     +#define STATS(a, b, c, d, e, f, g, h, i) \
>           .read_hits = a, \
>           .read_misses = b, \
>           .read_ahead_transfers = c, \
>     -    .read_blocks = d, \
>     -    .read_errors = e, \
>     -    .write_transfers = f, \
>     -    .write_blocks = g, \
>     -    .write_errors = h \
>     +    .read_ahead_transfers_with_size = d, \
>     +    .read_blocks = e, \
>     +    .read_errors = f, \
>     +    .write_transfers = g, \
>     +    .write_blocks = h, \
>     +    .write_errors = i \
>       static const rtems_blkdev_stats expected_stats [ACTION_COUNT] = {
>     -  STATS(0, 1, 0, 1, 0, 0, 0, 0),
>     -  STATS(0, 2, 1, 3, 0, 0, 0, 0),
>     -  STATS(1, 2, 2, 4, 0, 0, 0, 0),
>     -  STATS(2, 2, 2, 4, 0, 0, 0, 0),
>     -  STATS(2, 2, 2, 4, 0, 1, 1, 0),
>     -  STATS(2, 3, 2, 5, 1, 1, 1, 0),
>     -  STATS(2, 3, 2, 5, 1, 2, 2, 1)
>     +  STATS(0, 1, 0, 0, 1, 0, 0, 0, 0),
>     +  STATS(0, 2, 1, 0, 3, 0, 0, 0, 0),
>     +  STATS(1, 2, 2, 0, 4, 0, 0, 0, 0),
>     +  STATS(2, 2, 2, 0, 4, 0, 0, 0, 0),
>     +  STATS(2, 2, 2, 0, 4, 0, 1, 1, 0),
>     +  STATS(2, 3, 2, 0, 5, 1, 1, 1, 0),
>     +  STATS(2, 3, 2, 0, 5, 1, 2, 2, 1),
>     +  STATS(2, 4, 2, 0, 6, 1, 2, 2, 1),
>     +  STATS(2, 4, 3, 1, 7, 1, 2, 2, 1),
>     +  STATS(2, 5, 3, 1, 8, 1, 2, 2, 1),
>     +  STATS(2, 6, 4, 1, 10, 1, 2, 2, 1),
>     +  STATS(3, 6, 4, 1, 10, 1, 2, 2, 1),
>     +  STATS(3, 6, 5, 2, 11, 1, 2, 2, 1),
>     +  STATS(4, 6, 5, 2, 11, 1, 2, 2, 1),
>     +  STATS(4, 6, 6, 3, 12, 1, 2, 2, 1),
>     +  STATS(4, 7, 6, 3, 13, 1, 2, 2, 1),
>       static const int expected_block_access_counts [ACTION_COUNT]
>     [BLOCK_COUNT] = {
>     -   { 1, 0, 0, 0, 0, 0 },
>     -   { 1, 1, 1, 0, 0, 0 },
>     -   { 1, 1, 1, 1, 0, 0 },
>     -   { 1, 1, 1, 1, 1, 0 },
>     -   { 1, 1, 1, 1, 1, 1 },
>     -   { 1, 1, 1, 1, 1, 2 }
>     +   { 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
>     +   { 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
>     +   { 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
>     +   { 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
>     +   { 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0 },
>     +   { 1, 1, 1, 1, 1, 2, 0, 0, 0, 0, 0, 0, 0, 0 },
>     +   { 1, 1, 1, 1, 1, 2, 0, 0, 0, 1, 0, 0, 0, 0 },
>     +   { 1, 1, 1, 1, 1, 2, 0, 0, 0, 1, 0, 0, 0, 1 },
>     +   { 1, 1, 1, 1, 1, 2, 0, 0, 0, 1, 1, 0, 0, 1 },
>     +   { 1, 1, 1, 1, 1, 2, 0, 0, 0, 1, 1, 1, 1, 1 },
>     +   { 1, 1, 1, 1, 1, 2, 1, 0, 0, 1, 1, 1, 1, 1 },
>     +   { 1, 1, 1, 1, 1, 2, 1, 0, 1, 1, 1, 1, 1, 1 },
>     +   { 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 1, 1 },
>       static int block_access_counts [BLOCK_COUNT];
>     @@ -132,10 +186,16 @@ static void test_actions(rtems_disk_device *dd)
>           printf("action %i\n", i);
>     -    sc = (*action->get)(dd, action->block, &bd);
>     -    rtems_test_assert(sc == action->expected_get_status);
>     +    if (action->get != NULL) {
>     +      sc = (*action->get)(dd, action->block, &bd);
>     +      rtems_test_assert(sc == action->expected_get_status);
>     +    if (action->peek != NULL) {
>     +      (*action->peek)(dd, action->block, 1);
>     -    if (sc == RTEMS_SUCCESSFUL) {
>     +    if (sc == RTEMS_SUCCESSFUL && action->release != NULL) {
>             sc = (*action->release)(bd);
>             rtems_test_assert(sc == RTEMS_SUCCESSFUL);
>     2.26.2
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org <mailto:devel at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/devel
>     <http://lists.rtems.org/mailman/listinfo/devel>
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
