[PATCH] tester: Add Versal VCK190 eval board TFTP support
Thu Jul 1 15:27:14 UTC 2021
ok
On Thu, Jul 1, 2021 at 12:34 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
>  .../testing/bsps/xilinx_versal_vck190.ini     | 43 +++++++++++++++++++
>  1 file changed, 43 insertions(+)
>  create mode 100644 tester/rtems/testing/bsps/xilinx_versal_vck190.ini
> diff --git a/tester/rtems/testing/bsps/xilinx_versal_vck190.ini b/tester/rtems/testing/bsps/xilinx_versal_vck190.ini
> new file mode 100644
> index 0000000..3bdd6be
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/xilinx_versal_vck190.ini
> @@ -0,0 +1,43 @@
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2021 Chris Johns (chrisj at rtems.org)
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are met:
> +# 1. Redistributions of source code must retain the above copyright notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright notice,
> +# this list of conditions and the following disclaimer in the documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +# The Xilinx Zynq Zedboard and Microzed board connected via TFTP. The console
> +# is connected to a telnet tty device.
> +[xilinx_versal_vck190]
> +bsp                = xilinx_versal_vck190
> +arch               = aarch64
> +tester             = %{_rtscripts}/tftp.cfg
> +jobs               = 1
> +test_restarts      = 3
> +target_reset_regex = ^No ethernet found.*|^BOOTP broadcast 6.*|^.+complete\.+ TIMEOUT.*
> +target_start_regex = .* PSCI Power Domain Map:$|^U-Boot .*
> +requires           = target_on_command, target_off_command, target_reset_command, bsp_tty_dev
> 2.24.1
> devel mailing list
> devel at rtems.org
