[PATCH v2 2/2] score: Add _Thread_Get_objects_information()
Sebastian Huber
Fri Jan 29 18:01:21 UTC 2021
We do not need all the checks if we have a valid indentifier to a thread
class object.
Using the new _Thread_Get_objects_information() instead of the inline
function _Thread_Get_objects_information_by_id() avoids dead code since
the identifier in a thread control is always valid and the return NULL
path in _Thread_Get_objects_information_by_id() would be dead code. The
_Thread_Get_objects_information_by_id() should be an inline function
since it is used by _Thread_Get() and thus performance critical. Static
analyzers which cannot derive that the identifier in a thread control is
always valid, may find a potential NULL pointer access (or otherwise
find dead code).
The identifier in an object control is always valid, see
_Objects_Initialize_information() and _Objects_Extend_information().
Move _RTEMS_tasks_Free() to the only source file which calls this
function.
cpukit/include/rtems/rtems/tasksimpl.h | 16 ----------------
cpukit/include/rtems/score/threadimpl.h | 24 ++++++++++++++++++++++++
cpukit/rtems/src/taskconstruct.c | 8 ++++++++
cpukit/score/src/threadrestart.c | 12 ++++++------
4 files changed, 38 insertions(+), 22 deletions(-)
diff --git a/cpukit/include/rtems/rtems/tasksimpl.h b/cpukit/include/rtems/rtems/tasksimpl.h
index eac4647897..62a618b635 100644
--- a/cpukit/include/rtems/rtems/tasksimpl.h
+++ b/cpukit/include/rtems/rtems/tasksimpl.h
@@ -66,22 +66,6 @@ RTEMS_INLINE_ROUTINE Thread_Control *_RTEMS_tasks_Allocate(void)
_Objects_Allocate_unprotected( &_RTEMS_tasks_Information.Objects );
- * @brief Frees a task control block.
- * This routine frees a task control block to the
- * inactive chain of free task control blocks.
-RTEMS_INLINE_ROUTINE void _RTEMS_tasks_Free (
- Thread_Control *the_task
- _Objects_Free(
- _Objects_Get_information_id( the_task->Object.id ),
- &the_task->Object
* @brief Converts the RTEMS API priority to the corresponding SuperCore
* priority and validates it.
diff --git a/cpukit/include/rtems/score/threadimpl.h b/cpukit/include/rtems/score/threadimpl.h
index d5381c9871..e76f9c3972 100644
--- a/cpukit/include/rtems/score/threadimpl.h
+++ b/cpukit/include/rtems/score/threadimpl.h
@@ -846,6 +846,30 @@ RTEMS_INLINE_ROUTINE Objects_Information *_Thread_Get_objects_information_by_id(
return _Objects_Information_table[ the_api ][ 1 ];
+ * @brief Gets the thread object information of the thread.
+ * @param the_thread is the thread to get the thread object information.
+ * @return Returns the thread object information of the thread.
+RTEMS_INLINE_ROUTINE Thread_Information *_Thread_Get_objects_information(
+ Thread_Control *the_thread
+ size_t the_api;
+ Thread_Information *information;
+ the_api = (size_t) _Objects_Get_API( the_thread->Object.id );
+ _Assert( _Objects_Is_api_valid( the_api ) );
+ information = (Thread_Information *)
+ _Objects_Information_table[ the_api ][ 1 ];
+ _Assert( information != NULL );
+ return information;
* @brief Gets a thread by its identifier.
diff --git a/cpukit/rtems/src/taskconstruct.c b/cpukit/rtems/src/taskconstruct.c
index 6ff83a0b9c..d33a850d88 100644
--- a/cpukit/rtems/src/taskconstruct.c
+++ b/cpukit/rtems/src/taskconstruct.c
@@ -79,6 +79,14 @@ rtems_status_code rtems_task_construct(
return _RTEMS_tasks_Create( config, id, _RTEMS_tasks_Prepare_user_stack );
+static void _RTEMS_tasks_Free( Thread_Control *the_thread )
+ information = _Thread_Get_objects_information( the_thread );
+ _Objects_Free( &information->Objects, &the_thread->Object );
rtems_status_code _RTEMS_tasks_Create(
const rtems_task_config *config,
rtems_id *id,
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index b4204f7fbb..cf92e25a5d 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -130,16 +130,16 @@ static void _Thread_Add_to_zombie_chain( Thread_Control *the_thread )
static void _Thread_Make_zombie( Thread_Control *the_thread )
#if defined(RTEMS_SCORE_THREAD_ENABLE_RESOURCE_COUNT)
if ( _Thread_Owns_resources( the_thread ) ) {
_Internal_error( INTERNAL_ERROR_RESOURCE_IN_USE );
#endif
- _Objects_Close(
- _Objects_Get_information_id( the_thread->Object.id ),
- &the_thread->Object
+ _Objects_Close( &information->Objects, &the_thread->Object );
_Thread_Set_state( the_thread, STATES_ZOMBIE );
_Thread_queue_Extract_with_proxy( the_thread );
@@ -157,8 +157,7 @@ static void _Thread_Make_zombie( Thread_Control *the_thread )
static void _Thread_Free( Thread_Control *the_thread )
- Thread_Information *information = (Thread_Information *)
- _Objects_Get_information_id( the_thread->Object.id );
_User_extensions_Thread_delete( the_thread );
_User_extensions_Destroy_iterators( the_thread );
@@ -179,6 +178,7 @@ static void _Thread_Free( Thread_Control *the_thread )
#endif
#endif
_Freechain_Push(
&information->Thread_queue_heads.Free,
the_thread->Wait.spare_heads
2.26.2
