[PATCH v2] score: Use defines for Thread_Life_state
Fri Jan 29 16:37:55 UTC 2021
looks good to me, thanks
On Fri, Jan 29, 2021 at 8:59 AM Sebastian Huber <
> Do not use an enum as a bit field.  Document the state flags.
> This fix relates to a Coverity issue (PW.MIXED_ENUM_TYPE).
>  cpukit/include/rtems/score/thread.h | 57 ++++++++++++++++++++++++-----
>  1 file changed, 47 insertions(+), 10 deletions(-)
> diff --git a/cpukit/include/rtems/score/thread.h
> b/cpukit/include/rtems/score/thread.h
> index 8785879184..ab59ab13e9 100644
> --- a/cpukit/include/rtems/score/thread.h
> +++ b/cpukit/include/rtems/score/thread.h
> @@ -659,22 +659,59 @@ typedef struct {
>  } Thread_Action_control;
> - * @brief Thread life states.
> + * @brief This type represents the thread life state.
> - * The thread life states are orthogonal to the thread states used for
> + * The thread life state is orthogonal to the thread state used for
>   * synchronization primitives and blocking operations.  They reflect the
> state
>   * changes triggered with thread restart and delete requests.
> - * The individual state values must be a power of two to allow use of bit
> + * The individual state flags must be a power of two to allow use of bit
>   * operations to manipulate and evaluate the thread life state.
> -typedef enum {
> -  THREAD_LIFE_PROTECTED = 0x1,
> -  THREAD_LIFE_RESTARTING = 0x2,
> -  THREAD_LIFE_TERMINATING = 0x4,
> -  THREAD_LIFE_CHANGE_DEFERRED = 0x8,
> -  THREAD_LIFE_DETACHED = 0x10
> -} Thread_Life_state;
> +typedef unsigned int Thread_Life_state;
> + * @brief Indicates that the thread life is protected.
> + * If this flag is set, then the thread restart or delete requests are
> deferred
> + * until the protection and deferred change flags are cleared.  It is
> used by
> + * _Thread_Set_life_protection().
> +#define THREAD_LIFE_PROTECTED 0x1U
> + * @brief Indicates that thread is restarting.
> + * If this flag is set, then a thread restart request is in pending. See
> + * _Thread_Restart_self() and _Thread_Restart_other().
> +#define THREAD_LIFE_RESTARTING 0x2U
> + * @brief Indicates that thread is terminating.
> + * If this flag is set, then a thread termination request is in pending.
> See
> + * _Thread_Exit() and _Thread_Cancel().
> +#define THREAD_LIFE_TERMINATING 0x4U
> + * @brief Indicates that thread life changes are deferred.
> deferred
> used by
> + * pthread_setcanceltype().
> +#define THREAD_LIFE_CHANGE_DEFERRED 0x8U
> + * @brief Indicates that thread is detached.
> + * If this flag is set, then the thread is detached.  Detached threads do
> not
> + * wait during termination for other threads to join.  See
> rtems_task_delete(),
> + * rtems_task_exit(), and pthread_detach().
> +#define THREAD_LIFE_DETACHED 0x10U
>   * @brief Thread life control.
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210129/dcc0c458/attachment-0001.html>
