Buildbot failure in RTEMS on CHECK sparc/erc32 FreeBSD 10.1-STABLE GCC 7.3.0 POSIX
Thu Jan 28 05:44:42 UTC 2021
Hello,
On 28/01/2021 06:37, buildbot at rtems.org wrote:
> The Buildbot has detected a failed build on builder CHECK sparc/erc32 FreeBSD 10.1-STABLE GCC 7.3.0 POSIX while building rtems.
> Full details are available at:
>      https://buildbot.rtems.org/#builders/20/builds/440
> Buildbot URL: https://buildbot.rtems.org/
> Worker for this Build: build-1
> Build Reason: <unknown>
> Blamelist: Sebastian Huber <sebastian.huber at embedded-brains.de>
> BUILD FAILED: make (failure)
> Sincerely,
>   -The Buildbot
the Buildbot needs a tool chain update. It still uses GCC 7.5. For RTEMS
6, GCC 10 is required.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
