Fwd: New Defects reported by Coverity Scan for RTEMS
Gedare Bloom
gedare at rtems.org
Thu Jan 28 20:06:30 UTC 2021
fyi; I should see if I can get this put to the list directly...
---------- Forwarded message ---------
Date: Thu, Jan 28, 2021 at 11:59 AM
Subject: New Defects reported by Coverity Scan for RTEMS
To: <gedare at gwmail.gwu.edu>
Hi,
Please find the latest report on new defect(s) introduced to RTEMS found
with Coverity Scan.
7 new defect(s) introduced to RTEMS found with Coverity Scan.
3 defect(s), reported by Coverity Scan earlier, were marked fixed in the
recent build analyzed by Coverity Scan.
New defect(s) Reported-by: Coverity Scan
Showing 7 of 7 defect(s)
** CID 1472601: Null pointer dereferences (NULL_RETURNS)
/bsps/shared/ofw/ofw.c: 627 in rtems_ofw_get_reg()
________________________________________________________________________________________________________
*** CID 1472601: Null pointer dereferences (NULL_RETURNS)
621 nranges = len / sizeof(rtems_ofw_ranges);
622
623 offset = 0;
624 for (int i=0; i < nregs; i++) {
625 for (int j=0; j < nranges; j++) {
626
>>> Dereferencing "ptr", which is known to be "NULL".
627 range.parent_bus = fdt32_to_cpu(ptr[j].parent_bus);
628 range.child_bus = fdt32_to_cpu(ptr[j].child_bus);
629 range.size = fdt32_to_cpu(ptr[j].size);
630
631 if (buf[i].start >= range.child_bus &&
632 buf[i].start < range.child_bus + range.size) {
** CID 1472600: Memory - corruptions (USE_AFTER_FREE)
/bsps/shared/ofw/ofw.c: 377 in rtems_ofw_get_enc_prop_alloc()
*** CID 1472600: Memory - corruptions (USE_AFTER_FREE)
371 if (*buf == NULL) {
372 return -1;
373 }
374
375 if (rtems_ofw_get_enc_prop(node, propname, *buf, len) == -1) {
376 rtems_ofw_free(buf);
>>> Dereferencing freed pointer "buf".
377 *buf = NULL;
378 return -1;
379 }
380 }
381
382 return len;
** CID 1472599: Memory - corruptions (USE_AFTER_FREE)
/bsps/shared/ofw/ofw.c: 348 in rtems_ofw_get_prop_alloc_multi()
*** CID 1472599: Memory - corruptions (USE_AFTER_FREE)
342 if (*buf == NULL) {
343 return -1;
344 }
345
346 if (rtems_ofw_get_prop(node, propname, *buf, len) == -1) {
347 rtems_ofw_free(buf);
348 *buf = NULL;
349 return -1;
350 }
351 }
352
353 return (len / elsz);
** CID 1472598: Memory - corruptions (USE_AFTER_FREE)
/bsps/shared/ofw/ofw.c: 317 in rtems_ofw_get_prop_alloc()
*** CID 1472598: Memory - corruptions (USE_AFTER_FREE)
311 if (*buf == NULL) {
312 return -1;
313 }
314
315 if (rtems_ofw_get_prop(node, propname, *buf, len) == -1) {
316 rtems_ofw_free(buf);
317 *buf = NULL;
318 return -1;
319 }
320 }
321
322 return len;
** CID 1472597: Memory - corruptions (ARRAY_VS_SINGLETON)
*** CID 1472597: Memory - corruptions (ARRAY_VS_SINGLETON)
/bsps/shared/ofw/ofw.c: 510 in rtems_ofw_get_effective_phandle()
504
505 for (child = rtems_ofw_child(node); child != 0; child =
rtems_ofw_peer(child)) {
506 ref = rtems_ofw_get_effective_phandle(child, xref);
507 if (ref != -1)
508 return ref;
509
>>> Passing "&ref" to function "rtems_ofw_get_enc_prop" which uses it
as an array. This might corrupt or misinterpret adjacent memory locations.
510 if (rtems_ofw_get_enc_prop(child, "phandle", &ref, sizeof(ref))
== -1 &&
511 rtems_ofw_get_enc_prop(child, "ibm,phandle", &ref,
sizeof(ref)) == -1 &&
512 rtems_ofw_get_enc_prop(child, "linux,phandle", &ref,
sizeof(ref)) == -1
513 ) {
514 continue;
515 }
** CID 1472596: Memory - corruptions (USE_AFTER_FREE)
/bsps/shared/ofw/ofw.c: 408 in rtems_ofw_get_enc_prop_alloc_multi()
*** CID 1472596: Memory - corruptions (USE_AFTER_FREE)
402 if (*buf == NULL) {
403 return -1;
404 }
405
406 if (rtems_ofw_get_enc_prop(node, propname, *buf, len) == -1) {
407 rtems_ofw_free(buf);
408 *buf = NULL;
409 return -1;
410 }
411 }
412
413 return (len / elsz);
** CID 1472595: Memory - corruptions (ARRAY_VS_SINGLETON)
*** CID 1472595: Memory - corruptions (ARRAY_VS_SINGLETON)
/bsps/shared/ofw/ofw.c: 538 in rtems_ofw_xref_from_node()
532 }
533
534 phandle_t rtems_ofw_xref_from_node( phandle_t node )
535 {
536 phandle_t ref;
537
538 if (rtems_ofw_get_enc_prop(node, "phandle", &ref, sizeof(ref))
== -1 &&
539 rtems_ofw_get_enc_prop(node, "ibm,phandle", &ref,
540 rtems_ofw_get_enc_prop(node, "linux,phandle", &ref,
sizeof(ref)) == -1)
541 {
542 return node;
543 }
To view the defects in Coverity Scan visit,
https://u15810271.ct.sendgrid.net/ls/click?upn=HRESupC-2F2Czv4BOaCWWCy7my0P0qcxCbhZ31OYv50ypUUzi-2FdSNmuyRB7BEFT8xQ4-2B8hpujh0hTgQljRGId4Dg-3D-3D4rCS_NXfCUf1CLFYLbjXajJIgHlbL5qYn95oel6MvjPauKObfKXAxQ82kyzbTTgHGbdRzqrUhmhYWDX-2FyQdnWo5YnM-2FFUamWoMY-2BoKaEuqI2cyQv-2F-2Fhu0OTnekxXXUMfFLrMvhuvV4eI1uHLQGggvvsj-2FLfNGn-2BGPcv-2FG4UQSY4tky86S7nsFiHxxfqeXd31O6xy-2FCgLy2h3kVviDDWthwfms12-2BjQqk8Zt9jVBFB6z3QmdY-3D
To manage Coverity Scan email notifications for "gedare at gwmail.gwu.edu",
click
https://u15810271.ct.sendgrid.net/ls/click?upn=HRESupC-2F2Czv4BOaCWWCy7my0P0qcxCbhZ31OYv50yped04pjJnmXOsUBtKYNIXxkxN7gn3yK5ofbuH1ptBFYw9YgpazuIaA-2BBUVKiHj8oUDwYWUynp42iaapm4KJU8XqWU01jaV7ANE1ZK33b9AxrNSft0QTNSkD2bLN6ho-2BnY-3DliTr_NXfCUf1CLFYLbjXajJIgHlbL5qYn95oel6MvjPauKObfKXAxQ82kyzbTTgHGbdRz-2BKYfPnlg8v0lG2OqkZltGqoPujs4o3Ew0WTou9CIxoFc4RjvuFhkcXGRn3c7g6KmB509Izxa1pJ-2F-2FjZk3UcbB8IeOv8BL-2FA9BKCOzInvZG8-2BJhuSFCgnDMpdzFxT189-2FHmarweYa8ZFAFFgf29GheX05-2F2-2FArB0zn-2F7w52Pa2yo-3D
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210128/bb56b4e0/attachment.html>
