GSoC - Code Formatting and Style Checking for RTEMS score
Ida Delphine idadelm at gmail.com
Sat Jul 3 23:40:01 UTC 2021
Hello mentors,
I got some feedback and I have improved my code based on it -
https://github.com/Idadelveloper/rtems/blob/master/hooks/pre-commit
Will love to get some more feedback and ways to make it look better.
And is it okay I start working on its documentation though it hasn't been
approved yet?
Cheers,
Ida
On Thu, Jul 1, 2021 at 6:42 PM Ida Delphine <idadelm at gmail.com> wrote:
> Thank you. I will make changes accordingly.
> On Thu, 1 Jul 2021, 5:31 pm Gedare Bloom, <gedare at rtems.org> wrote:
>> Hi Ida,
>> On Tue, Jun 29, 2021 at 1:11 PM Ida Delphine <idadelm at gmail.com> wrote:
>> > Hello mentors,
>> > Here is the code for my pre-commit hook script. How it works is by
>> default, upon commiting it outputs a warning stating the number of style
>> issues in case there are mismatches.
>> > The user can trigger the strict mode which gives a more detailed output
>> of the style issues by running adding the mode to the config file ( git
>> config mode "strict") - will document this.
>> I made comments on your commit that added this:
>> https://github.com/Idadelveloper/rtems/commit/6bfc4802d17b3aab260190d53467b750848f0002
>> > I had already sent some screenshots here on how the outcome looks like.
>> Will love to improve my code based on your feedback and get more
>> suggestions.
>> > On Mon, Jun 21, 2021 at 7:05 PM Gedare Bloom <gedare at rtems.org> wrote:
>> >> On Sun, Jun 20, 2021 at 1:13 AM Ida Delphine <idadelm at gmail.com>
>> wrote:
>> >>> Hello everyone,
>> >>> I updated the hooks script. About the modes, we have the default,
>> "strict" and "nonstrict" (couldn't think of better names). With the default
>> mode, it prints a warning specifying the number of style issues if any and
>> aborts the commit. With the strict mode, it goes into more detail showing
>> both the formatted and unformatted patch, the number of style issues, and
>> aborts the commit. In the non-strict mode, it simply displays the warning
>> with the style issues and the commit happens.
>> >>> The default mode basically happens when you run
>> >>>> git commit -m "Commit message"
>> >>> The best method I could find to pass arguments to a script was via
>> environment variables. So the nonstrict mode applies when you run
>> >>>> STYLEMODE=nonstrict git commit -m "Commit message"
>> >>> The strict mode applies when you run
>> >>>> STYLEMODE=strict git commit -m "Commit message"
>> >> What are the possible options to pass arguments? (Maybe, a blog post
>> :)) Reading from a git-config file would be better than environment
>> variables.
>> >> It might be better to share screenshots by a link (e.g., a blog post
>> :)) to avoid hitting the mailing list attachment limits.
>> >> Gedare
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210704/1391fa96/attachment.html>
