[PATCH] bsps/shared/ofw: Fix coverity reported defects
Christian MAUDERER
christian.mauderer at embedded-brains.de
Fri Jan 29 08:17:14 UTC 2021
Hello Niteesh,
Am 29.01.21 um 07:33 schrieb Niteesh G. S.:
> Hello,
> https://lists.rtems.org/pipermail/devel/2021-January/064115.html
> <https://lists.rtems.org/pipermail/devel/2021-January/064115.html>
> I have fixed defects reported in the above thread except
> CID 1472595, 1472597 (ARRAY_VS_SINGLETON)
> Along with the buffer we also take the size of the buffer this makes
> sure that we don't read more than the buffer capacity.
> But coverity reports this as an defect how can I fix this?
Thanks for taking a look at these. Regarding the CID 1472595:
What Coverity doesn't like is the following:
You create a variable (phandle_t ref). You then pass the pointer of the
variable to the rtems_ofw_get_enc_prop in the pcell_t *buf parameter.
And rtems_ofw_get_enc_prop uses a buf[i] which might could be more than
0 if you ask Coverity. Coverity is most likely not intelligent enough to
understand the logic. I think it might be possible to suppress that
message by creating the variable with
phandle_t ref[1];
and adapting the following uses of that variable. But please double
check, that the code is correct when you do something like that. What
isn't mentioned in that defect: In rtems_ofw_get_enc_prop you pass the
buf to rtems_ofw_get_prop which uses a strncpy in line 201 to fill the
buffer. That is _very_ odd for an integer value and might lead to wrong
results.
Best regards
Christian
> Thanks,
> Niteesh.
> On Fri, Jan 29, 2021 at 11:48 AM G S Niteesh Babu <niteesh.gs at gmail.com
> <mailto:niteesh.gs at gmail.com>> wrote:
> Fixed use after free and null pointer dereference defects
> FIXES:
> 1) CID 1472601 (NULL_RETURNS)
> 2) CID 1472600 (USE_AFTER_FREE)
> 3) CID 1472599 (USE_AFTER_FREE)
> 4) CID 1472598 (USE_AFTER_FREE)
> 5) CID 1472596 (USE_AFTER_FREE)
> bsps/shared/ofw/ofw.c | 10 +++++-----
> 1 file changed, 5 insertions(+), 5 deletions(-)
> diff --git a/bsps/shared/ofw/ofw.c b/bsps/shared/ofw/ofw.c
> index 82924b2600..fa94bfbf05 100644
> --- a/bsps/shared/ofw/ofw.c
> +++ b/bsps/shared/ofw/ofw.c
> @@ -313,7 +313,7 @@ ssize_t rtems_ofw_get_prop_alloc(
> if (rtems_ofw_get_prop(node, propname, *buf, len) == -1) {
> - rtems_ofw_free(buf);
> + rtems_ofw_free(*buf);
> *buf = NULL;
> return -1;
> @@ -344,7 +344,7 @@ ssize_t rtems_ofw_get_prop_alloc_multi(
> *buf = NULL;
> return -1;
> @@ -373,7 +373,7 @@ ssize_t rtems_ofw_get_enc_prop_alloc(
> if (rtems_ofw_get_enc_prop(node, propname, *buf, len) == -1) {
> *buf = NULL;
> return -1;
> @@ -404,7 +404,7 @@ ssize_t rtems_ofw_get_enc_prop_alloc_multi(
> *buf = NULL;
> return -1;
> @@ -614,7 +614,7 @@ int rtems_ofw_get_reg(
> offset = rtems_fdt_phandle_to_offset(parent);
> ptr = fdt_getprop(fdtp, offset, "ranges", &len);
> - if (len < 0) {
> + if (ptr == NULL) {
> break;
> 2.17.1
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
