[PATCH rtems 1/2] libblock: Add rtems_bdbuf_peek()
Fri Jan 22 14:29:01 UTC 2021
On Fri, Jan 22, 2021 at 7:08 AM Christian MAUDERER <
christian.mauderer at embedded-brains.de> wrote:
> Am 22.01.21 um 14:59 schrieb Gedare Bloom:
> > On Fri, Jan 22, 2021 at 6:24 AM Christian Mauderer
> > <christian.mauderer at embedded-brains.de
> > <mailto:christian.mauderer at embedded-brains.de>> wrote:
> >     Adds a peek function that allows (for example) a file system to
> suggest
> >     the next blocks that should be used for read ahead. This can increase
> >     the read speed of fragmented files.
> >       cpukit/include/rtems/bdbuf.h             |  21 ++++
> >       cpukit/include/rtems/diskdevs.h          |  27 ++++-
> >       cpukit/libblock/src/bdbuf.c              |  80 +++++++++++----
> >       cpukit/libblock/src/blkdev-print-stats.c |  28 ++---
> >       testsuites/fstests/fsdosfswrite01/init.c |  51 +++++-----
> >       testsuites/libtests/block14/block14.scn  |  37 ++++---
> >       testsuites/libtests/block14/init.c       | 124
> >       7 files changed, 264 insertions(+), 104 deletions(-)
> >     diff --git a/cpukit/include/rtems/bdbuf.h
> b/cpukit/include/rtems/bdbuf.h
> >     index fbb4fc05e9..0cde571816 100644
> >     --- a/cpukit/include/rtems/bdbuf.h
> >     +++ b/cpukit/include/rtems/bdbuf.h
> >     @@ -539,6 +539,27 @@ rtems_bdbuf_read (
> >         rtems_bdbuf_buffer** bd
> >     + * Provide a hint to the read ahead mechanism which blocks should
> >     be cached
> >     + * next. This overwrites the default linear pattern. You should use
> >     it in (for
> >     + * example) a file system to tell bdbuf where the next part of a
> >     fragmented file
> >     + * is. If you know the length of the file, you can provide that too.
> >     + * Before you can use this function, the rtems_bdbuf_init() routine
> >     must be
> >     + * called at least once to initialize everything. Otherwise you
> >     might get
> >     + * unexpected results.
> >     + * @param dd [in] The disk device.
> >     + * @param block [in] Linear media block number.
> >     + * @param nr_blocks [in] Number of consecutive blocks that can be
> >     pre-fetched.
> >     +void
> >     +rtems_bdbuf_peek (
> >     +  rtems_disk_device *dd,
> >     +  rtems_blkdev_bnum block,
> >     +  uint32_t nr_blocks
> >        * Release the buffer obtained by a read call back to the cache.
> >     If the buffer
> >        * was obtained by a get call and was not already in the cache the
> >     release
> >     diff --git a/cpukit/include/rtems/diskdevs.h
> >     b/cpukit/include/rtems/diskdevs.h
> >     index 85d157dcd5..d7529cbe89 100644
> >     --- a/cpukit/include/rtems/diskdevs.h
> >     +++ b/cpukit/include/rtems/diskdevs.h
> >     @@ -58,6 +58,11 @@ typedef int (*rtems_block_device_ioctl)(
> >       #define RTEMS_DISK_READ_AHEAD_NO_TRIGGER ((rtems_blkdev_bnum) -1)
> >     + * @brief Size value to set number of blocks based on config and
> >     disk size.
> >     +#define RTEMS_DISK_READ_AHEAD_SIZE_AUTO (0)
> >        * @brief Block device read-ahead control.
> >     @@ -71,7 +76,8 @@ typedef struct {
> >          * @brief Block value to trigger the read-ahead request.
> >          * A value of @ref RTEMS_DISK_READ_AHEAD_NO_TRIGGER will disable
> >     further
> >     -   * read-ahead requests since no valid block can have this value.
> >     +   * read-ahead requests (except the ones triggered by @a
> >     rtems_bdbuf_peek)
> >     +   * since no valid block can have this value.
> >         rtems_blkdev_bnum trigger;
> >     @@ -82,6 +88,14 @@ typedef struct {
> >          * be arbitrary.
> >         rtems_blkdev_bnum next;
> >     +   * @brief Size of the next read-ahead request in blocks.
> >     +   * A value of @ref RTEMS_DISK_READ_AHEAD_SIZE_AUTO will try to
> >     read the rest
> >     +   * of the disk but at most the configured max_read_ahead_blocks.
> >     +  uint32_t nr_blocks;
> >       } rtems_blkdev_read_ahead;
> >     @@ -110,10 +124,19 @@ typedef struct {
> >          * @brief Read-ahead transfer count.
> >     -   * Each read-ahead transfer may read multiple blocks.
> >     +   * Each read-ahead transfer may read multiple blocks. This counts
> all
> >     +   * transfers (with and without size).
> >         uint32_t read_ahead_transfers;
> >     +   * @brief Read-ahead transfers with given size.
> >     +   * Number of times a read ahead transfer has been given a size.
> >     This is the
> >     +   * case for read ahead transfers that are caused by a peek.
> >     +  uint32_t read_ahead_transfers_with_size;
> > A little bit wordy. Maybe you just want to count the number of peeks?
> I thought about that too. But in theory, someone could add another
> mechanism that uses the size. For example it would be possible to do the
> normal read ahead with that too.
> But if you prefer, I can rename it to "read_ahead_peeks". I would avoid
> removing the read_ahead altogether because it belongs to this mechanism.
> >          * @brief Count of blocks transfered from the device.
> >     diff --git a/cpukit/libblock/src/bdbuf.c
> b/cpukit/libblock/src/bdbuf.c
> >     index a7d471507c..02acf11f54 100644
> >     --- a/cpukit/libblock/src/bdbuf.c
> >     +++ b/cpukit/libblock/src/bdbuf.c
> >     @@ -2018,6 +2018,23 @@ rtems_bdbuf_read_ahead_reset
> >     (rtems_disk_device *dd)
> >         dd->read_ahead.trigger = RTEMS_DISK_READ_AHEAD_NO_TRIGGER;
> >     +static void
> >     +rtems_bdbuf_read_ahead_add_to_chain (rtems_disk_device *dd)
> >     +  rtems_status_code sc;
> >     +  rtems_chain_control *chain = &bdbuf_cache.read_ahead_chain;
> >     +  if (rtems_chain_is_empty (chain))
> >     +    sc = rtems_event_send (bdbuf_cache.read_ahead_task,
> >     +                           RTEMS_BDBUF_READ_AHEAD_WAKE_UP);
> >     +    if (sc != RTEMS_SUCCESSFUL)
> >     +      rtems_bdbuf_fatal (RTEMS_BDBUF_FATAL_RA_WAKE_UP);
> >     +  rtems_chain_append_unprotected (chain, &dd->read_ahead.node);
> >       static void
> >       rtems_bdbuf_check_read_ahead_trigger (rtems_disk_device *dd,
> >                                             rtems_blkdev_bnum  block)
> >     @@ -2026,18 +2043,8 @@ rtems_bdbuf_check_read_ahead_trigger
> >             && dd->read_ahead.trigger == block
> >             && !rtems_bdbuf_is_read_ahead_active (dd))
> >     -    rtems_status_code sc;
> >     -    rtems_chain_control *chain = &bdbuf_cache.read_ahead_chain;
> >     -    if (rtems_chain_is_empty (chain))
> >     -      sc = rtems_event_send (bdbuf_cache.read_ahead_task,
> >     -                             RTEMS_BDBUF_READ_AHEAD_WAKE_UP);
> >     -      if (sc != RTEMS_SUCCESSFUL)
> >     -        rtems_bdbuf_fatal (RTEMS_BDBUF_FATAL_RA_WAKE_UP);
> >     -    rtems_chain_append_unprotected (chain, &dd->read_ahead.node);
> >     +    dd->read_ahead.nr_blocks = RTEMS_DISK_READ_AHEAD_SIZE_AUTO;
> >     +    rtems_bdbuf_read_ahead_add_to_chain(dd);
> >     @@ -2112,6 +2119,24 @@ rtems_bdbuf_read (rtems_disk_device   *dd,
> >         return sc;
> >     +void
> >     +rtems_bdbuf_peek (rtems_disk_device *dd,
> >     +                  uint32_t nr_blocks)
> >     +  rtems_bdbuf_lock_cache ();
> >     +  if (bdbuf_cache.read_ahead_enabled)
> >     +    rtems_bdbuf_read_ahead_reset(dd);
> >     +    dd->read_ahead.next = block;
> >     +    dd->read_ahead.nr_blocks = nr_blocks;
> >     +  rtems_bdbuf_unlock_cache ();
> >       static rtems_status_code
> >       rtems_bdbuf_check_bd_and_lock_cache (rtems_bdbuf_buffer *bd, const
> >     char *kind)
> >     @@ -2952,18 +2977,33 @@ rtems_bdbuf_read_ahead_task
> >     (rtems_task_argument arg)
> >               if (bd != NULL)
> >     -          uint32_t transfer_count = dd->block_count - block;
> >     +          uint32_t transfer_count = dd->read_ahead.nr_blocks;
> >     +          uint32_t blocks_till_end_of_disk = dd->block_count -
> block;
> > Use "until" or "til" with one l. "Till" means something else (like a
> > cashier's register).
> OK. Thanks for the correction.
> >                 uint32_t max_transfer_count =
> >     bdbuf_config.max_read_ahead_blocks;
> >     -          if (transfer_count >= max_transfer_count)
> >     +          if (transfer_count > blocks_till_end_of_disk) {
> >     +            transfer_count = blocks_till_end_of_disk;
> >     +          if (transfer_count > max_transfer_count) {
> >                   transfer_count = max_transfer_count;
> >     -            dd->read_ahead.trigger = block + transfer_count / 2;
> >     -            dd->read_ahead.next = block + transfer_count;
> >     -          else
> >     +          if (transfer_count == RTEMS_DISK_READ_AHEAD_SIZE_AUTO) {
> >     +            if (transfer_count >= max_transfer_count)
> > I think this can only be == by this point?
> Just in the line above, I set it to "blocks_till_end_of_disk". It's
> basically to keep the old behavior. But with that it can be bigger then
> max_transfer_count.
> Maybe it's better if I do the check for RTEMS_DISK_READ_AHEAD_SIZE_AUTO
> first and do the other checks only in the else case. I'll change that.
Yes, I think that will help reduce the complexity of this logic.
> >     +              transfer_count = max_transfer_count;
> > Then, this is redundant.
> >     +              dd->read_ahead.trigger = block + transfer_count / 2;
> >     +              dd->read_ahead.next = block + transfer_count;
> >     +            else
> >     +          } else {
> >     +            ++dd->stats.read_ahead_transfers_with_size;
> >                 ++dd->stats.read_ahead_transfers;
> >     diff --git a/cpukit/libblock/src/blkdev-print-stats.c
> >     b/cpukit/libblock/src/blkdev-print-stats.c
> >     index 8edf24fd8c..8e07e97b68 100644
> >     --- a/cpukit/libblock/src/blkdev-print-stats.c
> >     +++ b/cpukit/libblock/src/blkdev-print-stats.c
> >     @@ -40,25 +40,27 @@ void rtems_blkdev_print_stats(
> >            printer,
>  "-------------------------------------------------------------------------------\n"
> >            "                               DEVICE STATISTICS\n"
>  "----------------------+--------------------------------------------------------\n"
> >     -     " MEDIA BLOCK SIZE     | %" PRIu32 "\n"
> >     -     " MEDIA BLOCK COUNT    | %" PRIu32 "\n"
> >     -     " BLOCK SIZE           | %" PRIu32 "\n"
> >     -     " READ HITS            | %" PRIu32 "\n"
> >     -     " READ MISSES          | %" PRIu32 "\n"
> >     -     " READ AHEAD TRANSFERS | %" PRIu32 "\n"
> >     -     " READ BLOCKS          | %" PRIu32 "\n"
> >     -     " READ ERRORS          | %" PRIu32 "\n"
> >     -     " WRITE TRANSFERS      | %" PRIu32 "\n"
> >     -     " WRITE BLOCKS         | %" PRIu32 "\n"
> >     -     " WRITE ERRORS         | %" PRIu32 "\n"
>  "----------------------+--------------------------------------------------------\n",
>  "--------------------------------+----------------------------------------------\n"
> >     +     " MEDIA BLOCK SIZE               | %" PRIu32 "\n"
> >     +     " MEDIA BLOCK COUNT              | %" PRIu32 "\n"
> >     +     " BLOCK SIZE                     | %" PRIu32 "\n"
> >     +     " READ HITS                      | %" PRIu32 "\n"
> >     +     " READ MISSES                    | %" PRIu32 "\n"
> >     +     " READ AHEAD TRANSFERS           | %" PRIu32 "\n"
> >     +     " READ AHEAD TRANSFERS WITH SIZE | %" PRIu32 "\n"
> >     +     " READ BLOCKS                    | %" PRIu32 "\n"
> >     +     " READ ERRORS                    | %" PRIu32 "\n"
> >     +     " WRITE TRANSFERS                | %" PRIu32 "\n"
> >     +     " WRITE BLOCKS                   | %" PRIu32 "\n"
> >     +     " WRITE ERRORS                   | %" PRIu32 "\n"
>  "--------------------------------+----------------------------------------------\n",
> >            media_block_size,
> >            media_block_count,
> >            block_size,
> >            stats->read_hits,
> >            stats->read_misses,
> >            stats->read_ahead_transfers,
> >     +     stats->read_ahead_transfers_with_size,
> >            stats->read_blocks,
> >            stats->read_errors,
> >            stats->write_transfers,
> >     diff --git a/testsuites/fstests/fsdosfswrite01/init.c
> >     b/testsuites/fstests/fsdosfswrite01/init.c
> >     index e5d8e5d6dd..e87289cf6d 100644
> >     --- a/testsuites/fstests/fsdosfswrite01/init.c
> >     +++ b/testsuites/fstests/fsdosfswrite01/init.c
> >     @@ -126,34 +126,37 @@ static void test_normal_file_write(
> >         const char *file_name )
> >         static const rtems_blkdev_stats complete_existing_block_stats = {
> >     -    .read_hits            = 0,
> >     -    .read_misses          = 0,
> >     -    .read_ahead_transfers = 0,
> >     -    .read_blocks          = 0,
> >     -    .read_errors          = 0,
> >     -    .write_transfers      = 1,
> >     -    .write_blocks         = 1,
> >     -    .write_errors         = 0
> >     +    .read_hits                      = 0,
> >     +    .read_misses                    = 0,
> >     +    .read_ahead_transfers           = 0,
> >     +    .read_ahead_transfers_with_size = 0,
> >     +    .read_blocks                    = 0,
> >     +    .read_errors                    = 0,
> >     +    .write_transfers                = 1,
> >     +    .write_blocks                   = 1,
> >     +    .write_errors                   = 0
> >         static const rtems_blkdev_stats complete_new_block_stats = {
> >     -    .read_hits            = 3,
> >     -    .read_misses          = 2,
> >     -    .read_blocks          = 2,
> >     -    .read_errors          = 0,
> >     -    .write_blocks         = 3,
> >     -    .write_errors         = 0
> >     +    .read_hits                      = 3,
> >     +    .read_misses                    = 2,
> >     +    .read_blocks                    = 2,
> >     +    .read_errors                    = 0,
> >     +    .write_blocks                   = 3,
> >     +    .write_errors                   = 0
> >         static const rtems_blkdev_stats partial_new_block_stats = {
> >     -    .read_hits            = 3,
> >     -    .read_misses          = 3,
> >     -    .read_blocks          = 3,
> >     -    .read_errors          = 0,
> >     -    .write_errors         = 0
> >     +    .read_hits                      = 3,
> >     +    .read_misses                    = 3,
> >     +    .read_blocks                    = 3,
> >     +    .read_errors                    = 0,
> >     +    .write_errors                   = 0
> >         int                             rv;
> >     diff --git a/testsuites/libtests/block14/block14.scn
> >     b/testsuites/libtests/block14/block14.scn
> >     index 7170522579..48c22b716d 100644
> >     --- a/testsuites/libtests/block14/block14.scn
> >     +++ b/testsuites/libtests/block14/block14.scn
> >     @@ -6,19 +6,30 @@ action 3
> >       action 4
> >       action 5
> >       action 6
> >     +action 7
> >     +action 8
> >     +action 9
> >     +action 10
> >     +action 11
> >     +action 12
> >     +action 13
> >     +action 14
> >     +action 15
> >                                      DEVICE STATISTICS
> >     - MEDIA BLOCK SIZE     | 0
> >     - MEDIA BLOCK COUNT    | 1
> >     - BLOCK SIZE           | 2
> >     - READ HITS            | 2
> >     - READ MISSES          | 3
> >     - READ AHEAD TRANSFERS | 2
> >     - READ BLOCKS          | 5
> >     - READ ERRORS          | 1
> >     - WRITE TRANSFERS      | 2
> >     - WRITE BLOCKS         | 2
> >     - WRITE ERRORS         | 1
> >     + MEDIA BLOCK SIZE               | 0
> >     + MEDIA BLOCK COUNT              | 1
> >     + BLOCK SIZE                     | 2
> >     + READ HITS                      | 4
> >     + READ MISSES                    | 7
> >     + READ AHEAD TRANSFERS           | 6
> >     + READ AHEAD TRANSFERS WITH SIZE | 3
> >     + READ BLOCKS                    | 13
> >     + READ ERRORS                    | 1
> >     + WRITE TRANSFERS                | 2
> >     + WRITE BLOCKS                   | 2
> >     + WRITE ERRORS                   | 1
> >       *** END OF TEST BLOCK 14 ***
> >     diff --git a/testsuites/libtests/block14/init.c
> >     b/testsuites/libtests/block14/init.c
> >     index b4e73aadc9..24441c4fe8 100644
> >     --- a/testsuites/libtests/block14/init.c
> >     +++ b/testsuites/libtests/block14/init.c
> >     @@ -29,9 +29,9 @@
> >       const char rtems_test_name[] = "BLOCK 14";
> >     -#define ACTION_COUNT 7
> >     +#define ACTION_COUNT 16
> >     -#define BLOCK_COUNT 6
> >     +#define BLOCK_COUNT 14
> >       #define DISK_PATH "/disk"
> >     @@ -42,50 +42,104 @@ typedef struct {
> >           rtems_bdbuf_buffer **bd_ptr
> >     +  void (*peek)(
> >         rtems_status_code expected_get_status;
> >         rtems_status_code (*release)(rtems_bdbuf_buffer *bd);
> >       } test_action;
> >       static const test_action actions [ACTION_COUNT] = {
> >     -  { 0, rtems_bdbuf_read, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
> >     -  { 1, rtems_bdbuf_read, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
> >     -  { 2, rtems_bdbuf_read, RTEMS_SUCCESSFUL, rtems_bdbuf_release },
> >     -  { 4, rtems_bdbuf_get, RTEMS_SUCCESSFUL, rtems_bdbuf_sync },
> >     -  { 5, rtems_bdbuf_read, RTEMS_IO_ERROR, rtems_bdbuf_release },
> >     -  { 5, rtems_bdbuf_get, RTEMS_SUCCESSFUL, rtems_bdbuf_sync }
> >     +  /* normal read ahead */
> >     +  { 0, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL,
> >     +  { 1, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL,
> >     +  { 2, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL,
> >     +  /* re-read a cached block */
> >     +  /* cause some writes */
> >     +  { 4, rtems_bdbuf_get, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_sync },
> >     +  { 5, rtems_bdbuf_read, NULL, RTEMS_IO_ERROR, rtems_bdbuf_release
> >     +  { 5, rtems_bdbuf_get, NULL, RTEMS_SUCCESSFUL, rtems_bdbuf_sync },
> >     +  /* interrupt normal read ahead with a peek */
> >     +  { 9, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL,
> >     +  { 13, NULL, rtems_bdbuf_peek, 0, NULL },
> >     +  { 10, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL,
> >     +  { 11, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL,
> >     +  { 12, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL,
> >     +  /* peek with hit */
> >     +  { 6, NULL, rtems_bdbuf_peek, 0, NULL },
> >     +  { 6, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL,
> >     +  /* (wrong) peek with reading different block */
> >     +  { 8, NULL, rtems_bdbuf_peek, 0, NULL },
> >     +  { 7, rtems_bdbuf_read, NULL, RTEMS_SUCCESSFUL,
> >     -#define STATS(a, b, c, d, e, f, g, h) \
> >     +#define STATS(a, b, c, d, e, f, g, h, i) \
> >           .read_hits = a, \
> >           .read_misses = b, \
> >           .read_ahead_transfers = c, \
> >     -    .read_blocks = d, \
> >     -    .read_errors = e, \
> >     -    .write_transfers = f, \
> >     -    .write_blocks = g, \
> >     -    .write_errors = h \
> >     +    .read_ahead_transfers_with_size = d, \
> >     +    .read_blocks = e, \
> >     +    .read_errors = f, \
> >     +    .write_transfers = g, \
> >     +    .write_blocks = h, \
> >     +    .write_errors = i \
> >       static const rtems_blkdev_stats expected_stats [ACTION_COUNT] = {
> >     -  STATS(0, 1, 0, 1, 0, 0, 0, 0),
> >     -  STATS(0, 2, 1, 3, 0, 0, 0, 0),
> >     -  STATS(1, 2, 2, 4, 0, 0, 0, 0),
> >     -  STATS(2, 2, 2, 4, 0, 0, 0, 0),
> >     -  STATS(2, 2, 2, 4, 0, 1, 1, 0),
> >     -  STATS(2, 3, 2, 5, 1, 1, 1, 0),
> >     -  STATS(2, 3, 2, 5, 1, 2, 2, 1)
> >     +  STATS(0, 1, 0, 0, 1, 0, 0, 0, 0),
> >     +  STATS(0, 2, 1, 0, 3, 0, 0, 0, 0),
> >     +  STATS(1, 2, 2, 0, 4, 0, 0, 0, 0),
> >     +  STATS(2, 2, 2, 0, 4, 0, 0, 0, 0),
> >     +  STATS(2, 2, 2, 0, 4, 0, 1, 1, 0),
> >     +  STATS(2, 3, 2, 0, 5, 1, 1, 1, 0),
> >     +  STATS(2, 3, 2, 0, 5, 1, 2, 2, 1),
> >     +  STATS(2, 4, 2, 0, 6, 1, 2, 2, 1),
> >     +  STATS(2, 4, 3, 1, 7, 1, 2, 2, 1),
> >     +  STATS(2, 5, 3, 1, 8, 1, 2, 2, 1),
> >     +  STATS(2, 6, 4, 1, 10, 1, 2, 2, 1),
> >     +  STATS(3, 6, 4, 1, 10, 1, 2, 2, 1),
> >     +  STATS(3, 6, 5, 2, 11, 1, 2, 2, 1),
> >     +  STATS(4, 6, 5, 2, 11, 1, 2, 2, 1),
> >     +  STATS(4, 6, 6, 3, 12, 1, 2, 2, 1),
> >     +  STATS(4, 7, 6, 3, 13, 1, 2, 2, 1),
> >       static const int expected_block_access_counts [ACTION_COUNT]
> >     [BLOCK_COUNT] = {
> >     -   { 1, 0, 0, 0, 0, 0 },
> >     -   { 1, 1, 1, 0, 0, 0 },
> >     -   { 1, 1, 1, 1, 0, 0 },
> >     -   { 1, 1, 1, 1, 1, 0 },
> >     -   { 1, 1, 1, 1, 1, 1 },
> >     -   { 1, 1, 1, 1, 1, 2 }
> >     +   { 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
> >     +   { 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
> >     +   { 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
> >     +   { 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
> >     +   { 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0 },
> >     +   { 1, 1, 1, 1, 1, 2, 0, 0, 0, 0, 0, 0, 0, 0 },
> >     +   { 1, 1, 1, 1, 1, 2, 0, 0, 0, 1, 0, 0, 0, 0 },
> >     +   { 1, 1, 1, 1, 1, 2, 0, 0, 0, 1, 0, 0, 0, 1 },
> >     +   { 1, 1, 1, 1, 1, 2, 0, 0, 0, 1, 1, 0, 0, 1 },
> >     +   { 1, 1, 1, 1, 1, 2, 0, 0, 0, 1, 1, 1, 1, 1 },
> >     +   { 1, 1, 1, 1, 1, 2, 1, 0, 0, 1, 1, 1, 1, 1 },
> >     +   { 1, 1, 1, 1, 1, 2, 1, 0, 1, 1, 1, 1, 1, 1 },
> >     +   { 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 1, 1 },
> >       static int block_access_counts [BLOCK_COUNT];
> >     @@ -132,10 +186,16 @@ static void test_actions(rtems_disk_device *dd)
> >           printf("action %i\n", i);
> >     -    sc = (*action->get)(dd, action->block, &bd);
> >     -    rtems_test_assert(sc == action->expected_get_status);
> >     +    if (action->get != NULL) {
> >     +      sc = (*action->get)(dd, action->block, &bd);
> >     +      rtems_test_assert(sc == action->expected_get_status);
> >     +    if (action->peek != NULL) {
> >     +      (*action->peek)(dd, action->block, 1);
> >     -    if (sc == RTEMS_SUCCESSFUL) {
> >     +    if (sc == RTEMS_SUCCESSFUL && action->release != NULL) {
> >             sc = (*action->release)(bd);
> >             rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> >     2.26.2
> >     _______________________________________________
> >     devel mailing list
> >     devel at rtems.org <mailto:devel at rtems.org>
> >     http://lists.rtems.org/mailman/listinfo/devel
> >     <http://lists.rtems.org/mailman/listinfo/devel>
> embedded brains GmbH
> Herr Christian MAUDERER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> phone: +49-89-18 94 741 - 18
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210122/8c44fd46/attachment-0001.html>
