[PATCH 00/11] Misc Coverity fixes
Fri Jan 29 16:38:42 UTC 2021
Just as a curiosity, it would be good to know what the private version
picks up that the public one does not.
On Thu, Jan 28, 2021 at 8:28 AM Sebastian Huber <
> Not all issues are related to:
> https://scan.coverity.com/projects/rtems
> Some are obtained by a private Coverity instance.
> Sebastian Huber (11):
>   score: Add comments and asserts for clarification
>   kern_tc.c: Remove unused code
>   bsp/leon3: Fix incompatible function types
>   score: Fix implicit type conversion
>   score: Simplify _MRSP_Wait_for_ownership()
>   bsp/leon3: Improve printk() support
>   score: Simplify _CORE_message_queue_Broadcast()
>   score: Remove superfluous type qualifier
>   libtest: Check return values with RTEMS_DEBUG
>   score: Remove double assignment
>   rtems: Mark value as used
>  bsps/sparc/leon3/clock/ckinit.c           | 10 ++-
>  bsps/sparc/leon3/console/printk_support.c | 92 +++++++++++++----------
>  cpukit/include/rtems/rtems/timerimpl.h    |  2 +-
>  cpukit/include/rtems/score/mrspimpl.h     | 13 ++--
>  cpukit/include/rtems/score/priorityimpl.h |  7 ++
>  cpukit/include/rtems/score/smpimpl.h      |  2 +-
>  cpukit/libtest/t-test-rtems-measure.c     | 60 +++++++++++----
>  cpukit/rtems/src/semrelease.c             |  1 +
>  cpukit/score/src/coremsgbroadcast.c       | 19 ++---
>  cpukit/score/src/kern_tc.c                |  6 --
>  cpukit/score/src/scheduleredfsmp.c        |  3 +-
>  11 files changed, 130 insertions(+), 85 deletions(-)
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210129/e97f9ddb/attachment.html>
