[PATCH 4/6] nios2: Use Per_CPU_Control::isr_dispatch_disable
Wed Jan 27 09:13:33 UTC 2021
 cpukit/score/cpu/nios2/include/rtems/score/cpu.h  | 14 ++++++++------
 .../cpu/nios2/include/rtems/score/nios2-utility.h | 13 +------------
 cpukit/score/cpu/nios2/nios2-context-switch.S     | 12 ++++++------
 cpukit/score/cpu/nios2/nios2-eic-il-low-level.S   | 15 +++++++--------
 .../cpu/nios2/nios2-thread-dispatch-disabled.c    |  4 +---
 5 files changed, 23 insertions(+), 35 deletions(-)
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/cpu.h b/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
index 5fffed646e..8caec19b5b 100644
--- a/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
@@ -106,11 +106,6 @@ extern "C" {
  * There is no need to save the global pointer (gp) since it is a system wide
  * constant and set-up with the C runtime environment.
- * The @a thread_dispatch_disabled field is used for the external interrupt
- * controller (EIC) support.
- * @see _Nios2_Thread_dispatch_disabled
 typedef struct {
   uint32_t r16;
@@ -125,7 +120,14 @@ typedef struct {
   uint32_t status;
   uint32_t sp;
   uint32_t ra;
-  uint32_t thread_dispatch_disabled;
+   * @brief This member is used for the external interrupt controller (EIC) support.
+   * It corresponds to Per_CPU_Control::isr_dispatch_disable.
+  uint32_t isr_dispatch_disable;
   uint32_t stack_mpubase;
   uint32_t stack_mpuacc;
 } Context_Control;
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/nios2-utility.h b/cpukit/score/cpu/nios2/include/rtems/score/nios2-utility.h
index d5eb4b3597..9367f73315 100644
--- a/cpukit/score/cpu/nios2/include/rtems/score/nios2-utility.h
+++ b/cpukit/score/cpu/nios2/include/rtems/score/nios2-utility.h
@@ -47,7 +47,7 @@
 #define NIOS2_CONTEXT_OFFSET_STATUS 36
 #define NIOS2_CONTEXT_OFFSET_SP 40
 #define NIOS2_CONTEXT_OFFSET_RA 44
-#define NIOS2_CONTEXT_OFFSET_THREAD_DISPATCH_DISABLED 48
+#define NIOS2_CONTEXT_OFFSET_ISR_DISPATCH_DISABLE 48
 #define NIOS2_CONTEXT_OFFSET_STACK_MPUBASE 52
 #define NIOS2_CONTEXT_OFFSET_STACK_MPUACC 56
@@ -143,17 +143,6 @@
 extern "C" {
 #endif /* __cplusplus */
- * @brief Nios II specific thread dispatch disabled indicator.
- * This global variable is used by the interrupt dispatch support for the
- * external interrupt controller (EIC) with shadow registers.  This makes it
- * possible to do the thread dispatch after an interrupt without disabled
- * interrupts and thus probably reduce the maximum interrupt latency.  Its
- * purpose is to prevent unbounded stack usage of the interrupted thread.
-extern uint32_t _Nios2_Thread_dispatch_disabled;
  * @brief This global symbol specifies the status register mask used to disable
  * interrupts.
diff --git a/cpukit/score/cpu/nios2/nios2-context-switch.S b/cpukit/score/cpu/nios2/nios2-context-switch.S
index 0203faef48..3792f693da 100644
--- a/cpukit/score/cpu/nios2/nios2-context-switch.S
+++ b/cpukit/score/cpu/nios2/nios2-context-switch.S
@@ -15,17 +15,17 @@
 #include "config.h"
 #endif
-#include <rtems/score/cpu.h>
+#include <rtems/score/percpu.h>
 #include <rtems/score/nios2-utility.h>
-	.extern	_Nios2_Thread_dispatch_disabled
+	.extern	_Per_CPU_Information
 	.globl	_CPU_Context_switch
 	.globl	_CPU_Context_restore
 _CPU_Context_switch:
-	ldw	r9, %gprel(_Nios2_Thread_dispatch_disabled)(gp)
+	ldw	r9, %gprel(_Per_CPU_Information + PER_CPU_ISR_DISPATCH_DISABLE)(gp)
 	rdctl	r8, status
 	stw	r16, NIOS2_CONTEXT_OFFSET_R16(r4)
 	stw	r17, NIOS2_CONTEXT_OFFSET_R17(r4)
@@ -39,11 +39,11 @@ _CPU_Context_switch:
 	stw	r8, NIOS2_CONTEXT_OFFSET_STATUS(r4)
 	stw	sp, NIOS2_CONTEXT_OFFSET_SP(r4)
 	stw	ra, NIOS2_CONTEXT_OFFSET_RA(r4)
-	stw	r9, NIOS2_CONTEXT_OFFSET_THREAD_DISPATCH_DISABLED(r4)
+	stw	r9, NIOS2_CONTEXT_OFFSET_ISR_DISPATCH_DISABLE(r4)
 restore:
-	ldw	r10, NIOS2_CONTEXT_OFFSET_THREAD_DISPATCH_DISABLED(r5)
+	ldw	r10, NIOS2_CONTEXT_OFFSET_ISR_DISPATCH_DISABLE(r5)
 	ldw	r16, NIOS2_CONTEXT_OFFSET_R16(r5)
 	ldw	r17, NIOS2_CONTEXT_OFFSET_R17(r5)
 	ldw	r18, NIOS2_CONTEXT_OFFSET_R18(r5)
@@ -53,7 +53,7 @@ restore:
 	ldw	r22, NIOS2_CONTEXT_OFFSET_R22(r5)
 	ldw	r23, NIOS2_CONTEXT_OFFSET_R23(r5)
 	ldw	fp, NIOS2_CONTEXT_OFFSET_FP(r5)
-	stw	r10, %gprel(_Nios2_Thread_dispatch_disabled)(gp)
+	stw	r10, %gprel(_Per_CPU_Information + PER_CPU_ISR_DISPATCH_DISABLE)(gp)
 	ldw	r11, NIOS2_CONTEXT_OFFSET_STATUS(r5)
 	ldw	sp, NIOS2_CONTEXT_OFFSET_SP(r5)
 	ldw	ra, NIOS2_CONTEXT_OFFSET_RA(r5)
diff --git a/cpukit/score/cpu/nios2/nios2-eic-il-low-level.S b/cpukit/score/cpu/nios2/nios2-eic-il-low-level.S
index a8045d74df..c215d4bd94 100644
--- a/cpukit/score/cpu/nios2/nios2-eic-il-low-level.S
+++ b/cpukit/score/cpu/nios2/nios2-eic-il-low-level.S
@@ -41,7 +41,6 @@
 	.section	.text
 	.extern	_Nios2_ISR_Status_interrupts_disabled
 	.globl	_Nios2_ISR_Dispatch_with_shadow_non_preemptive
@@ -65,8 +64,8 @@ _Nios2_ISR_Dispatch_with_shadow_non_preemptive:
 	/* Load thread dispatch necessary */
 	ldb	r12, %gprel(_Per_CPU_Information + PER_CPU_DISPATCH_NEEDED)(gp)
-	/* Load Nios II specific thread dispatch disabled */
-	ldw	r13, %gprel(_Nios2_Thread_dispatch_disabled)(gp)
+	/* Load thread dispatch after ISR disable indicator */
+	ldw	r13, %gprel(_Per_CPU_Information + PER_CPU_ISR_DISPATCH_DISABLE)(gp)
 	/* Read status */
 	rdctl	r14, status
@@ -92,14 +91,14 @@ _Nios2_ISR_Dispatch_with_shadow_non_preemptive:
 	andhi	r14, r14, 0x3f
 	bne	r14, zero, no_thread_dispatch
-	/* Is Nios II specific thread dispatch allowed? */
+	/* Is thread dispatch after ISR allowed? */
 	bne	r13, zero, no_thread_dispatch
 	/* Obtain stack frame in normal register set */
 	rdprs	r15, sp, -FRAME_SIZE
-	/* Disable Nios II specific thread dispatch */
-	stw	r12, %gprel(_Nios2_Thread_dispatch_disabled)(gp)
+	/* Disable thread dispatch after ISR */
+	stw	r12, %gprel(_Per_CPU_Information + PER_CPU_ISR_DISPATCH_DISABLE)(gp)
 	/* Save context */
 	stw	sstatus, FRAME_OFFSET_STATUS(r15)
@@ -184,8 +183,8 @@ do_thread_dispatch:
 	/* Is thread dispatch necessary? */
 	bne	r13, zero, enable_interrupts_before_thread_dispatch
-	/* Enable Nios II specific thread dispatch */
-	stw	zero, %gprel(_Nios2_Thread_dispatch_disabled)(gp)
+	/* Enable thread dispatch after ISR */
+	stw	zero, %gprel(_Per_CPU_Information + PER_CPU_ISR_DISPATCH_DISABLE)(gp)
 	/* Restore remaining volatile register */
 	ldw	r13, FRAME_OFFSET_R13(sp)
diff --git a/cpukit/score/cpu/nios2/nios2-thread-dispatch-disabled.c b/cpukit/score/cpu/nios2/nios2-thread-dispatch-disabled.c
index 952a979a98..8d1e3ee9b8 100644
--- a/cpukit/score/cpu/nios2/nios2-thread-dispatch-disabled.c
+++ b/cpukit/score/cpu/nios2/nios2-thread-dispatch-disabled.c
@@ -43,8 +43,6 @@ NIOS2_ASSERT_OFFSET(fp, FP);
 NIOS2_ASSERT_OFFSET(status, STATUS);
 NIOS2_ASSERT_OFFSET(sp, SP);
 NIOS2_ASSERT_OFFSET(ra, RA);
-NIOS2_ASSERT_OFFSET(thread_dispatch_disabled, THREAD_DISPATCH_DISABLED);
+NIOS2_ASSERT_OFFSET(isr_dispatch_disable, ISR_DISPATCH_DISABLE);
 NIOS2_ASSERT_OFFSET(stack_mpubase, STACK_MPUBASE);
 NIOS2_ASSERT_OFFSET(stack_mpuacc, STACK_MPUACC);
-uint32_t _Nios2_Thread_dispatch_disabled;
2.26.2
