GSoC - Code Formatting and Style Checking for RTEMS score
Ida Delphine
idadelm at gmail.com
Thu Jul 1 17:42:57 UTC 2021
Thank you. I will make changes accordingly.
On Thu, 1 Jul 2021, 5:31 pm Gedare Bloom, <gedare at rtems.org> wrote:
> Hi Ida,
> On Tue, Jun 29, 2021 at 1:11 PM Ida Delphine <idadelm at gmail.com> wrote:
> > Hello mentors,
> > Here is the code for my pre-commit hook script. How it works is by
> default, upon commiting it outputs a warning stating the number of style
> issues in case there are mismatches.
> > The user can trigger the strict mode which gives a more detailed output
> of the style issues by running adding the mode to the config file ( git
> config mode "strict") - will document this.
> > https://github.com/Idadelveloper/rtems/blob/master/hooks/pre-commit
> I made comments on your commit that added this:
> https://github.com/Idadelveloper/rtems/commit/6bfc4802d17b3aab260190d53467b750848f0002
> > I had already sent some screenshots here on how the outcome looks like.
> Will love to improve my code based on your feedback and get more
> suggestions.
> > On Mon, Jun 21, 2021 at 7:05 PM Gedare Bloom <gedare at rtems.org> wrote:
> >> On Sun, Jun 20, 2021 at 1:13 AM Ida Delphine <idadelm at gmail.com> wrote:
> >>> Hello everyone,
> >>> I updated the hooks script. About the modes, we have the default,
> "strict" and "nonstrict" (couldn't think of better names). With the default
> mode, it prints a warning specifying the number of style issues if any and
> aborts the commit. With the strict mode, it goes into more detail showing
> both the formatted and unformatted patch, the number of style issues, and
> aborts the commit. In the non-strict mode, it simply displays the warning
> with the style issues and the commit happens.
> >>> The default mode basically happens when you run
> >>>> git commit -m "Commit message"
> >>> The best method I could find to pass arguments to a script was via
> environment variables. So the nonstrict mode applies when you run
> >>>> STYLEMODE=nonstrict git commit -m "Commit message"
> >>> The strict mode applies when you run
> >>>> STYLEMODE=strict git commit -m "Commit message"
> >> What are the possible options to pass arguments? (Maybe, a blog post
> :)) Reading from a git-config file would be better than environment
> variables.
> >> It might be better to share screenshots by a link (e.g., a blog post
> :)) to avoid hitting the mailing list attachment limits.
> >> Gedare
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210701/a9be02f4/attachment-0001.html>
