[PATCH rtems-libbsd 1/4] usb_template:Import CDC Ethernet
Husni Faiz ahamedhusni73 at gmail.com
Tue Jul 6 17:00:31 UTC 2021
Signed-off-by: Husni Faiz <ahamedhusni73 at gmail.com>
 freebsd/sys/dev/usb/template/usb_template.c   | 1489 +++++++++++++++++
 freebsd/sys/dev/usb/template/usb_template.h   |  130 ++
 .../sys/dev/usb/template/usb_template_cdce.c  |  355 ++++
 3 files changed, 1974 insertions(+)
 create mode 100644 freebsd/sys/dev/usb/template/usb_template.c
 create mode 100644 freebsd/sys/dev/usb/template/usb_template.h
 create mode 100644 freebsd/sys/dev/usb/template/usb_template_cdce.c
diff --git a/freebsd/sys/dev/usb/template/usb_template.c b/freebsd/sys/dev/usb/template/usb_template.c
new file mode 100644
index 00000000..0650da15
--- /dev/null
+++ b/freebsd/sys/dev/usb/template/usb_template.c
@@ -0,0 +1,1489 @@
+#include <machine/rtems-bsd-kernel-space.h>
+/* $FreeBSD$ */
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright (c) 2007 Hans Petter Selasky. All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * This file contains sub-routines to build up USB descriptors from
+ * USB templates.
+#ifdef USB_GLOBAL_INCLUDE_FILE
+#include USB_GLOBAL_INCLUDE_FILE
+#else
+#include <sys/stdint.h>
+#include <sys/stddef.h>
+#include <sys/param.h>
+#include <sys/queue.h>
+#include <sys/types.h>
+#include <sys/systm.h>
+#include <sys/kernel.h>
+#include <sys/bus.h>
+#include <sys/module.h>
+#include <sys/lock.h>
+#include <sys/mutex.h>
+#include <sys/condvar.h>
+#include <sys/sysctl.h>
+#include <sys/sx.h>
+#include <rtems/bsd/sys/unistd.h>
+#include <sys/callout.h>
+#include <sys/malloc.h>
+#include <sys/priv.h>
+#include <dev/usb/usb.h>
+#include <dev/usb/usb_ioctl.h>
+#include <dev/usb/usbdi.h>
+#include <dev/usb/usbdi_util.h>
+#include <rtems/bsd/local/usbdevs.h>
+#include <dev/usb/usb_cdc.h>
+#include <dev/usb/usb_core.h>
+#include <dev/usb/usb_dynamic.h>
+#include <dev/usb/usb_busdma.h>
+#include <dev/usb/usb_process.h>
+#include <dev/usb/usb_device.h>
+#include <dev/usb/usb_util.h>
+#define	USB_DEBUG_VAR usb_debug
+#include <dev/usb/usb_debug.h>
+#include <dev/usb/usb_controller.h>
+#include <dev/usb/usb_bus.h>
+#include <dev/usb/usb_request.h>
+#include <dev/usb/template/usb_template.h>
+#endif			/* USB_GLOBAL_INCLUDE_FILE */
+MODULE_DEPEND(usb_template, usb, 1, 1, 1);
+MODULE_VERSION(usb_template, 1);
+/* function prototypes */
+static int	sysctl_hw_usb_template_power(SYSCTL_HANDLER_ARGS);
+static void	usb_make_raw_desc(struct usb_temp_setup *, const uint8_t *);
+static void	usb_make_endpoint_desc(struct usb_temp_setup *,
+		    const struct usb_temp_endpoint_desc *);
+static void	usb_make_interface_desc(struct usb_temp_setup *,
+		    const struct usb_temp_interface_desc *);
+static void	usb_make_config_desc(struct usb_temp_setup *,
+		    const struct usb_temp_config_desc *);
+static void	usb_make_device_desc(struct usb_temp_setup *,
+		    const struct usb_temp_device_desc *);
+static uint8_t	usb_hw_ep_match(const struct usb_hw_ep_profile *, uint8_t,
+		    uint8_t);
+static uint8_t	usb_hw_ep_find_match(struct usb_hw_ep_scratch *,
+		    struct usb_hw_ep_scratch_sub *, uint8_t);
+static uint8_t	usb_hw_ep_get_needs(struct usb_hw_ep_scratch *, uint8_t,
+		    uint8_t);
+static usb_error_t usb_hw_ep_resolve(struct usb_device *,
+		    struct usb_descriptor *);
+static const struct usb_temp_device_desc *usb_temp_get_tdd(struct usb_device *);
+static void	*usb_temp_get_device_desc(struct usb_device *);
+static void	*usb_temp_get_qualifier_desc(struct usb_device *);
+static void	*usb_temp_get_config_desc(struct usb_device *, uint16_t *,
+		    uint8_t);
+static const void *usb_temp_get_string_desc(struct usb_device *, uint16_t,
+		    uint8_t);
+static const void *usb_temp_get_vendor_desc(struct usb_device *,
+		    const struct usb_device_request *, uint16_t *plen);
+static const void *usb_temp_get_hub_desc(struct usb_device *);
+static usb_error_t usb_temp_get_desc(struct usb_device *,
+		    struct usb_device_request *, const void **, uint16_t *);
+static usb_error_t usb_temp_setup_by_index(struct usb_device *,
+		    uint16_t index);
+static void	usb_temp_init(void *);
+SYSCTL_NODE(_hw_usb, OID_AUTO, templates, CTLFLAG_RW, 0,
+    "USB device side templates");
+SYSCTL_PROC(_hw_usb, OID_AUTO, template_power,
+    CTLTYPE_INT | CTLFLAG_RWTUN | CTLFLAG_MPSAFE,
+    NULL, 0, sysctl_hw_usb_template_power,
+    "I", "USB bus power consumption in mA at 5V");
+static int	usb_template_power = 500;	/* 500mA */
+static int
+sysctl_hw_usb_template_power(SYSCTL_HANDLER_ARGS)
+	int error, val;
+	val = usb_template_power;
+	error = sysctl_handle_int(oidp, &val, 0, req);
+	if (error != 0 || req->newptr == NULL)
+		return (error);
+	if (val < 0 || val > 500)
+		return (EINVAL);
+	usb_template_power = val;
+	return (0);
+ *	usb_decode_str_desc
+ * Helper function to decode string descriptors into a C string.
+void
+usb_decode_str_desc(struct usb_string_descriptor *sd, char *buf, size_t buflen)
+	size_t i;
+	if (sd->bLength < 2) {
+		buf[0] = '\0';
+		return;
+	for (i = 0; i < buflen - 1 && i < (sd->bLength / 2) - 1; i++)
+		buf[i] = UGETW(sd->bString[i]);
+	buf[i] = '\0';
+ *	usb_temp_sysctl
+ * Callback for SYSCTL_PROC(9), to set and retrieve template string
+ * descriptors.
+int
+usb_temp_sysctl(SYSCTL_HANDLER_ARGS)
+	char buf[128];
+	struct usb_string_descriptor *sd = arg1;
+	size_t len, sdlen = arg2;
+	int error;
+	usb_decode_str_desc(sd, buf, sizeof(buf));
+	error = sysctl_handle_string(oidp, buf, sizeof(buf), req);
+		return (error);
+	len = usb_make_str_desc(sd, sdlen, buf);
+	if (len == 0)
+		return (EINVAL);
+	return (0);
+ *	usb_make_raw_desc
+ * This function will insert a raw USB descriptor into the generated
+ * USB configuration.
+static void
+usb_make_raw_desc(struct usb_temp_setup *temp,
+    const uint8_t *raw)
+	void *dst;
+	uint8_t len;
+         * The first byte of any USB descriptor gives the length.
+	if (raw) {
+		len = raw[0];
+		if (temp->buf) {
+			dst = USB_ADD_BYTES(temp->buf, temp->size);
+			memcpy(dst, raw, len);
+			/* check if we have got a CDC union descriptor */
+			if ((raw[0] == sizeof(struct usb_cdc_union_descriptor)) &&
+			    (raw[1] == UDESC_CS_INTERFACE) &&
+			    (raw[2] == UDESCSUB_CDC_UNION)) {
+				struct usb_cdc_union_descriptor *ud = (void *)dst;
+				/* update the interface numbers */
+				ud->bMasterInterface +=
+				    temp->bInterfaceNumber;
+				ud->bSlaveInterface[0] +=
+			/* check if we have got an interface association descriptor */
+			if ((raw[0] == sizeof(struct usb_interface_assoc_descriptor)) &&
+			    (raw[1] == UDESC_IFACE_ASSOC)) {
+				struct usb_interface_assoc_descriptor *iad = (void *)dst;
+				/* update the interface number */
+				iad->bFirstInterface +=
+			/* check if we have got a call management descriptor */
+			if ((raw[0] == sizeof(struct usb_cdc_cm_descriptor)) &&
+			    (raw[2] == UDESCSUB_CDC_CM)) {
+				struct usb_cdc_cm_descriptor *ccd = (void *)dst;
+				ccd->bDataInterface +=
+		temp->size += len;
+ *	usb_make_endpoint_desc
+ * This function will generate an USB endpoint descriptor from the
+ * given USB template endpoint descriptor, which will be inserted into
+ * the USB configuration.
+static void
+usb_make_endpoint_desc(struct usb_temp_setup *temp,
+    const struct usb_temp_endpoint_desc *ted)
+	struct usb_endpoint_descriptor *ed;
+	const void **rd;
+	uint16_t old_size;
+	uint16_t mps;
+	uint8_t ea;			/* Endpoint Address */
+	uint8_t et;			/* Endpiont Type */
+	/* Reserve memory */
+	old_size = temp->size;
+	ea = (ted->bEndpointAddress & (UE_ADDR | UE_DIR_IN | UE_DIR_OUT));
+	et = (ted->bmAttributes & UE_XFERTYPE);
+	if (et == UE_ISOCHRONOUS) {
+		/* account for extra byte fields */
+		temp->size += sizeof(*ed) + 2;
+	} else {
+		temp->size += sizeof(*ed);
+	/* Scan all Raw Descriptors first */
+	rd = ted->ppRawDesc;
+	if (rd) {
+		while (*rd) {
+			usb_make_raw_desc(temp, *rd);
+			rd++;
+	if (ted->pPacketSize == NULL) {
+		/* not initialized */
+		temp->err = USB_ERR_INVAL;
+		return;
+	mps = ted->pPacketSize->mps[temp->usb_speed];
+	if (mps == 0) {
+		return;
+	} else if (mps == UE_ZERO_MPS) {
+		/* escape for Zero Max Packet Size */
+		mps = 0;
+	 * Fill out the real USB endpoint descriptor
+	 * in case there is a buffer present:
+	if (temp->buf) {
+		ed = USB_ADD_BYTES(temp->buf, old_size);
+			ed->bLength = sizeof(*ed) + 2;
+		else
+			ed->bLength = sizeof(*ed);
+		ed->bDescriptorType = UDESC_ENDPOINT;
+		ed->bEndpointAddress = ea;
+		ed->bmAttributes = ted->bmAttributes;
+		USETW(ed->wMaxPacketSize, mps);
+		/* setup bInterval parameter */
+		if (ted->pIntervals &&
+		    ted->pIntervals->bInterval[temp->usb_speed]) {
+			ed->bInterval =
+			    ted->pIntervals->bInterval[temp->usb_speed];
+		} else {
+			switch (et) {
+			case UE_BULK:
+			case UE_CONTROL:
+				ed->bInterval = 0;	/* not used */
+				break;
+			case UE_INTERRUPT:
+				switch (temp->usb_speed) {
+				case USB_SPEED_LOW:
+				case USB_SPEED_FULL:
+					ed->bInterval = 1;	/* 1 ms */
+					break;
+				default:
+					ed->bInterval = 4;	/* 1 ms */
+					break;
+				break;
+			default:	/* UE_ISOCHRONOUS */
+					break;
+				default:
+					ed->bInterval = 1;	/* 125 us */
+					break;
+				break;
+	temp->bNumEndpoints++;
+ *	usb_make_interface_desc
+ * This function will generate an USB interface descriptor from the
+ * given USB template interface descriptor, which will be inserted
+ * into the USB configuration.
+static void
+usb_make_interface_desc(struct usb_temp_setup *temp,
+    const struct usb_temp_interface_desc *tid)
+	struct usb_interface_descriptor *id;
+	const struct usb_temp_endpoint_desc **ted;
+	const void **rd;
+	temp->size += sizeof(*id);
+	/* Update interface and alternate interface numbers */
+	if (tid->isAltInterface == 0) {
+		temp->bAlternateSetting = 0;
+		temp->bInterfaceNumber++;
+	} else {
+		temp->bAlternateSetting++;
+	rd = tid->ppRawDesc;
+	if (rd) {
+		while (*rd) {
+			rd++;
+	/* Reset some counters */
+	temp->bNumEndpoints = 0;
+	/* Scan all Endpoint Descriptors second */
+	ted = tid->ppEndpoints;
+	if (ted) {
+		while (*ted) {
+			usb_make_endpoint_desc(temp, *ted);
+			ted++;
+	 * Fill out the real USB interface descriptor
+	if (temp->buf) {
+		id = USB_ADD_BYTES(temp->buf, old_size);
+		id->bLength = sizeof(*id);
+		id->bDescriptorType = UDESC_INTERFACE;
+		id->bInterfaceNumber = temp->bInterfaceNumber;
+		id->bAlternateSetting = temp->bAlternateSetting;
+		id->bNumEndpoints = temp->bNumEndpoints;
+		id->bInterfaceClass = tid->bInterfaceClass;
+		id->bInterfaceSubClass = tid->bInterfaceSubClass;
+		id->bInterfaceProtocol = tid->bInterfaceProtocol;
+		id->iInterface = tid->iInterface;
+ *	usb_make_config_desc
+ * This function will generate an USB config descriptor from the given
+ * USB template config descriptor, which will be inserted into the USB
+ * configuration.
+static void
+usb_make_config_desc(struct usb_temp_setup *temp,
+    const struct usb_temp_config_desc *tcd)
+	struct usb_config_descriptor *cd;
+	const struct usb_temp_interface_desc **tid;
+	int power;
+	temp->size += sizeof(*cd);
+	temp->bInterfaceNumber = 0xFF;
+	/* Scan all the USB interfaces */
+	tid = tcd->ppIfaceDesc;
+	if (tid) {
+		while (*tid) {
+			usb_make_interface_desc(temp, *tid);
+			tid++;
+	 * Fill out the real USB config descriptor
+	if (temp->buf) {
+		cd = USB_ADD_BYTES(temp->buf, old_size);
+		/* compute total size */
+		old_size = temp->size - old_size;
+		cd->bLength = sizeof(*cd);
+		cd->bDescriptorType = UDESC_CONFIG;
+		USETW(cd->wTotalLength, old_size);
+		cd->bNumInterface = temp->bInterfaceNumber + 1;
+		cd->bConfigurationValue = temp->bConfigurationValue;
+		cd->iConfiguration = tcd->iConfiguration;
+		cd->bmAttributes = tcd->bmAttributes;
+		power = usb_template_power;
+		cd->bMaxPower = power / 2; /* 2 mA units */
+		cd->bmAttributes |= UC_REMOTE_WAKEUP;
+		if (power > 0) {
+			cd->bmAttributes |= UC_BUS_POWERED;
+			cd->bmAttributes &= ~UC_SELF_POWERED;
+		} else {
+			cd->bmAttributes &= ~UC_BUS_POWERED;
+			cd->bmAttributes |= UC_SELF_POWERED;
+ *	usb_make_device_desc
+ * This function will generate an USB device descriptor from the
+ * given USB template device descriptor.
+static void
+usb_make_device_desc(struct usb_temp_setup *temp,
+    const struct usb_temp_device_desc *tdd)
+	struct usb_temp_data *utd;
+	const struct usb_temp_config_desc **tcd;
+	temp->size += sizeof(*utd);
+	/* Scan all the USB configs */
+	temp->bConfigurationValue = 1;
+	tcd = tdd->ppConfigDesc;
+	if (tcd) {
+		while (*tcd) {
+			usb_make_config_desc(temp, *tcd);
+			temp->bConfigurationValue++;
+			tcd++;
+	 * Fill out the real USB device descriptor
+	if (temp->buf) {
+		utd = USB_ADD_BYTES(temp->buf, old_size);
+		/* Store a pointer to our template device descriptor */
+		utd->tdd = tdd;
+		/* Fill out USB device descriptor */
+		utd->udd.bLength = sizeof(utd->udd);
+		utd->udd.bDescriptorType = UDESC_DEVICE;
+		utd->udd.bDeviceClass = tdd->bDeviceClass;
+		utd->udd.bDeviceSubClass = tdd->bDeviceSubClass;
+		utd->udd.bDeviceProtocol = tdd->bDeviceProtocol;
+		USETW(utd->udd.idVendor, tdd->idVendor);
+		USETW(utd->udd.idProduct, tdd->idProduct);
+		USETW(utd->udd.bcdDevice, tdd->bcdDevice);
+		utd->udd.iManufacturer = tdd->iManufacturer;
+		utd->udd.iProduct = tdd->iProduct;
+		utd->udd.iSerialNumber = tdd->iSerialNumber;
+		utd->udd.bNumConfigurations = temp->bConfigurationValue - 1;
+		 * Fill out the USB device qualifier. Pretend that we
+		 * don't support any other speeds by setting
+		 * "bNumConfigurations" equal to zero. That saves us
+		 * generating an extra set of configuration
+		 * descriptors.
+		utd->udq.bLength = sizeof(utd->udq);
+		utd->udq.bDescriptorType = UDESC_DEVICE_QUALIFIER;
+		utd->udq.bDeviceClass = tdd->bDeviceClass;
+		utd->udq.bDeviceSubClass = tdd->bDeviceSubClass;
+		utd->udq.bDeviceProtocol = tdd->bDeviceProtocol;
+		utd->udq.bNumConfigurations = 0;
+		USETW(utd->udq.bcdUSB, 0x0200);
+		utd->udq.bMaxPacketSize0 = 0;
+			USETW(utd->udd.bcdUSB, 0x0110);
+			utd->udd.bMaxPacketSize = 8;
+			break;
+			utd->udd.bMaxPacketSize = 32;
+			break;
+		case USB_SPEED_HIGH:
+			USETW(utd->udd.bcdUSB, 0x0200);
+			utd->udd.bMaxPacketSize = 64;
+			break;
+		case USB_SPEED_VARIABLE:
+			USETW(utd->udd.bcdUSB, 0x0250);
+			utd->udd.bMaxPacketSize = 255;	/* 512 bytes */
+			break;
+		case USB_SPEED_SUPER:
+			USETW(utd->udd.bcdUSB, 0x0300);
+			utd->udd.bMaxPacketSize = 9;	/* 2**9 = 512 bytes */
+			break;
+		default:
+			break;
+ *	usb_hw_ep_match
+ * Return values:
+ *    0: The endpoint profile does not match the criteria
+ * Else: The endpoint profile matches the criteria
+static uint8_t
+usb_hw_ep_match(const struct usb_hw_ep_profile *pf,
+    uint8_t ep_type, uint8_t ep_dir_in)
+	if (ep_type == UE_CONTROL) {
+		/* special */
+		return (pf->support_control);
+	if ((pf->support_in && ep_dir_in) ||
+	    (pf->support_out && !ep_dir_in)) {
+		if ((pf->support_interrupt && (ep_type == UE_INTERRUPT)) ||
+		    (pf->support_isochronous && (ep_type == UE_ISOCHRONOUS)) ||
+		    (pf->support_bulk && (ep_type == UE_BULK))) {
+			return (1);
+	return (0);
+ *	usb_hw_ep_find_match
+ * This function is used to find the best matching endpoint profile
+ * for and endpoint belonging to an USB descriptor.
+ * Return values:
+ *    0: Success. Got a match.
+ * Else: Failure. No match.
+static uint8_t
+usb_hw_ep_find_match(struct usb_hw_ep_scratch *ues,
+    struct usb_hw_ep_scratch_sub *ep, uint8_t is_simplex)
+	const struct usb_hw_ep_profile *pf;
+	uint16_t distance;
+	uint16_t temp;
+	uint16_t max_frame_size;
+	uint8_t n;
+	uint8_t best_n;
+	uint8_t dir_in;
+	uint8_t dir_out;
+	distance = 0xFFFF;
+	best_n = 0;
+	if ((!ep->needs_in) && (!ep->needs_out)) {
+		return (0);		/* we are done */
+	if (ep->needs_ep_type == UE_CONTROL) {
+		dir_in = 1;
+		dir_out = 1;
+	} else {
+		if (ep->needs_in) {
+			dir_in = 1;
+			dir_out = 0;
+		} else {
+			dir_in = 0;
+			dir_out = 1;
+	for (n = 1; n != (USB_EP_MAX / 2); n++) {
+		/* get HW endpoint profile */
+		(ues->methods->get_hw_ep_profile) (ues->udev, &pf, n);
+		if (pf == NULL) {
+			/* end of profiles */
+			break;
+		/* check if IN-endpoint is reserved */
+		if (dir_in || pf->is_simplex) {
+			if (ues->bmInAlloc[n / 8] & (1 << (n % 8))) {
+				/* mismatch */
+				continue;
+		/* check if OUT-endpoint is reserved */
+		if (dir_out || pf->is_simplex) {
+			if (ues->bmOutAlloc[n / 8] & (1 << (n % 8))) {
+				/* mismatch */
+				continue;
+		/* check simplex */
+		if (pf->is_simplex == is_simplex) {
+			/* mismatch */
+			continue;
+		/* check if HW endpoint matches */
+		if (!usb_hw_ep_match(pf, ep->needs_ep_type, dir_in)) {
+			/* mismatch */
+			continue;
+		/* get maximum frame size */
+		if (dir_in)
+			max_frame_size = pf->max_in_frame_size;
+		else
+			max_frame_size = pf->max_out_frame_size;
+		/* check if we have a matching profile */
+		if (max_frame_size >= ep->max_frame_size) {
+			temp = (max_frame_size - ep->max_frame_size);
+			if (distance > temp) {
+				distance = temp;
+				best_n = n;
+				ep->pf = pf;
+	/* see if we got a match */
+	if (best_n != 0) {
+		/* get the correct profile */
+		pf = ep->pf;
+		/* reserve IN-endpoint */
+		if (dir_in) {
+			ues->bmInAlloc[best_n / 8] |=
+			    (1 << (best_n % 8));
+			ep->hw_endpoint_in = best_n | UE_DIR_IN;
+			ep->needs_in = 0;
+		/* reserve OUT-endpoint */
+		if (dir_out) {
+			ues->bmOutAlloc[best_n / 8] |=
+			ep->hw_endpoint_out = best_n | UE_DIR_OUT;
+			ep->needs_out = 0;
+		return (0);		/* got a match */
+	return (1);			/* failure */
+ *	usb_hw_ep_get_needs
+ * This function will figure out the type and number of endpoints
+ * which are needed for an USB configuration.
+ * Return values:
+ *    0: Success.
+ * Else: Failure.
+static uint8_t
+usb_hw_ep_get_needs(struct usb_hw_ep_scratch *ues,
+    uint8_t ep_type, uint8_t is_complete)
+	struct usb_hw_ep_scratch_sub *ep_iface;
+	struct usb_hw_ep_scratch_sub *ep_curr;
+	struct usb_hw_ep_scratch_sub *ep_max;
+	struct usb_hw_ep_scratch_sub *ep_end;
+	struct usb_descriptor *desc;
+	enum usb_dev_speed speed;
+	uint16_t wMaxPacketSize;
+	uint16_t temp;
+	uint8_t ep_no;
+	ep_iface = ues->ep_max;
+	ep_curr = ues->ep_max;
+	ep_end = ues->ep + USB_EP_MAX;
+	ep_max = ues->ep_max;
+	desc = NULL;
+	speed = usbd_get_speed(ues->udev);
+repeat:
+	while ((desc = usb_desc_foreach(ues->cd, desc))) {
+		if ((desc->bDescriptorType == UDESC_INTERFACE) &&
+		    (desc->bLength >= sizeof(*id))) {
+			id = (void *)desc;
+			if (id->bAlternateSetting == 0) {
+				/* going forward */
+				ep_iface = ep_max;
+			} else {
+				/* reset */
+				ep_curr = ep_iface;
+		if ((desc->bDescriptorType == UDESC_ENDPOINT) &&
+		    (desc->bLength >= sizeof(*ed))) {
+			ed = (void *)desc;
+			goto handle_endpoint_desc;
+	ues->ep_max = ep_max;
+	return (0);
+handle_endpoint_desc:
+	temp = (ed->bmAttributes & UE_XFERTYPE);
+	if (temp == ep_type) {
+		if (ep_curr == ep_end) {
+			/* too many endpoints */
+		wMaxPacketSize = UGETW(ed->wMaxPacketSize);
+		if ((wMaxPacketSize & 0xF800) &&
+		    (speed == USB_SPEED_HIGH)) {
+			/* handle packet multiplier */
+			temp = (wMaxPacketSize >> 11) & 3;
+			wMaxPacketSize &= 0x7FF;
+			if (temp == 1) {
+				wMaxPacketSize *= 2;
+			} else {
+				wMaxPacketSize *= 3;
+		 * Check if we have a fixed endpoint number, else the
+		 * endpoint number is allocated dynamically:
+		ep_no = (ed->bEndpointAddress & UE_ADDR);
+		if (ep_no != 0) {
+			    (ues->udev, &pf, ep_no);
+			if (pf == NULL) {
+				/* HW profile does not exist - failure */
+				DPRINTFN(0, "Endpoint profile %u "
+				    "does not exist\n", ep_no);
+				return (1);
+			/* reserve fixed endpoint number */
+				ues->bmInAlloc[ep_no / 8] |=
+				    (1 << (ep_no % 8));
+				ues->bmOutAlloc[ep_no / 8] |=
+				if ((pf->max_in_frame_size < wMaxPacketSize) ||
+				    (pf->max_out_frame_size < wMaxPacketSize)) {
+					    "has too small buffer\n", ep_no);
+					return (1);
+			} else if (ed->bEndpointAddress & UE_DIR_IN) {
+				if (pf->max_in_frame_size < wMaxPacketSize) {
+					return (1);
+			} else {
+				if (pf->max_out_frame_size < wMaxPacketSize) {
+					return (1);
+		} else if (is_complete) {
+			/* check if we have enough buffer space */
+			if (wMaxPacketSize >
+			    ep_curr->max_frame_size) {
+			if (ed->bEndpointAddress & UE_DIR_IN) {
+				    ep_curr->hw_endpoint_in;
+			} else {
+				    ep_curr->hw_endpoint_out;
+		} else {
+			/* compute the maximum frame size */
+			if (ep_curr->max_frame_size < wMaxPacketSize) {
+				ep_curr->max_frame_size = wMaxPacketSize;
+			if (temp == UE_CONTROL) {
+				ep_curr->needs_in = 1;
+				ep_curr->needs_out = 1;
+			} else {
+				} else {
+			ep_curr->needs_ep_type = ep_type;
+		ep_curr++;
+		if (ep_max < ep_curr) {
+			ep_max = ep_curr;
+	goto repeat;
+ *	usb_hw_ep_resolve
+ * This function will try to resolve endpoint requirements by the
+ * given endpoint profiles that the USB hardware reports.
+ * Return values:
+ *    0: Success
+ * Else: Failure
+static usb_error_t
+usb_hw_ep_resolve(struct usb_device *udev,
+    struct usb_descriptor *desc)
+	struct usb_hw_ep_scratch *ues;
+	struct usb_hw_ep_scratch_sub *ep;
+	const struct usb_bus_methods *methods;
+	struct usb_device_descriptor *dd;
+	uint16_t mps;
+	if (desc == NULL)
+		return (USB_ERR_INVAL);
+	/* get bus methods */
+	methods = udev->bus->methods;
+	if (methods->get_hw_ep_profile == NULL)
+	if (desc->bDescriptorType == UDESC_DEVICE) {
+		if (desc->bLength < sizeof(*dd))
+		dd = (void *)desc;
+		/* get HW control endpoint 0 profile */
+		(methods->get_hw_ep_profile) (udev, &pf, 0);
+		if (pf == NULL) {
+		if (!usb_hw_ep_match(pf, UE_CONTROL, 0)) {
+			DPRINTFN(0, "Endpoint 0 does not "
+			    "support control\n");
+		mps = dd->bMaxPacketSize;
+		if (udev->speed == USB_SPEED_FULL) {
+			 * We can optionally choose another packet size !
+			while (1) {
+				/* check if "mps" is ok */
+				if (pf->max_in_frame_size >= mps) {
+					break;
+				/* reduce maximum packet size */
+				mps /= 2;
+				/* check if "mps" is too small */
+				if (mps < 8) {
+			dd->bMaxPacketSize = mps;
+		} else {
+			/* We only have one choice */
+			if (mps == 255) {
+				mps = 512;
+			/* Check if we support the specified wMaxPacketSize */
+			if (pf->max_in_frame_size < mps) {
+		return (0);		/* success */
+	if (desc->bDescriptorType != UDESC_CONFIG)
+	if (desc->bLength < sizeof(*(ues->cd)))
+	ues = udev->scratch.hw_ep_scratch;
+	memset(ues, 0, sizeof(*ues));
+	ues->ep_max = ues->ep;
+	ues->cd = (void *)desc;
+	ues->methods = methods;
+	ues->udev = udev;
+	/* Get all the endpoints we need */
+	if (usb_hw_ep_get_needs(ues, UE_ISOCHRONOUS, 0) ||
+	    usb_hw_ep_get_needs(ues, UE_INTERRUPT, 0) ||
+	    usb_hw_ep_get_needs(ues, UE_CONTROL, 0) ||
+	    usb_hw_ep_get_needs(ues, UE_BULK, 0)) {
+		DPRINTFN(0, "Could not get needs\n");
+	for (ep = ues->ep; ep != ues->ep_max; ep++) {
+		while (ep->needs_in || ep->needs_out) {
+		         * First try to use a simplex endpoint.
+		         * Then try to use a duplex endpoint.
+			if (usb_hw_ep_find_match(ues, ep, 1) &&
+			    usb_hw_ep_find_match(ues, ep, 0)) {
+				DPRINTFN(0, "Could not find match\n");
+	/* Update all endpoint addresses */
+	if (usb_hw_ep_get_needs(ues, UE_ISOCHRONOUS, 1) ||
+	    usb_hw_ep_get_needs(ues, UE_INTERRUPT, 1) ||
+	    usb_hw_ep_get_needs(ues, UE_CONTROL, 1) ||
+	    usb_hw_ep_get_needs(ues, UE_BULK, 1)) {
+		DPRINTFN(0, "Could not update endpoint address\n");
+ *	usb_temp_get_tdd
+ * Returns:
+ *  NULL: No USB template device descriptor found.
+ *  Else: Pointer to the USB template device descriptor.
+usb_temp_get_tdd(struct usb_device *udev)
+	if (udev->usb_template_ptr == NULL) {
+		return (NULL);
+	return (udev->usb_template_ptr->tdd);
+ *	usb_temp_get_device_desc
+ * Returns:
+ *  NULL: No USB device descriptor found.
+ *  Else: Pointer to USB device descriptor.
+static void *
+usb_temp_get_device_desc(struct usb_device *udev)
+		return (NULL);
+	dd = &udev->usb_template_ptr->udd;
+	if (dd->bDescriptorType != UDESC_DEVICE) {
+		/* sanity check failed */
+		return (NULL);
+	return (dd);
+ *	usb_temp_get_qualifier_desc
+ * Returns:
+ *  NULL: No USB device_qualifier descriptor found.
+ *  Else: Pointer to USB device_qualifier descriptor.
+static void *
+usb_temp_get_qualifier_desc(struct usb_device *udev)
+	struct usb_device_qualifier *dq;
+		return (NULL);
+	dq = &udev->usb_template_ptr->udq;
+	if (dq->bDescriptorType != UDESC_DEVICE_QUALIFIER) {
+		return (NULL);
+	return (dq);
+ *	usb_temp_get_config_desc
+ * Returns:
+ *  NULL: No USB config descriptor found.
+ *  Else: Pointer to USB config descriptor having index "index".
+static void *
+usb_temp_get_config_desc(struct usb_device *udev,
+    uint16_t *pLength, uint8_t index)
+	uint16_t temp;
+		return (NULL);
+	cd = (void *)(udev->usb_template_ptr + 1);
+	if (index >= dd->bNumConfigurations) {
+		/* out of range */
+		return (NULL);
+	while (index--) {
+		if (cd->bDescriptorType != UDESC_CONFIG) {
+			return (NULL);
+		temp = UGETW(cd->wTotalLength);
+		cd = USB_ADD_BYTES(cd, temp);
+	if (pLength) {
+		*pLength = UGETW(cd->wTotalLength);
+	return (cd);
+ *	usb_temp_get_vendor_desc
+ * Returns:
+ *  NULL: No vendor descriptor found.
+ *  Else: Pointer to a vendor descriptor.
+usb_temp_get_vendor_desc(struct usb_device *udev,
+    const struct usb_device_request *req, uint16_t *plen)
+	const struct usb_temp_device_desc *tdd;
+	tdd = usb_temp_get_tdd(udev);
+	if (tdd == NULL) {
+		return (NULL);
+	if (tdd->getVendorDesc == NULL) {
+		return (NULL);
+	return ((tdd->getVendorDesc) (req, plen));
+ *	usb_temp_get_string_desc
+ * Returns:
+ *  NULL: No string descriptor found.
+ *  Else: Pointer to a string descriptor.
+usb_temp_get_string_desc(struct usb_device *udev,
+    uint16_t lang_id, uint8_t string_index)
+		return (NULL);
+	if (tdd->getStringDesc == NULL) {
+		return (NULL);
+	return ((tdd->getStringDesc) (lang_id, string_index));
+ *	usb_temp_get_hub_desc
+ * Returns:
+ *  NULL: No USB HUB descriptor found.
+ *  Else: Pointer to a USB HUB descriptor.
+usb_temp_get_hub_desc(struct usb_device *udev)
+	return (NULL);			/* needs to be implemented */
+ *	usb_temp_get_desc
+ * This function is a demultiplexer for local USB device side control
+ * endpoint requests.
+static usb_error_t
+usb_temp_get_desc(struct usb_device *udev, struct usb_device_request *req,
+    const void **pPtr, uint16_t *pLength)
+	const uint8_t *buf;
+	uint16_t len;
+	buf = NULL;
+	len = 0;
+	switch (req->bmRequestType) {
+	case UT_READ_DEVICE:
+		switch (req->bRequest) {
+		case UR_GET_DESCRIPTOR:
+			goto tr_handle_get_descriptor;
+		default:
+			goto tr_stalled;
+	case UT_READ_CLASS_DEVICE:
+			goto tr_handle_get_class_descriptor;
+		default:
+			goto tr_stalled;
+	default:
+		goto tr_stalled;
+tr_handle_get_descriptor:
+	switch (req->wValue[1]) {
+	case UDESC_DEVICE:
+		if (req->wValue[0]) {
+			goto tr_stalled;
+		buf = usb_temp_get_device_desc(udev);
+		goto tr_valid;
+	case UDESC_DEVICE_QUALIFIER:
+		if (udev->speed != USB_SPEED_HIGH) {
+			goto tr_stalled;
+			goto tr_stalled;
+		buf = usb_temp_get_qualifier_desc(udev);
+		goto tr_valid;
+	case UDESC_OTHER_SPEED_CONFIGURATION:
+			goto tr_stalled;
+	case UDESC_CONFIG:
+		buf = usb_temp_get_config_desc(udev,
+		    &len, req->wValue[0]);
+		goto tr_valid;
+	case UDESC_STRING:
+		buf = usb_temp_get_string_desc(udev,
+		    UGETW(req->wIndex), req->wValue[0]);
+		goto tr_valid;
+	default:
+		goto tr_stalled;
+tr_handle_get_class_descriptor:
+		goto tr_stalled;
+	buf = usb_temp_get_hub_desc(udev);
+	goto tr_valid;
+tr_valid:
+	if (buf == NULL)
+		goto tr_stalled;
+	if (len == 0)
+		len = buf[0];
+	*pPtr = buf;
+	*pLength = len;
+tr_stalled:
+	/* try to get a vendor specific descriptor */
+	len = 0;
+	buf = usb_temp_get_vendor_desc(udev, req, &len);
+	if (buf != NULL)
+		goto tr_valid;
+	*pPtr = NULL;
+	*pLength = 0;
+	return (0);	/* we ignore failures */
+ *	usb_temp_setup
+ * This function generates USB descriptors according to the given USB
+ * template device descriptor. It will also try to figure out the best
+ * matching endpoint addresses using the hardware endpoint profiles.
+ * Returns:
+ *    0: Success
+ * Else: Failure
+usb_error_t
+usb_temp_setup(struct usb_device *udev,
+	struct usb_temp_setup *uts;
+	void *buf;
+	usb_error_t error;
+	uint8_t n;
+	uint8_t do_unlock;
+	/* be NULL safe */
+	if (tdd == NULL)
+		return (0);
+	/* Protect scratch area */
+	do_unlock = usbd_ctrl_lock(udev);
+	uts = udev->scratch.temp_setup;
+	memset(uts, 0, sizeof(*uts));
+	uts->usb_speed = udev->speed;
+	uts->self_powered = udev->flags.self_powered;
+	/* first pass */
+	usb_make_device_desc(uts, tdd);
+	if (uts->err) {
+		/* some error happened */
+		goto done;
+	/* sanity check */
+	if (uts->size == 0) {
+		uts->err = USB_ERR_INVAL;
+		goto done;
+	/* allocate zeroed memory */
+	uts->buf = usbd_alloc_config_desc(udev, uts->size);
+	 * Allow malloc() to return NULL regardless of M_WAITOK flag.
+	 * This helps when porting the software to non-FreeBSD
+	 * systems.
+	if (uts->buf == NULL) {
+		/* could not allocate memory */
+		uts->err = USB_ERR_NOMEM;
+		goto done;
+	/* second pass */
+	uts->size = 0;
+	 * Store a pointer to our descriptors:
+	udev->usb_template_ptr = uts->buf;
+	if (uts->err) {
+		/* some error happened during second pass */
+		goto done;
+	 * Resolve all endpoint addresses !
+	uts->err = usb_hw_ep_resolve(udev, buf);
+	if (uts->err) {
+		DPRINTFN(0, "Could not resolve endpoints for "
+		    "Device Descriptor, error = %s\n",
+		    usbd_errstr(uts->err));
+		goto done;
+	for (n = 0;; n++) {
+		buf = usb_temp_get_config_desc(udev, NULL, n);
+		if (buf == NULL) {
+			break;
+		if (uts->err) {
+			    "Config Descriptor %u, error = %s\n", n,
+			goto done;
+done:
+	error = uts->err;
+	if (error)
+		usb_temp_unsetup(udev);
+	if (do_unlock)
+		usbd_ctrl_unlock(udev);
+	return (error);
+ *	usb_temp_unsetup
+ * This function frees any memory associated with the currently
+ * setup template, if any.
+void
+usb_temp_unsetup(struct usb_device *udev)
+	usbd_free_config_desc(udev, udev->usb_template_ptr);
+	udev->usb_template_ptr = NULL;
+static usb_error_t
+usb_temp_setup_by_index(struct usb_device *udev, uint16_t index)
+	usb_error_t err;
+	switch (index) {
+	case USB_TEMP_MSC:
+		err = usb_temp_setup(udev, &usb_template_msc);
+		break;
+	case USB_TEMP_CDCE:
+		err = usb_temp_setup(udev, &usb_template_cdce);
+		break;
+	case USB_TEMP_MTP:
+		err = usb_temp_setup(udev, &usb_template_mtp);
+		break;
+	case USB_TEMP_MODEM:
+		err = usb_temp_setup(udev, &usb_template_modem);
+		break;
+	case USB_TEMP_AUDIO:
+		err = usb_temp_setup(udev, &usb_template_audio);
+		break;
+	case USB_TEMP_KBD:
+		err = usb_temp_setup(udev, &usb_template_kbd);
+		break;
+	case USB_TEMP_MOUSE:
+		err = usb_temp_setup(udev, &usb_template_mouse);
+		break;
+	case USB_TEMP_PHONE:
+		err = usb_temp_setup(udev, &usb_template_phone);
+		break;
+	case USB_TEMP_SERIALNET:
+		err = usb_temp_setup(udev, &usb_template_serialnet);
+		break;
+	case USB_TEMP_MIDI:
+		err = usb_temp_setup(udev, &usb_template_midi);
+		break;
+	case USB_TEMP_MULTI:
+		err = usb_temp_setup(udev, &usb_template_multi);
+		break;
+	case USB_TEMP_CDCEEM:
+		err = usb_temp_setup(udev, &usb_template_cdceem);
+		break;
+	default:
+	return (err);
+static void
+usb_temp_init(void *arg)
+	/* register our functions */
+	usb_temp_get_desc_p = &usb_temp_get_desc;
+	usb_temp_setup_by_index_p = &usb_temp_setup_by_index;
+	usb_temp_unsetup_p = &usb_temp_unsetup;
+SYSINIT(usb_temp_init, SI_SUB_LOCK, SI_ORDER_FIRST, usb_temp_init, NULL);
+SYSUNINIT(usb_temp_unload, SI_SUB_LOCK, SI_ORDER_ANY, usb_temp_unload, NULL);
diff --git a/freebsd/sys/dev/usb/template/usb_template.h b/freebsd/sys/dev/usb/template/usb_template.h
index 00000000..1bb2424c
--- /dev/null
+++ b/freebsd/sys/dev/usb/template/usb_template.h
@@ -0,0 +1,130 @@
+/* $FreeBSD$ */
+ * Copyright (c) 2007 Hans Petter Selasky <hselasky at FreeBSD.org>
+ * All rights reserved.
+ * are met:
+ * SUCH DAMAGE.
+/* USB templates are used to build up real USB descriptors */
+#ifndef _USB_TEMPLATE_H_
+#define	_USB_TEMPLATE_H_
+#ifndef USB_TEMPLATE_VENDOR
+ * https://github.com/obdev/v-usb/blob/master/usbdrv/USB-IDs-for-free.txt
+#define	USB_TEMPLATE_VENDOR		0x16c0
+#define	USB_TEMPLATE_MANUFACTURER	\
+	"The FreeBSD Project (https://www.FreeBSD.org)"
+#endif
+typedef const void *(usb_temp_get_string_desc_t)(uint16_t lang_id, uint8_t string_index);
+typedef const void *(usb_temp_get_vendor_desc_t)(const struct usb_device_request *req, uint16_t *plen);
+struct usb_temp_packet_size {
+	uint16_t mps[USB_SPEED_MAX];
+struct usb_temp_interval {
+	uint8_t	bInterval[USB_SPEED_MAX];
+struct usb_temp_endpoint_desc {
+	const void **ppRawDesc;
+	const struct usb_temp_packet_size *pPacketSize;
+	const struct usb_temp_interval *pIntervals;
+	 * If (bEndpointAddress & UE_ADDR) is non-zero the endpoint number
+	 * is pre-selected for this endpoint descriptor. Else an endpoint
+	 * number is automatically chosen.
+	uint8_t	bEndpointAddress;	/* UE_DIR_IN or UE_DIR_OUT */
+	uint8_t	bmAttributes;
+struct usb_temp_interface_desc {
+	const struct usb_temp_endpoint_desc **ppEndpoints;
+	uint8_t	bInterfaceClass;
+	uint8_t	bInterfaceSubClass;
+	uint8_t	bInterfaceProtocol;
+	uint8_t	iInterface;
+	uint8_t	isAltInterface;
+struct usb_temp_config_desc {
+	const struct usb_temp_interface_desc **ppIfaceDesc;
+	uint8_t	bMaxPower;
+	uint8_t	iConfiguration;
+struct usb_temp_device_desc {
+	usb_temp_get_string_desc_t *getStringDesc;
+	usb_temp_get_vendor_desc_t *getVendorDesc;
+	const struct usb_temp_config_desc **ppConfigDesc;
+	uint16_t idVendor;
+	uint16_t idProduct;
+	uint16_t bcdDevice;
+	uint8_t	bDeviceClass;
+	uint8_t	bDeviceSubClass;
+	uint8_t	bDeviceProtocol;
+	uint8_t	iManufacturer;
+	uint8_t	iProduct;
+	uint8_t	iSerialNumber;
+struct usb_temp_data {
+	struct usb_device_descriptor udd;	/* device descriptor */
+	struct usb_device_qualifier udq;	/* device qualifier */
+/* prototypes */
+extern struct usb_temp_device_desc usb_template_audio;
+extern struct usb_temp_device_desc usb_template_cdce;
+extern struct usb_temp_device_desc usb_template_kbd;
+extern struct usb_temp_device_desc usb_template_modem;
+extern struct usb_temp_device_desc usb_template_mouse;
+extern struct usb_temp_device_desc usb_template_msc;
+extern struct usb_temp_device_desc usb_template_mtp;
+extern struct usb_temp_device_desc usb_template_phone;
+extern struct usb_temp_device_desc usb_template_serialnet;
+extern struct usb_temp_device_desc usb_template_midi;
+extern struct usb_temp_device_desc usb_template_multi;
+extern struct usb_temp_device_desc usb_template_cdceem;
+void		usb_decode_str_desc(struct usb_string_descriptor *sd,
+		    char *buf, size_t buflen);
+usb_error_t	usb_temp_setup(struct usb_device *,
+void		usb_temp_unsetup(struct usb_device *);
+int		usb_temp_sysctl(SYSCTL_HANDLER_ARGS);
+SYSCTL_DECL(_hw_usb_templates);
+#endif					/* _USB_TEMPLATE_H_ */
diff --git a/freebsd/sys/dev/usb/template/usb_template_cdce.c b/freebsd/sys/dev/usb/template/usb_template_cdce.c
index 00000000..18568fc2
--- /dev/null
+++ b/freebsd/sys/dev/usb/template/usb_template_cdce.c
@@ -0,0 +1,355 @@
+/* $FreeBSD$ */
+ * Copyright (c) 2018 The FreeBSD Foundation
+ * Portions of this software were developed by Edward Tomasz Napierala
+ * under sponsorship from the FreeBSD Foundation.
+ * are met:
+ * SUCH DAMAGE.
+ * This file contains the USB templates for a CDC USB ethernet device.
+#else
+enum {
+	ETH_LANG_INDEX,
+	ETH_MAC_INDEX,
+	ETH_CONTROL_INDEX,
+	ETH_DATA_INDEX,
+	ETH_CONFIGURATION_INDEX,
+	ETH_MANUFACTURER_INDEX,
+	ETH_PRODUCT_INDEX,
+	ETH_SERIAL_NUMBER_INDEX,
+	ETH_MAX_INDEX,
+#define	ETH_DEFAULT_VENDOR_ID		USB_TEMPLATE_VENDOR
+#define	ETH_DEFAULT_PRODUCT_ID		0x27e1
+#define	ETH_DEFAULT_MAC			"2A02030405060789AB"
+#define	ETH_DEFAULT_CONTROL		"USB Ethernet Comm Interface"
+#define	ETH_DEFAULT_DATA		"USB Ethernet Data Interface"
+#define	ETH_DEFAULT_CONFIG		"Default Config"
+#define	ETH_DEFAULT_MANUFACTURER	USB_TEMPLATE_MANUFACTURER
+#define	ETH_DEFAULT_PRODUCT		"USB Ethernet Adapter"
+#define	ETH_DEFAULT_SERIAL_NUMBER	"December 2007"
+static struct usb_string_descriptor	eth_mac;
+static struct usb_string_descriptor	eth_control;
+static struct usb_string_descriptor	eth_data;
+static struct usb_string_descriptor	eth_configuration;
+static struct usb_string_descriptor	eth_manufacturer;
+static struct usb_string_descriptor	eth_product;
+static struct usb_string_descriptor	eth_serial_number;
+static struct sysctl_ctx_list		eth_ctx_list;
+/* prototypes */
+static usb_temp_get_string_desc_t eth_get_string_desc;
+static const struct usb_cdc_union_descriptor eth_union_desc = {
+	.bLength = sizeof(eth_union_desc),
+	.bDescriptorType = UDESC_CS_INTERFACE,
+	.bDescriptorSubtype = UDESCSUB_CDC_UNION,
+	.bMasterInterface = 0,		/* this is automatically updated */
+	.bSlaveInterface[0] = 1,	/* this is automatically updated */
+static const struct usb_cdc_header_descriptor eth_header_desc = {
+	.bLength = sizeof(eth_header_desc),
+	.bDescriptorSubtype = UDESCSUB_CDC_HEADER,
+	.bcdCDC[0] = 0x10,
+	.bcdCDC[1] = 0x01,
+static const struct usb_cdc_ethernet_descriptor eth_enf_desc = {
+	.bLength = sizeof(eth_enf_desc),
+	.bDescriptorSubtype = UDESCSUB_CDC_ENF,
+	.iMacAddress = ETH_MAC_INDEX,
+	.bmEthernetStatistics = {0, 0, 0, 0},
+	.wMaxSegmentSize = {0xEA, 0x05},/* 1514 bytes */
+	.wNumberMCFilters = {0, 0},
+	.bNumberPowerFilters = 0,
+static const void *eth_control_if_desc[] = {
+	&eth_union_desc,
+	&eth_header_desc,
+	&eth_enf_desc,
+	NULL,
+static const struct usb_temp_packet_size bulk_mps = {
+	.mps[USB_SPEED_FULL] = 64,
+	.mps[USB_SPEED_HIGH] = 512,
+static const struct usb_temp_packet_size intr_mps = {
+	.mps[USB_SPEED_FULL] = 8,
+	.mps[USB_SPEED_HIGH] = 8,
+static const struct usb_temp_endpoint_desc bulk_in_ep = {
+	.pPacketSize = &bulk_mps,
+#ifdef USB_HIP_IN_EP_0
+	.bEndpointAddress = USB_HIP_IN_EP_0,
+#else
+	.bEndpointAddress = UE_DIR_IN,
+#endif
+	.bmAttributes = UE_BULK,
+static const struct usb_temp_endpoint_desc bulk_out_ep = {
+#ifdef USB_HIP_OUT_EP_0
+	.bEndpointAddress = USB_HIP_OUT_EP_0,
+#else
+	.bEndpointAddress = UE_DIR_OUT,
+#endif
+static const struct usb_temp_endpoint_desc intr_in_ep = {
+	.pPacketSize = &intr_mps,
+	.bmAttributes = UE_INTERRUPT,
+static const struct usb_temp_endpoint_desc *eth_intr_endpoints[] = {
+	&intr_in_ep,
+	NULL,
+static const struct usb_temp_interface_desc eth_control_interface = {
+	.ppEndpoints = eth_intr_endpoints,
+	.ppRawDesc = eth_control_if_desc,
+	.bInterfaceClass = UICLASS_CDC,
+	.bInterfaceSubClass = UISUBCLASS_ETHERNET_NETWORKING_CONTROL_MODEL,
+	.bInterfaceProtocol = 0,
+	.iInterface = ETH_CONTROL_INDEX,
+static const struct usb_temp_endpoint_desc *eth_data_endpoints[] = {
+	&bulk_in_ep,
+	&bulk_out_ep,
+	NULL,
+static const struct usb_temp_interface_desc eth_data_null_interface = {
+	.ppEndpoints = NULL,		/* no endpoints */
+	.bInterfaceClass = UICLASS_CDC_DATA,
+	.bInterfaceSubClass = 0,
+	.iInterface = ETH_DATA_INDEX,
+static const struct usb_temp_interface_desc eth_data_interface = {
+	.ppEndpoints = eth_data_endpoints,
+	.bInterfaceSubClass = UISUBCLASS_DATA,
+	.isAltInterface = 1,		/* this is an alternate setting */
+static const struct usb_temp_interface_desc *eth_interfaces[] = {
+	&eth_control_interface,
+	&eth_data_null_interface,
+	&eth_data_interface,
+	NULL,
+static const struct usb_temp_config_desc eth_config_desc = {
+	.ppIfaceDesc = eth_interfaces,
+	.bmAttributes = 0,
+	.bMaxPower = 0,
+	.iConfiguration = ETH_CONFIGURATION_INDEX,
+static const struct usb_temp_config_desc *eth_configs[] = {
+	&eth_config_desc,
+	NULL,
+struct usb_temp_device_desc usb_template_cdce = {
+	.getStringDesc = &eth_get_string_desc,
+	.ppConfigDesc = eth_configs,
+	.idVendor = ETH_DEFAULT_VENDOR_ID,
+	.idProduct = ETH_DEFAULT_PRODUCT_ID,
+	.bcdDevice = 0x0100,
+	.bDeviceClass = UDCLASS_COMM,
+	.bDeviceSubClass = 0,
+	.bDeviceProtocol = 0,
+	.iManufacturer = ETH_MANUFACTURER_INDEX,
+	.iProduct = ETH_PRODUCT_INDEX,
+	.iSerialNumber = ETH_SERIAL_NUMBER_INDEX,
+ *	eth_get_string_desc
+ * Return values:
+ * NULL: Failure. No such string.
+ * Else: Success. Pointer to string descriptor is returned.
+eth_get_string_desc(uint16_t lang_id, uint8_t string_index)
+	static const void *ptr[ETH_MAX_INDEX] = {
+		[ETH_LANG_INDEX] = &usb_string_lang_en,
+		[ETH_MAC_INDEX] = &eth_mac,
+		[ETH_CONTROL_INDEX] = &eth_control,
+		[ETH_DATA_INDEX] = &eth_data,
+		[ETH_CONFIGURATION_INDEX] = &eth_configuration,
+		[ETH_MANUFACTURER_INDEX] = &eth_manufacturer,
+		[ETH_PRODUCT_INDEX] = &eth_product,
+		[ETH_SERIAL_NUMBER_INDEX] = &eth_serial_number,
+	if (string_index == 0) {
+		return (&usb_string_lang_en);
+	if (lang_id != 0x0409) {
+		return (NULL);
+	if (string_index < ETH_MAX_INDEX) {
+		return (ptr[string_index]);
+	return (NULL);
+static void
+eth_init(void *arg __unused)
+	struct sysctl_oid *parent;
+	char parent_name[3];
+	usb_make_str_desc(&eth_mac, sizeof(eth_mac),
+	    ETH_DEFAULT_MAC);
+	usb_make_str_desc(&eth_control, sizeof(eth_control),
+	    ETH_DEFAULT_CONTROL);
+	usb_make_str_desc(&eth_data, sizeof(eth_data),
+	    ETH_DEFAULT_DATA);
+	usb_make_str_desc(&eth_configuration, sizeof(eth_configuration),
+	    ETH_DEFAULT_CONFIG);
+	usb_make_str_desc(&eth_manufacturer, sizeof(eth_manufacturer),
+	    ETH_DEFAULT_MANUFACTURER);
+	usb_make_str_desc(&eth_product, sizeof(eth_product),
+	    ETH_DEFAULT_PRODUCT);
+	usb_make_str_desc(&eth_serial_number, sizeof(eth_serial_number),
+	    ETH_DEFAULT_SERIAL_NUMBER);
+	snprintf(parent_name, sizeof(parent_name), "%d", USB_TEMP_CDCE);
+	sysctl_ctx_init(&eth_ctx_list);
+	parent = SYSCTL_ADD_NODE(&eth_ctx_list,
+	    SYSCTL_STATIC_CHILDREN(_hw_usb_templates), OID_AUTO,
+	    parent_name, CTLFLAG_RW,
+	    0, "USB CDC Ethernet device side template");
+	SYSCTL_ADD_U16(&eth_ctx_list, SYSCTL_CHILDREN(parent), OID_AUTO,
+	    "vendor_id", CTLFLAG_RWTUN,
+	    &usb_template_cdce.idVendor, 1, "Vendor identifier");
+	    "product_id", CTLFLAG_RWTUN,
+	    &usb_template_cdce.idProduct, 1, "Product identifier");
+	SYSCTL_ADD_PROC(&eth_ctx_list, SYSCTL_CHILDREN(parent), OID_AUTO,
+	    "mac", CTLTYPE_STRING | CTLFLAG_RWTUN | CTLFLAG_MPSAFE,
+	    &eth_mac, sizeof(eth_mac), usb_temp_sysctl,
+	    "A", "MAC address string");
+#if 0
+	    "control", CTLTYPE_STRING | CTLFLAG_RWTUN | CTLFLAG_MPSAFE,
+	    &eth_control, sizeof(eth_control), usb_temp_sysctl,
+	    "A", "Control interface string");
+	    "data", CTLTYPE_STRING | CTLFLAG_RWTUN | CTLFLAG_MPSAFE,
+	    &eth_data, sizeof(eth_data), usb_temp_sysctl,
+	    "A", "Data interface string");
+	    "configuration", CTLTYPE_STRING | CTLFLAG_RWTUN | CTLFLAG_MPSAFE,
+	    &eth_configuration, sizeof(eth_configuration), usb_temp_sysctl,
+	    "A", "Configuration string");
+#endif
+	    "manufacturer", CTLTYPE_STRING | CTLFLAG_RWTUN | CTLFLAG_MPSAFE,
+	    &eth_manufacturer, sizeof(eth_manufacturer), usb_temp_sysctl,
+	    "A", "Manufacturer string");
+	    "product", CTLTYPE_STRING | CTLFLAG_RWTUN | CTLFLAG_MPSAFE,
+	    &eth_product, sizeof(eth_product), usb_temp_sysctl,
+	    "A", "Product string");
+	    "serial_number", CTLTYPE_STRING | CTLFLAG_RWTUN | CTLFLAG_MPSAFE,
+	    &eth_serial_number, sizeof(eth_serial_number), usb_temp_sysctl,
+	    "A", "Serial number string");
+static void
+eth_uninit(void *arg __unused)
+	sysctl_ctx_free(&eth_ctx_list);
+SYSINIT(eth_init, SI_SUB_LOCK, SI_ORDER_FIRST, eth_init, NULL);
+SYSUNINIT(eth_uninit, SI_SUB_LOCK, SI_ORDER_FIRST, eth_uninit, NULL);
2.25.1
