[PATCH] bsps/sparc: Improve interrupt affinity support
Sebastian Huber
Fri Jul 2 08:56:13 UTC 2021
Fully support the interrupt extension API to set/get the interrupt affinity.
Remove LEON3_irq_to_cpu which defined the interrupt to processor mapping in a
BSP-specific way.
Update #3269.
bsps/sparc/erc32/start/bspstart.c | 18 ++++
bsps/sparc/leon2/start/bspstart.c | 19 +++++
bsps/sparc/leon3/include/bsp.h | 11 ---
bsps/sparc/leon3/start/bspsmp.c | 22 +++--
bsps/sparc/leon3/start/eirq.c | 133 +++++++++++++++++++++++++----
bsps/sparc/shared/irq/irq-shared.c | 46 ++--------
6 files changed, 171 insertions(+), 78 deletions(-)
diff --git a/bsps/sparc/erc32/start/bspstart.c b/bsps/sparc/erc32/start/bspstart.c
index 1979c68308..73ec48de80 100644
--- a/bsps/sparc/erc32/start/bspstart.c
+++ b/bsps/sparc/erc32/start/bspstart.c
@@ -15,6 +15,24 @@
#include <bsp/irq-generic.h>
#include <rtems/sysinit.h>
+rtems_status_code bsp_interrupt_facility_initialize(void)
+ /* Nothing to do */
+ return RTEMS_SUCCESSFUL;
+void bsp_interrupt_vector_enable(rtems_vector_number vector)
+ bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
+ BSP_Cpu_Unmask_interrupt(vector, 0);
+void bsp_interrupt_vector_disable(rtems_vector_number vector)
+ BSP_Cpu_Mask_interrupt(vector, 0);
* Initialize shared interrupt handling, must be done after IRQ controller has
* been found and initialized.
diff --git a/bsps/sparc/leon2/start/bspstart.c b/bsps/sparc/leon2/start/bspstart.c
index e90cfad5a8..427896ba6b 100644
--- a/bsps/sparc/leon2/start/bspstart.c
+++ b/bsps/sparc/leon2/start/bspstart.c
@@ -27,6 +27,7 @@
#include <bsp.h>
#include <bsp/bootcard.h>
+#include <bsp/irq-generic.h>
@@ -102,6 +103,24 @@ struct drvmgr_bus_res leon2_amba_res __attribute__((weak)) =
#endif /* RTEMS_DRVMGR_STARTUP */
* Called just before drivers are initialized. Is used to initialize shared
* interrupt handling.
diff --git a/bsps/sparc/leon3/include/bsp.h b/bsps/sparc/leon3/include/bsp.h
index cb08764eae..850220d70d 100644
--- a/bsps/sparc/leon3/include/bsp.h
+++ b/bsps/sparc/leon3/include/bsp.h
@@ -214,17 +214,6 @@ extern void BSP_shared_interrupt_mask(int irq);
extern const unsigned char LEON3_mp_irq;
#endif
-#ifdef RTEMS_SMP
-/* Weak table used to implement static interrupt CPU affinity in a SMP
- * configuration. The array index is the interrupt to be looked up, and
- * the array[INTERRUPT] content is the CPU number relative to boot CPU
- * index that will be servicing the interrupts from the IRQ source. The
- * default is to let the first CPU (the boot cpu) to handle all
- * interrupts (all zeros).
-extern const unsigned char LEON3_irq_to_cpu[32];
-#endif
/* Common driver build-time configurations. On small systems undefine
* [DRIVER]_INFO_AVAIL to avoid info routines get dragged in. It is good
* for debugging and printing information about the system, but makes the
diff --git a/bsps/sparc/leon3/start/bspsmp.c b/bsps/sparc/leon3/start/bspsmp.c
index f2749bfa06..1c72027ebf 100644
--- a/bsps/sparc/leon3/start/bspsmp.c
+++ b/bsps/sparc/leon3/start/bspsmp.c
@@ -16,6 +16,7 @@
#include <bsp.h>
#include <bsp/fatal.h>
+#include <bsp/irq.h>
#include <leon.h>
#include <rtems/bspIo.h>
@@ -38,8 +39,6 @@ static void bsp_inter_processor_interrupt( void *arg )
void bsp_start_on_secondary_processor(Per_CPU_Control *cpu_self)
- uint32_t cpu_index_self;
* If data cache snooping is not enabled we terminate using BSP_fatal_exit()
* instead of bsp_fatal(). This is done since the latter function tries to
@@ -49,19 +48,20 @@ void bsp_start_on_secondary_processor(Per_CPU_Control *cpu_self)
if ( !leon3_data_cache_snooping_enabled() )
BSP_fatal_exit( LEON3_FATAL_INVALID_CACHE_CONFIG_SECONDARY_PROCESSOR );
- /* Unmask IPI interrupts at Interrupt controller for this CPU */
- cpu_index_self = _Per_CPU_Get_index(cpu_self);
- LEON3_IrqCtrl_Regs->mask[cpu_index_self] |= 1U << LEON3_mp_irq;
_SMP_Start_multitasking_on_secondary_processor(cpu_self);
static void leon3_install_inter_processor_interrupt( void )
rtems_status_code sc;
+ rtems_vector_number irq;
+ irq = LEON3_mp_irq;
+ bsp_interrupt_set_affinity( irq, _SMP_Get_online_processors() );
sc = rtems_interrupt_handler_install(
- LEON3_mp_irq,
+ irq,
"IPI",
RTEMS_INTERRUPT_SHARED,
bsp_inter_processor_interrupt,
@@ -75,10 +75,6 @@ uint32_t _CPU_SMP_Initialize( void )
bsp_fatal( LEON3_FATAL_INVALID_CACHE_CONFIG_MAIN_PROCESSOR );
-#if !defined(RTEMS_DRVMGR_STARTUP)
- leon3_install_inter_processor_interrupt();
-#endif
return leon3_get_cpu_count(LEON3_IrqCtrl_Regs);
@@ -97,7 +93,9 @@ void _CPU_SMP_Finalize_initialization( uint32_t cpu_count )
(void) cpu_count;
- /* Nothing to do */
+#if !defined(RTEMS_DRVMGR_STARTUP)
+ leon3_install_inter_processor_interrupt();
+#endif
void _CPU_SMP_Prepare_start_multitasking( void )
diff --git a/bsps/sparc/leon3/start/eirq.c b/bsps/sparc/leon3/start/eirq.c
index e3ae5b1a4d..84e81a90a4 100644
--- a/bsps/sparc/leon3/start/eirq.c
+++ b/bsps/sparc/leon3/start/eirq.c
@@ -1,6 +1,8 @@
* GRLIB/LEON3 extended interrupt controller
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
* COPYRIGHT (c) 2011
* Aeroflex Gaisler
@@ -39,42 +41,141 @@ bool bsp_interrupt_is_valid_vector(rtems_vector_number vector)
return vector <= BSP_INTERRUPT_VECTOR_MAX_STD;
-void bsp_interrupt_set_affinity(
- rtems_vector_number vector,
- const Processor_mask *affinity
+#if defined(RTEMS_SMP)
+Processor_mask leon3_interrupt_affinities[BSP_INTERRUPT_VECTOR_MAX_STD + 1];
+#endif
+ Processor_mask affinity;
+ size_t i;
+ _Processor_mask_From_index(&affinity, rtems_scheduler_get_processor());
+ for (i = 0; i < RTEMS_ARRAY_SIZE(leon3_interrupt_affinities); ++i) {
+ leon3_interrupt_affinities[i] = affinity;
+#endif
+static void leon3_interrupt_vector_enable(rtems_vector_number vector)
- uint32_t unmasked = 0;
- uint32_t cpu_count = rtems_scheduler_get_processor_maximum();
uint32_t cpu_index;
+ uint32_t cpu_count;
+ uint32_t bit;
+ uint32_t unmasked;
+ cpu_count = rtems_scheduler_get_processor_maximum();
+ affinity = leon3_interrupt_affinities[vector];
+ bit = 1U << vector;
+ unmasked = 0;
for (cpu_index = 0; cpu_index < cpu_count; ++cpu_index) {
- if (_Processor_mask_Is_set(affinity, cpu_index)) {
- BSP_Cpu_Unmask_interrupt(vector, cpu_index);
+ uint32_t mask;
+ mask = LEON3_IrqCtrl_Regs->mask[cpu_index];
+ if (_Processor_mask_Is_set(&affinity, cpu_index)) {
++unmasked;
+ mask |= bit;
+ } else {
+ mask &= ~bit;
+ LEON3_IrqCtrl_Regs->mask[cpu_index] = mask;
if (unmasked > 1) {
- LEON_Enable_interrupt_broadcast(vector);
+ LEON3_IrqCtrl_Regs->bcast |= bit;
} else {
- LEON_Disable_interrupt_broadcast(vector);
+ LEON3_IrqCtrl_Regs->bcast &= ~bit;
+#endif
-void bsp_interrupt_get_affinity(
+ rtems_interrupt_lock_context lock_context;
+ LEON3_IRQCTRL_ACQUIRE(&lock_context);
+ leon3_interrupt_vector_enable(vector);
+ LEON3_IRQCTRL_RELEASE(&lock_context);
+#else
+ BSP_Cpu_Unmask_interrupt(vector, _LEON3_Get_current_processor());
+#endif
+ uint32_t bit;
+ uint32_t cpu_index;
+ for (cpu_index = 0; cpu_index < cpu_count; ++cpu_index) {
+ LEON3_IrqCtrl_Regs->mask[cpu_index] &= ~bit;
+#else
+ BSP_Cpu_Mask_interrupt(vector, _LEON3_Get_current_processor());
+#endif
+void bsp_interrupt_set_affinity(
- Processor_mask *affinity
+ const Processor_mask *affinity
uint32_t cpu_index;
+ uint32_t bit;
- _Processor_mask_Zero(affinity);
+ leon3_interrupt_affinities[vector] = *affinity;
+ * If the interrupt is enabled on at least one processor, then re-enable it
+ * using the new affinity.
- if (!BSP_Cpu_Is_interrupt_masked(vector, cpu_index)) {
- _Processor_mask_Set(affinity, cpu_index);
+ if ((LEON3_IrqCtrl_Regs->mask[cpu_index] & bit) != 0) {
+ break;
+void bsp_interrupt_get_affinity(
+ rtems_vector_number vector,
+ Processor_mask *affinity
+ *affinity = leon3_interrupt_affinities[vector];
+#endif
diff --git a/bsps/sparc/shared/irq/irq-shared.c b/bsps/sparc/shared/irq/irq-shared.c
index a127ab64c2..329d47b6a8 100644
--- a/bsps/sparc/shared/irq/irq-shared.c
+++ b/bsps/sparc/shared/irq/irq-shared.c
@@ -8,54 +8,22 @@
-#include <rtems.h>
#include <bsp.h>
-#include <bsp/irq-generic.h>
-#if defined(RTEMS_SMP) && defined(LEON3)
-/* Interrupt to CPU map. Default to CPU0 since in BSS. */
-const unsigned char LEON3_irq_to_cpu[32] __attribute__((weak));
-/* On SMP use map table above relative to SMP Boot CPU (normally CPU0) */
-static inline int bsp_irq_cpu(int irq)
- /* protect from bad user configuration, default to boot cpu */
- if (rtems_configuration_get_maximum_processors() <= LEON3_irq_to_cpu[irq])
- return LEON3_Cpu_Index;
- else
- return LEON3_Cpu_Index + LEON3_irq_to_cpu[irq];
-#else
-/* when not SMP the local CPU is returned */
-#ifdef LEON3
+ bsp_interrupt_get_affinity((rtems_vector_number) irq, &affinity);
+ return (int) _Processor_mask_Find_last_set(&affinity);
+#elif defined(LEON3)
return _LEON3_Get_current_processor();
#else
return 0;
#endif
-#endif
-/* Callback from bsp_interrupt_initialize() */
-rtems_status_code bsp_interrupt_facility_initialize(void)
- return RTEMS_SUCCESSFUL;
-void bsp_interrupt_vector_enable(rtems_vector_number vector)
- int irq = (int)vector;
- bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
- BSP_Cpu_Unmask_interrupt(irq, bsp_irq_cpu(irq));
-void bsp_interrupt_vector_disable(rtems_vector_number vector)
- BSP_Cpu_Mask_interrupt(irq, bsp_irq_cpu(irq));
2.26.2
