[PATCH] score: Use defines for Thread_Life_state
Peter Dufault dufault at hda.com
Fri Jan 29 17:33:56 UTC 2021
> On Jan 29, 2021, at 11:37 , Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Jan 29, 2021 at 9:03 AM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 29/01/2021 16:09, Joel Sherrill wrote:
> > On Fri, Jan 29, 2021 at 9:06 AM Gedare Bloom <gedare at rtems.org
> > <mailto:gedare at rtems.org>> wrote:
> >     On Fri, Jan 29, 2021 at 12:24 AM Sebastian Huber
> >     <mailto:sebastian.huber at embedded-brains.de>> wrote:
> >         Do not use an enum as a bit field.  Document the state flags.
> > Is this a new style rule that needs to be documented?
> Into which category would you put this? Language and Compiler?
> https://docs.rtems.org/branches/master/eng/coding-conventions.html
> Yes.
I use enums as bit fields a lot. I use them in conjunction with objects that are the same enum.
I avoid using #define.  In most situations you can't print them in a debugger and they imply restricted usage.
Is this an appropriate warning?  Does it always mean that the enum should be replaced with a #define?
If it doesn't always apply then the style should make it clear when it should apply.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
Type: application/pgp-signature
Desc: Message signed with OpenPGP
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210129/03e5e396/attachment.bin>
