[PATCH 5/6] nios2: Optimize ISR dispatch variant
Sebastian Huber
Wed Jan 27 09:13:34 UTC 2021
Use _Thread_Do_dispatch() in
_Nios2_ISR_Dispatch_with_shadow_non_preemptive().
.../score/cpu/nios2/nios2-eic-il-low-level.S | 102 ++++++++++--------
1 file changed, 60 insertions(+), 42 deletions(-)
diff --git a/cpukit/score/cpu/nios2/nios2-eic-il-low-level.S b/cpukit/score/cpu/nios2/nios2-eic-il-low-level.S
index c215d4bd94..1632fbb8c2 100644
--- a/cpukit/score/cpu/nios2/nios2-eic-il-low-level.S
+++ b/cpukit/score/cpu/nios2/nios2-eic-il-low-level.S
@@ -55,16 +55,16 @@ _Nios2_ISR_Dispatch_with_shadow_non_preemptive:
ldw r4, 8(et)
/* Increment and store thread dispatch disable level */
- addi r9, r16, 1
- stw r9, %gprel(_Per_CPU_Information + PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL)(gp)
+ addi r17, r16, 1
+ stw r17, %gprel(_Per_CPU_Information + PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL)(gp)
/* Call high level handler with argument */
callr r8
- /* Load thread dispatch necessary */
+ /* Load the thread dispatch necessary indicator */
ldb r12, %gprel(_Per_CPU_Information + PER_CPU_DISPATCH_NEEDED)(gp)
- /* Load thread dispatch after ISR disable indicator */
+ /* Load the thread dispatch after ISR disable indicator */
ldw r13, %gprel(_Per_CPU_Information + PER_CPU_ISR_DISPATCH_DISABLE)(gp)
/* Read status */
@@ -74,31 +74,36 @@ _Nios2_ISR_Dispatch_with_shadow_non_preemptive:
subi ea, ea, 4
- * Restore the thread dispatch disable level. We must do this before
- * we return to the normal register set, because otherwise we have
- * problems if someone deletes or restarts the interrupted thread while
- * we are in the thread dispatch helper.
+ * If the current thread dispatch disable level (r17) is one, then
+ * negate the thread dispatch necessary indicator, otherwise the value
+ * is irrelevant. Or it with the previous thread dispatch disable
+ * level value (r16). The r15 which will be used as a status to
+ * determine if a thread dispatch is necessary and allowed.
- stw r16, %gprel(_Per_CPU_Information + PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL)(gp)
- /* Is thread dispatch allowed? */
- bne r16, zero, no_thread_dispatch
+ xor r12, r17, r12
+ or r15, r12, r16
- /* Is thread dispatch necessary? */
- beq r12, zero, no_thread_dispatch
+ * Get the previous register set from r14. If it is zero, then this is
+ * the outermost interrupt. Or it to the thread dispatch status (r15).
+ andhi r12, r14, 0x3f
+ or r15, r12, r15
- /* Is outermost interrupt? */
- andhi r14, r14, 0x3f
- bne r14, zero, no_thread_dispatch
+ * Or the thread dispatch after ISR disable indicator (r13) to the
+ * thread dispatch status (r15).
+ or r15, r13, r15
- /* Is thread dispatch after ISR allowed? */
- bne r13, zero, no_thread_dispatch
+ /* Is a thread dispatch necessary and allowed? */
+ bne r15, zero, no_thread_dispatch
/* Obtain stack frame in normal register set */
rdprs r15, sp, -FRAME_SIZE
/* Disable thread dispatch after ISR */
- stw r12, %gprel(_Per_CPU_Information + PER_CPU_ISR_DISPATCH_DISABLE)(gp)
+ stw r17, %gprel(_Per_CPU_Information + PER_CPU_ISR_DISPATCH_DISABLE)(gp)
/* Save context */
stw sstatus, FRAME_OFFSET_STATUS(r15)
@@ -111,12 +116,15 @@ _Nios2_ISR_Dispatch_with_shadow_non_preemptive:
/* Update stack pointer in normal register set */
wrprs sp, r15
+ /* Jump to thread dispatch helper */
+ eret
no_thread_dispatch:
- * Return to thread dispatch helper, interrupted thread or interrupted
- * lower level interrupt service routine.
+ /* Restore the thread dispatch disable level */
+ stw r16, %gprel(_Per_CPU_Information + PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL)(gp)
+ /* Return to interrupted context */
eret
thread_dispatch_helper:
@@ -141,9 +149,26 @@ thread_dispatch_helper:
stw r14, FRAME_OFFSET_R14(sp)
stw r15, FRAME_OFFSET_R15(sp)
+ * Disable interrupts (1).
+ * We have the following invariants:
+ * 1. status.RSIE == 0: thread context initialization
+ * 2. status.CRS == 0: thread context initialization
+ * 3. status.PRS: arbitrary
+ * 4. status.IL < interrupt disable IL: else we would not be here
+ * 5. status.IH == 0: thread context initialization
+ * 6. status.U == 0: thread context initialization
+ * 7. status.PIE == 1: thread context initialization
+ * Thus we can use a constant to disable interrupts.
+ movi r5, %lo(_Nios2_ISR_Status_interrupts_disabled)
+ wrctl status, r5
do_thread_dispatch:
- call _Thread_Dispatch
+ addi r4, gp, %gprel(_Per_CPU_Information)
+ call _Thread_Do_dispatch
/* Restore some volatile registers */
ldw ra, FRAME_OFFSET_RA(sp)
@@ -160,19 +185,7 @@ do_thread_dispatch:
ldw r11, FRAME_OFFSET_R11(sp)
ldw r12, FRAME_OFFSET_R12(sp)
- * Disable interrupts.
- * We have the following invariants:
- * 1. status.RSIE == 0: thread context initialization
- * 2. status.CRS == 0: thread context initialization
- * 3. status.PRS: arbitrary
- * 4. status.IL < interrupt disable IL: else we would not be here
- * 5. status.IH == 0: thread context initialization
- * 6. status.U == 0: thread context initialization
- * 7. status.PIE == 1: thread context initialization
- * Thus we can use a constant to disable interrupts.
+ /* Disable interrupts, see (1) */
rdctl r14, status
movi r15, %lo(_Nios2_ISR_Status_interrupts_disabled)
wrctl status, r15
@@ -181,7 +194,7 @@ do_thread_dispatch:
ldb r13, %gprel(_Per_CPU_Information + PER_CPU_DISPATCH_NEEDED)(gp)
- bne r13, zero, enable_interrupts_before_thread_dispatch
+ bne r13, zero, prepare_thread_dispatch
/* Enable thread dispatch after ISR */
stw zero, %gprel(_Per_CPU_Information + PER_CPU_ISR_DISPATCH_DISABLE)(gp)
@@ -204,9 +217,14 @@ do_thread_dispatch:
/* Return to interrupted thread */
eret
-enable_interrupts_before_thread_dispatch:
+prepare_thread_dispatch:
+ /* Disable thread dispatching */
+ movi r4, 1
+ stw r4, %gprel(_Per_CPU_Information + PER_CPU_ISR_DISPATCH_DISABLE)(gp)
+ stw r4, %gprel(_Per_CPU_Information + PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL)(gp)
- /* Restore status */
- wrctl status, r14
+ /* Set interrupt level argument for _Thread_Do_dispatch() */
+ mov r5, r15
br do_thread_dispatch
2.26.2
