[PATCH rtems-libbsd 0/4] Beagle BSP: USB Template Driver for CDC Ethernet
Husni Faiz ahamedhusni73 at gmail.com
Tue Jul 6 17:00:30 UTC 2021
This set of patches import the drivers from freebsd and
configures it for the beagle bsp.
Github Branch for the commits
https://github.com/drac98/rtems-libbsd/commits/usb-cdce
Husni Faiz (4):
  usb_template:Import CDC Ethernet
  usb_template: Configure template driver only for CDC Ethernet
  nexus-devices: Include CDC Ethernet for Beagle
  libbsd.py: add usb template files
 buildset/default.ini                          |    1 +
 buildset/minimal.ini                          |    3 +-
 freebsd/sys/dev/usb/template/usb_template.c   | 1493 +++++++++++++++++
 freebsd/sys/dev/usb/template/usb_template.h   |  130 ++
 .../sys/dev/usb/template/usb_template_cdce.c  |  355 ++++
 freebsd/sys/dev/usb/usb_device.c              |    4 +-
 libbsd.py                                     |   25 +
 rtemsbsd/include/bsp/nexus-devices.h          |    5 +
 .../include/machine/rtems-bsd-nexus-bus.h     |   17 +
 9 files changed, 2030 insertions(+), 3 deletions(-)
 create mode 100644 freebsd/sys/dev/usb/template/usb_template.c
 create mode 100644 freebsd/sys/dev/usb/template/usb_template.h
 create mode 100644 freebsd/sys/dev/usb/template/usb_template_cdce.c
2.25.1
