[PATCH 03/11] bsp/leon3: Fix incompatible function types
Sebastian Huber
Thu Jan 28 15:27:59 UTC 2021
This fix relates to a Coverity issue (PW.INCOMPATIBLE_PARAM).
bsps/sparc/leon3/clock/ckinit.c | 10 ++++++----
1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/bsps/sparc/leon3/clock/ckinit.c b/bsps/sparc/leon3/clock/ckinit.c
index bf0c506ec0..43e5f55ae5 100644
--- a/bsps/sparc/leon3/clock/ckinit.c
+++ b/bsps/sparc/leon3/clock/ckinit.c
@@ -130,10 +130,10 @@ static void leon3_tc_do_tick(void)
} while (0)
-#define Clock_driver_support_install_isr( _new ) \
- bsp_clock_handler_install(_new)
+#define Clock_driver_support_install_isr(isr) \
+ bsp_clock_handler_install(isr)
-static void bsp_clock_handler_install(rtems_isr *new)
+static void bsp_clock_handler_install(rtems_interrupt_handler isr)
rtems_status_code sc;
@@ -141,7 +141,7 @@ static void bsp_clock_handler_install(rtems_isr *new)
clkirq,
"Clock",
RTEMS_INTERRUPT_UNIQUE,
- new,
+ isr,
NULL
if (sc != RTEMS_SUCCESSFUL) {
@@ -234,6 +234,8 @@ static void leon3_clock_initialize(void)
#define Clock_driver_timecounter_tick() leon3_tc_do_tick()
+#define BSP_FEATURE_IRQ_EXTENSION
#include "../../../shared/dev/clock/clockimpl.h"
#endif
2.26.2
