[PATCH] aarch64: improve start code for aarch32 mode
Gedare Bloom
gedare at rtems.org
Fri Jul 2 13:49:11 UTC 2021
On Fri, Jul 2, 2021 at 6:45 AM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> I think there is a misunderstanding here as to what ILP32 is. ILP32 is
> still AArch64 code, just running with a ARMv7-compatible data model
> (pointers, ints, and longs are all 32-bit). AArch32 is literally ARMv7
> code. The ILP32 flag should not set the AArch32 flag in SPSR_EL3.
I see, there is indeed a misunderstanding. Thanks for that
clarification, I had it in my head that ILP32 was meant to be aarch32
mode for some reason. Then we don't need this patch.
> Kinsey
> On 7/1/2021 17:35, Gedare Bloom wrote:
> > bsps/aarch64/shared/start/start.S | 31 ++++++++++++++++++++++++++++---
> > 1 file changed, 28 insertions(+), 3 deletions(-)
> > diff --git a/bsps/aarch64/shared/start/start.S b/bsps/aarch64/shared/start/start.S
> > index f4c39dacdf..f47625ef99 100644
> > --- a/bsps/aarch64/shared/start/start.S
> > +++ b/bsps/aarch64/shared/start/start.S
> > @@ -107,30 +107,43 @@ _start:
> > _el3_start:
> > /* Drop from EL3 to EL2 */
> > + msr CPTR_EL3, XZR
> > /* Initialize HCR_EL2 and SCTLR_EL2 */
> > msr HCR_EL2, XZR
> > msr SCTLR_EL2, XZR
> > /* Set EL2 Execution state via SCR_EL3 */
> > mrs x0, SCR_EL3
> > +#ifdef AARCH64_MULTILIB_ARCH_V8_ILP32
> > + bic x0, x0, #(1<<10)
> > +#else
> > /* Set EL2 to AArch64 */
> > orr x0, x0, #(1<<10)
> > -#ifdef AARCH64_IS_NONSECURE
> > +#endif
> > +#if defined(AARCH64_IS_NONSECURE)
> > /* Set EL1 to NS */
> > orr x0, x0, #1
> > #endif
> > msr SCR_EL3, x0
> > /* set EL2h mode for eret */
> > mov x0, #0b01001
> > #else
> > + /* set EL1h mode for eret */
> > mov x0, #0b00101
> > #endif
> > +#if defined(AARCH64_MULTILIB_ARCH_V8_ILP32)
> > + /* set aarch32 mode */
> > + orr x0, x0, #(1<<4)
> > +#endif
> > msr SPSR_EL3, x0
> > /* Set EL2 entry point */
> > adr x0, _el2_start
> > #else
> > adr x0, _el1_start
> > @@ -143,8 +156,12 @@ _el2_start:
> > /* Configure HCR_EL2 */
> > mrs x0, HCR_EL2
> > +#ifndef AARCH64_MULTILIB_ARCH_V8_ILP32
> > /* Set EL1 Execution state to AArch64 */
> > orr x0, x0, #(1<<31)
> > +#endif
> > /* Disable ID traps */
> > bic x0, x0, #(1<<15)
> > bic x0, x0, #(1<<16)
> > @@ -152,8 +169,16 @@ _el2_start:
> > bic x0, x0, #(1<<18)
> > msr HCR_EL2, x0
> > + /* Disable coprocessor traps */
> > + msr CPTR_EL2, XZR
> > + msr HSTR_EL2, XZR
> > /* Set to EL1h mode for eret */
> > mov x0, #0b00101
> > +#endif
> > msr SPSR_EL2, x0
> > /* Set EL1 entry point */
> devel mailing list
> devel at rtems.org
