Fwd: New Defects reported by Coverity Scan for RTEMS
Thu Jan 28 04:24:56 UTC 2021
FYI
---------- Forwarded message ---------
Date: Wed, Jan 27, 2021, 9:21 PM
Subject: New Defects reported by Coverity Scan for RTEMS
To: <gedare at gwmail.gwu.edu>
Hi,
Please find the latest report on new defect(s) introduced to RTEMS found
with Coverity Scan.
11 new defect(s) introduced to RTEMS found with Coverity Scan.
42 defect(s), reported by Coverity Scan earlier, were marked fixed in the
recent build analyzed by Coverity Scan.
New defect(s) Reported-by: Coverity Scan
Showing 11 of 11 defect(s)
** CID 1472583:    (STRING_NULL)
/cpukit/libdl/rtl-archive.c: 796 in rtems_rtl_archives_refresh()
/cpukit/libdl/rtl-archive.c: 798 in rtems_rtl_archives_refresh()
________________________________________________________________________________________________________
*** CID 1472583:    (STRING_NULL)
790         {
791           ++config_path;
792           continue;
793         }
794
795         if (rtems_rtl_trace (RTEMS_RTL_TRACE_ARCHIVES))
>>>     Passing unterminated string "dirname" to "printf".
796           printf ("rtl: archive: refresh: %s\n", dirname);
797
798         config_path += strlen (dirname);
799
800         /*
801          * Relative paths do not work in the config. Must be absolute.
790         {
791           ++config_path;
792           continue;
793         }
794
797
799
800         /*
790         {
791           ++config_path;
792           continue;
793         }
794
797
799
800         /*
792           continue;
793         }
794
797
>>>     Passing unterminated string "dirname" to "strlen", which expects a
null-terminated string.
799
800         /*
802          */
803         if (dirname[0] != '/')
792           continue;
793         }
794
797
799
800         /*
802          */
792           continue;
793         }
794
797
799
800         /*
802          */
** CID 1472582:  Insecure data handling  (TAINTED_SCALAR)
*** CID 1472582:  Insecure data handling  (TAINTED_SCALAR)
/cpukit/libdl/rtl-elf.c: 1328 in rtems_rtl_elf_parse_sections()
1322           printf ("rtl: section header: %2d: offset=%d\n", section,
(int) off);
1323
1324         if (!rtems_rtl_obj_cache_read_byval (sects, fd, off, &shdr,
sizeof (shdr)))
1325           return false;
1326
1327         len = RTEMS_RTL_ELF_STRING_MAX;
>>>     Passing tainted expression "sectstroff + shdr.sh_name" to
"rtems_rtl_obj_cache_read", which uses it as an offset.
1328         if (!rtems_rtl_obj_cache_read (strings, fd,
1329                                        sectstroff + shdr.sh_name,
1330                                        (void**) &name, &len))
1331           return false;
1332
1333         if (rtems_rtl_trace (RTEMS_RTL_TRACE_DETAIL))
** CID 1472581:  Null pointer dereferences  (REVERSE_INULL)
/cpukit/mghttpd/mongoose.c: 656 in cry()
*** CID 1472581:  Null pointer dereferences  (REVERSE_INULL)
650
651       // Do not lock when getting the callback value, here and below.
652       // I suppose this is fine, since function cannot disappear in the
653       // same way string option can.
654       if (conn->ctx->callbacks.log_message == NULL ||
655           conn->ctx->callbacks.log_message(conn, buf) == 0) {
>>>     Null-checking "conn->ctx" suggests that it may be null, but it has
already been dereferenced on all paths leading to the check.
656         fp = conn->ctx == NULL || conn->ctx->config[ERROR_LOG_FILE] ==
NULL ? NULL :
657           fopen(conn->ctx->config[ERROR_LOG_FILE], "a+");
658
659         if (fp != NULL) {
660           flockfile(fp);
661           timestamp = time(NULL);
** CID 1472580:    (TAINTED_SCALAR)
/cpukit/libdl/rtl-rap.c: 921 in rtems_rtl_rap_file_load()
/cpukit/libdl/rtl-rap.c: 915 in rtems_rtl_rap_file_load()
*** CID 1472580:    (TAINTED_SCALAR)
/cpukit/libdl/rtl-rap.c: 933 in rtems_rtl_rap_file_load()
927         if (!rtems_rtl_rap_read_uint32 (rap.decomp, &rap.strtable_size))
928           return false;
929
930         if (rtems_rtl_trace (RTEMS_RTL_TRACE_DETAIL))
931           printf ("rtl: rap: details: obj_num=%" PRIu32 "\n",
obj->obj_num);
932
>>>     Passing tainted expression "rap.rpathlen" to
"rtems_rtl_rap_load_linkmap", which uses it as a loop boundary.
933         if (!rtems_rtl_rap_load_linkmap (&rap, obj))
934           return false;
935       }
936
937       /*
938        * uint32_t: text_size
915         obj->sec_num = (uint32_t*) malloc (sizeof (uint32_t) *
obj->obj_num);
916
917         if (!rtems_rtl_rap_read_uint32 (rap.decomp, &rap.rpathlen))
918           return false;
919
920         uint32_t i;
>>>     Using tainted variable "obj->obj_num" as a loop boundary.
921         for (i = 0; i < obj->obj_num; ++i)
922         {
923           if (!rtems_rtl_rap_read_uint32 (rap.decomp,
&(obj->sec_num[i])))
924             return false;
925         }
926
909        */
910       if (!rtems_rtl_rap_read_uint32 (rap.decomp, &obj->obj_num))
911         return false;
912
913       if (obj->obj_num > 0)
914       {
>>>     Passing tainted expression "4U * obj->obj_num" to "malloc", which
uses it as an allocation size. [Note: The source code implementation of the
function has been overridden by a builtin model.]
obj->obj_num);
916
918           return false;
919
920         uint32_t i;
928           return false;
929
obj->obj_num);
932
>>>     Passing tainted expression "rap.strtable_size" to
"rtems_rtl_rap_load_linkmap", which uses it as an offset.
934           return false;
935       }
936
937       /*
928           return false;
929
obj->obj_num);
932
>>>     Passing tainted expression "*obj->sec_num" to
934           return false;
935       }
936
937       /*
** CID 1472579:  Error handling issues  (CHECKED_RETURN)
/cpukit/mghttpd/mongoose.c: 3716 in put_file()
*** CID 1472579:  Error handling issues  (CHECKED_RETURN)
3710       } else {
3711         fclose_on_exec(&file);
3712         range = mg_get_header(conn, "Content-Range");
3713         r1 = r2 = 0;
3714         if (range != NULL && parse_range_header(range, &r1, &r2) > 0) {
3715           conn->status_code = 206;
>>>     Calling "fseeko(file.fp, r1, 0)" without checking return value.
This library function may fail and return an error code.
3716           fseeko(file.fp, r1, SEEK_SET);
3717         }
3718         if (!forward_body_data(conn, file.fp, INVALID_SOCKET, NULL)) {
3719           conn->status_code = 500;
3720         }
3721         mg_printf(conn, "HTTP/1.1 %d OK\r\nContent-Length: 0\r\n\r\n",
** CID 1472578:  Uninitialized variables  (UNINIT)
*** CID 1472578:  Uninitialized variables  (UNINIT)
/cpukit/libfs/src/jffs2/src/scan.c: 759 in jffs2_scan_eraseblock()
753                             continue;
754                     }
755                     /* We seem to have a node of sorts. Check the CRC */
756                     crcnode.magic = node->magic;
757                     crcnode.nodetype = cpu_to_je16(
je16_to_cpu(node->nodetype) | JFFS2_NODE_ACCURATE);
758                     crcnode.totlen = node->totlen;
>>>     Using uninitialized value "crcnode". Field "crcnode.hdr_crc" is
uninitialized when calling "cyg_crc32_accumulate".
759                     hdr_crc = crc32(0, &crcnode, sizeof(crcnode)-4);
760
761                     if (hdr_crc != je32_to_cpu(node->hdr_crc)) {
762                             noisy_printk(&noise, "%s(): Node at 0x%08x
{0x%04x, 0x%04x, 0x%08x) has invalid CRC 0x%08x (calculated 0x%08x)\n",
763                                          __func__,
764                                          ofs, je16_to_cpu(node->magic),
** CID 1472577:    (PATH_MANIPULATION)
/cpukit/mghttpd/mongoose.c: 4432 in mg_upload()
*** CID 1472577:    (PATH_MANIPULATION)
4426             (s = strrchr(fname, '\\')) == NULL) {
4427           s = fname;
4428         }
4429
4430         // Open file in binary mode. TODO: set an exclusive lock.
4431         snprintf(path, sizeof(path), "%s/%s", destination_dir, s);
>>>     Constructing a path or URI using the tainted value "path" and
passing it to "fopen". This may allow an attacker to access, modify, or
test the existence of critical or sensitive files.
4432         if ((fp = fopen(path, "wb")) == NULL) {
4433           break;
4434         }
4435
4436         // Read POST data, write into file until boundary is found.
4437         eof = n = 0;
4427           s = fname;
4428         }
4429
4433           break;
4434         }
4435
4437         eof = n = 0;
4427           s = fname;
4428         }
4429
4433           break;
4434         }
4435
4437         eof = n = 0;
** CID 1472576:  Null pointer dereferences  (FORWARD_NULL)
*** CID 1472576:  Null pointer dereferences  (FORWARD_NULL)
/cpukit/libblock/src/bdbuf.c: 2632 in rtems_bdbuf_swapout_worker_task()
2626       rtems_bdbuf_swapout_worker* worker =
(rtems_bdbuf_swapout_worker*) arg;
2627
2628       while (worker->enabled)
2629       {
2630         rtems_bdbuf_wait_for_event (RTEMS_BDBUF_SWAPOUT_SYNC);
2631
>>>     Passing "&worker->transfer" to "rtems_bdbuf_swapout_write", which
dereferences null "worker->transfer.dd".
2632         rtems_bdbuf_swapout_write (&worker->transfer);
2633
2634         rtems_bdbuf_lock_cache ();
2635
2636         rtems_chain_initialize_empty (&worker->transfer.bds);
2637         worker->transfer.dd = BDBUF_INVALID_DEV;
** CID 1472575:  Memory - illegal accesses  (UNINIT)
/cpukit/libmisc/shell/main_rtrace.c: 229 in
rtems_trace_buffering_print_arg()
*** CID 1472575:  Memory - illegal accesses  (UNINIT)
223           memcpy (&variable.bytes[0], argv, arg->size);
224
225         printf ("(%s) ", arg->type);
226
227         if (strchr (arg->type, '*') != NULL)
228         {
>>>     Using uninitialized value "variable.pointer" when calling "printf".
229           printf ("%p", variable.pointer);
230         }
231         else
232         {
233           size_t b;
234           switch (arg->size)
** CID 1472574:  Error handling issues  (CHECKED_RETURN)
/cpukit/libfs/src/dosfs/msdos_format.c: 131 in msdos_format_read_sec()
*** CID 1472574:  Error handling issues  (CHECKED_RETURN)
125       int ret_val = 0;
126
127       if (0 > lseek(fd,((off_t)start_sector)*sector_size,SEEK_SET)) {
128         ret_val = -1;
129       }
130       if (ret_val == 0) {
>>>     "read(int, void *, size_t)" returns the number of bytes read, but
it is ignored.
131         if (0 > read(fd,buffer,sector_size)) {
132           ret_val = -1;
133         }
134       }
135
136       return ret_val;
** CID 1472573:  Insecure data handling  (TAINTED_SCALAR)
*** CID 1472573:  Insecure data handling  (TAINTED_SCALAR)
/cpukit/libdl/rtl-elf.c: 1706 in rtems_rtl_elf_file_load()
1700
1701       /*
1702        * Parse the section information first so we have the memory map
of the object
1703        * file and the memory allocated. Any further allocations we
make to complete
1704        * the load will not fragment the memory.
1705        */
>>>     Passing tainted expression "ehdr.e_shnum" to
"rtems_rtl_elf_parse_sections", which uses it as a loop boundary.
1706       if (!rtems_rtl_elf_parse_sections (obj, fd, &ehdr))
1707         return false;
1708
1709       /*
1710        * Set the entry point if there is one.
1711        */
To view the defects in Coverity Scan visit,
https://u15810271.ct.sendgrid.net/ls/click?upn=HRESupC-2F2Czv4BOaCWWCy7my0P0qcxCbhZ31OYv50ypUUzi-2FdSNmuyRB7BEFT8xQ4-2B8hpujh0hTgQljRGId4Dg-3D-3DHaSx_NXfCUf1CLFYLbjXajJIgHlbL5qYn95oel6MvjPauKOZWRAeoPfG9R5Ut-2B0l1A5CBYN8H1u2OvYHQK1lhr4Zh6SDh2S5PCPFmmyp-2BCuliFxJzj1S7OgK9z2cMZjSTabCeURWJhVg1EI1bNhOt7aXFw3Vp5t2pGj4mbLRlTtRMHZ6hxDQXicJzm8pwnsWJaDgwdb8CD96vfoF8CM8XgA81RPZ7mfvWd3hfqlGbYPYac3I-3D
  To manage Coverity Scan email notifications for "gedare at gwmail.gwu.edu",
click
https://u15810271.ct.sendgrid.net/ls/click?upn=HRESupC-2F2Czv4BOaCWWCy7my0P0qcxCbhZ31OYv50yped04pjJnmXOsUBtKYNIXxkxN7gn3yK5ofbuH1ptBFYw9YgpazuIaA-2BBUVKiHj8oUDwYWUynp42iaapm4KJU8XqWU01jaV7ANE1ZK33b9AxrNSft0QTNSkD2bLN6ho-2BnY-3DE-ws_NXfCUf1CLFYLbjXajJIgHlbL5qYn95oel6MvjPauKOZWRAeoPfG9R5Ut-2B0l1A5CB2NlyTs8n9wN-2FSyicx0tEXvXYGaGlLArYwAKrk-2B9Jr66dphmYP41ATiju2UCnJoYnvc2ZTjo8dyOLJxCeQsHoCOP862aab9fl1B0ammZrfyNIUSx8tg05QJP9bJRsN6zngYUWsWkGMJv3twh07snfhrXqd0NMPJLhSvujwj6My6A-3D
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210127/1c9803fa/attachment-0001.html>
