[PATCH] aarch64: improve start code for aarch32 mode
    Kinsey Moore
    kinsey.moore at oarcorp.com
    Fri Jul  2 12:45:24 UTC 2021
I think there is a misunderstanding here as to what ILP32 is. ILP32 is
still AArch64 code, just running with a ARMv7-compatible data model
(pointers, ints, and longs are all 32-bit). AArch32 is literally ARMv7
code. The ILP32 flag should not set the AArch32 flag in SPSR_EL3.
Kinsey
On 7/1/2021 17:35, Gedare Bloom wrote:
>   bsps/aarch64/shared/start/start.S | 31 ++++++++++++++++++++++++++++---
>   1 file changed, 28 insertions(+), 3 deletions(-)
> diff --git a/bsps/aarch64/shared/start/start.S b/bsps/aarch64/shared/start/start.S
> index f4c39dacdf..f47625ef99 100644
> --- a/bsps/aarch64/shared/start/start.S
> +++ b/bsps/aarch64/shared/start/start.S
> @@ -107,30 +107,43 @@ _start:
>   _el3_start:
>     /* Drop from EL3 to EL2 */
> +  msr CPTR_EL3, XZR
>     /* Initialize HCR_EL2 and SCTLR_EL2 */
>     msr HCR_EL2, XZR
>     msr SCTLR_EL2, XZR
>     /* Set EL2 Execution state via SCR_EL3 */
>     mrs x0, SCR_EL3
> +#ifdef AARCH64_MULTILIB_ARCH_V8_ILP32
> +  bic x0, x0, #(1<<10)
> +#else
>     /* Set EL2 to AArch64 */
>     orr x0, x0, #(1<<10)
> -#ifdef AARCH64_IS_NONSECURE
> +#endif
> +#if defined(AARCH64_IS_NONSECURE)
>     /* Set EL1 to NS */
>     orr x0, x0, #1
>   #endif
>     msr SCR_EL3, x0
>     /* set EL2h mode for eret */
>     mov x0, #0b01001
>   #else
> +  /* set EL1h mode for eret */
>     mov x0, #0b00101
>   #endif
> +#if defined(AARCH64_MULTILIB_ARCH_V8_ILP32)
> +  /* set aarch32 mode */
> +  orr x0, x0, #(1<<4)
> +#endif
>     msr SPSR_EL3, x0
>     /* Set EL2 entry point */
>     adr x0, _el2_start
>   #else
>     adr x0, _el1_start
> @@ -143,8 +156,12 @@ _el2_start:
>     /* Configure HCR_EL2 */
>     mrs x0, HCR_EL2
> +#ifndef AARCH64_MULTILIB_ARCH_V8_ILP32
>     /* Set EL1 Execution state to AArch64 */
>     orr x0, x0, #(1<<31)
> +#endif
>     /* Disable ID traps */
>     bic x0, x0, #(1<<15)
>     bic x0, x0, #(1<<16)
> @@ -152,8 +169,16 @@ _el2_start:
>     bic x0, x0, #(1<<18)
>     msr HCR_EL2, x0
> +  /* Disable coprocessor traps */
> +  msr CPTR_EL2, XZR
> +  msr HSTR_EL2, XZR
>     /* Set to EL1h mode for eret */
>     mov x0, #0b00101
> +#endif
>     msr SPSR_EL2, x0
>     /* Set EL1 entry point */
