Throughput/Goodput analysis on RTEMS
Christian Mauderer oss at c-mauderer.de
Fri Jul 2 16:51:52 UTC 2021
Hello Vijay,
On 01/07/2021 22:16, Vijay Kumar Banerjee wrote:
> Hi Kinsey,
> On Thu, Jul 1, 2021 at 12:57 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
>> On 7/1/2021 13:40, Vijay Kumar Banerjee wrote:
>>> Hi all,
>>> I'm planning to do a throughput analysis on the RTEMS network stacks
>>> and I'm looking for some suggestions on the tools/applications for
>>> that if anyone has done something like that before.
>> Stephen Clark has recently added TTCP tests/commands to LibBSD which I
>> think would be a great starting point.
> Thanks for the point! It looks interesting and I'll try it out.
If GPL is no problem (which shouldn't be the case for a specific
throughput test application) you could also take a look at nuttcp.
That's basically a fork of a fork of ttcp. It might has some new
features that are not there in the original and quite old ttcp.
Beneath the ttcp family, there is also iperf (2 or 3) which has a BSD
license. Note that despite iperf2 and iperf3 are named similar, they are
both different projects and both are actively maintained.
Best regards
Christian
> Best regards,
> Vijay
>> Kinsey
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
