[PATCH 11/11] rtems: Mark value as used
Gedare Bloom
gedare at rtems.org
Fri Jan 29 16:44:20 UTC 2021
rest of these looked fine to me
On Thu, Jan 28, 2021 at 8:28 AM Sebastian Huber <
> This fix relates to a Coverity issue (UNUSED_VALUE).
> cpukit/rtems/src/semrelease.c | 1 +
> 1 file changed, 1 insertion(+)
> diff --git a/cpukit/rtems/src/semrelease.c b/cpukit/rtems/src/semrelease.c
> index c31f242a98..3a1f9671fe 100644
> --- a/cpukit/rtems/src/semrelease.c
> +++ b/cpukit/rtems/src/semrelease.c
> @@ -86,6 +86,7 @@ rtems_status_code rtems_semaphore_release( rtems_id id )
> status == STATUS_SUCCESSFUL
> || status == STATUS_MAXIMUM_COUNT_EXCEEDED
> + (void) status;
> status = STATUS_SUCCESSFUL;
> break;
> #if defined(RTEMS_SMP)
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210129/30ddd224/attachment.html>
