Throughput/Goodput analysis on RTEMS
Vijay Kumar Banerjee
vijay at rtems.org
Fri Jul 2 23:43:50 UTC 2021
On Fri, Jul 2, 2021 at 10:51 AM Christian Mauderer <oss at c-mauderer.de> wrote:
> Hello Vijay,
> On 01/07/2021 22:16, Vijay Kumar Banerjee wrote:
> > Hi Kinsey,
> > On Thu, Jul 1, 2021 at 12:57 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> >> On 7/1/2021 13:40, Vijay Kumar Banerjee wrote:
> >>> Hi all,
> >>> I'm planning to do a throughput analysis on the RTEMS network stacks
> >>> and I'm looking for some suggestions on the tools/applications for
> >>> that if anyone has done something like that before.
> >> Stephen Clark has recently added TTCP tests/commands to LibBSD which I
> >> think would be a great starting point.
> > Thanks for the point! It looks interesting and I'll try it out.
> If GPL is no problem (which shouldn't be the case for a specific
> throughput test application) you could also take a look at nuttcp.
> That's basically a fork of a fork of ttcp. It might has some new
> features that are not there in the original and quite old ttcp.
Thanks Christian, I tried ttcp and nuttcp on Linux and this looks
great. GPL is certainly not a problem in our use case, so nuttcp is a
good idea as well.
> Beneath the ttcp family, there is also iperf (2 or 3) which has a BSD
> license. Note that despite iperf2 and iperf3 are named similar, they are
> both different projects and both are actively maintained.
Thanks. I haven't checked iperf2/3 yet, but I will certainly give it a shot.
Best regards,
Vijay
> Best regards
> Christian
> > Best regards,
> > Vijay
> >> Kinsey
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
