[PATCH v2] score: Use defines for Thread_Life_state
Sebastian Huber
Fri Jan 29 15:59:16 UTC 2021
Do not use an enum as a bit field. Document the state flags.
This fix relates to a Coverity issue (PW.MIXED_ENUM_TYPE).
cpukit/include/rtems/score/thread.h | 57 ++++++++++++++++++++++++-----
1 file changed, 47 insertions(+), 10 deletions(-)
diff --git a/cpukit/include/rtems/score/thread.h b/cpukit/include/rtems/score/thread.h
index 8785879184..ab59ab13e9 100644
--- a/cpukit/include/rtems/score/thread.h
+++ b/cpukit/include/rtems/score/thread.h
@@ -659,22 +659,59 @@ typedef struct {
} Thread_Action_control;
- * @brief Thread life states.
+ * @brief This type represents the thread life state.
- * The thread life states are orthogonal to the thread states used for
+ * The thread life state is orthogonal to the thread state used for
* synchronization primitives and blocking operations. They reflect the state
* changes triggered with thread restart and delete requests.
- * The individual state values must be a power of two to allow use of bit
+ * The individual state flags must be a power of two to allow use of bit
* operations to manipulate and evaluate the thread life state.
-typedef enum {
- THREAD_LIFE_PROTECTED = 0x1,
- THREAD_LIFE_RESTARTING = 0x2,
- THREAD_LIFE_TERMINATING = 0x4,
- THREAD_LIFE_CHANGE_DEFERRED = 0x8,
- THREAD_LIFE_DETACHED = 0x10
-} Thread_Life_state;
+typedef unsigned int Thread_Life_state;
+ * @brief Indicates that the thread life is protected.
+ * If this flag is set, then the thread restart or delete requests are deferred
+ * until the protection and deferred change flags are cleared. It is used by
+ * _Thread_Set_life_protection().
+#define THREAD_LIFE_PROTECTED 0x1U
+ * @brief Indicates that thread is restarting.
+ * If this flag is set, then a thread restart request is in pending. See
+ * _Thread_Restart_self() and _Thread_Restart_other().
+#define THREAD_LIFE_RESTARTING 0x2U
+ * @brief Indicates that thread is terminating.
+ * If this flag is set, then a thread termination request is in pending. See
+ * _Thread_Exit() and _Thread_Cancel().
+#define THREAD_LIFE_TERMINATING 0x4U
+ * @brief Indicates that thread life changes are deferred.
+ * pthread_setcanceltype().
+#define THREAD_LIFE_CHANGE_DEFERRED 0x8U
+ * @brief Indicates that thread is detached.
+ * If this flag is set, then the thread is detached. Detached threads do not
+ * wait during termination for other threads to join. See rtems_task_delete(),
+ * rtems_task_exit(), and pthread_detach().
+#define THREAD_LIFE_DETACHED 0x10U
* @brief Thread life control.
2.26.2
