Buildbot failure in RTEMS on CHECK sparc/erc32 FreeBSD 10.1-STABLE GCC 7.3.0 POSIX
Thu Jan 28 05:49:58 UTC 2021
On 28/1/21 4:44 pm, Sebastian Huber wrote:
> Hello,
> On 28/01/2021 06:37, buildbot at rtems.org wrote:
>> The Buildbot has detected a failed build on builder CHECK sparc/erc32 FreeBSD
>> 10.1-STABLE GCC 7.3.0 POSIX while building rtems.
>> Full details are available at:
>>      https://buildbot.rtems.org/#builders/20/builds/440
>> Buildbot URL: https://buildbot.rtems.org/
>> Worker for this Build: build-1
>> Build Reason: <unknown>
>> Blamelist: Sebastian Huber <sebastian.huber at embedded-brains.de>
>> BUILD FAILED: make (failure)
>> Sincerely,
>>   -The Buildbot
> the Buildbot needs a tool chain update. It still uses GCC 7.5. For RTEMS 6, GCC
> 10 is required.
Please raise a ticket and assign it to Amar.
Thanks
