[PATCH rtems-libbsd 3/4] nexus-devices: Include CDC Ethernet for Beagle
Husni Faiz
ahamedhusni73 at gmail.com
Tue Jul 6 17:00:33 UTC 2021
Configure bus for CDC Ethernet
Include CDC Ethernet in Beagle BSP
Signed-off-by: Husni Faiz <ahamedhusni73 at gmail.com>
rtemsbsd/include/bsp/nexus-devices.h | 5 +++++
rtemsbsd/include/machine/rtems-bsd-nexus-bus.h | 17 +++++++++++++++++
2 files changed, 22 insertions(+)
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index e6487470..6a35632e 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -83,6 +83,11 @@ SYSINIT_REFERENCE(rtwn_rtl8188eufw);
RTEMS_BSD_DRIVER_USB;
RTEMS_BSD_DRIVER_USB_MASS;
+#ifdef RTEMS_BSD_MODULE_DEV_USB_TEMPLATE
+RTEMS_BSD_DRIVER_USB_TEMPLATE;
+RTEMS_BSD_DRIVER_CDCE;
+#endif
#elif defined(LIBBSP_ARM_LPC32XX_BSP_H)
#include <bsp/irq.h>
diff --git a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
index 50a43873..84f561f5 100644
--- a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
+++ b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
@@ -282,6 +282,15 @@ extern "C" {
SYSINIT_DRIVER_REFERENCE(umass, uhub)
#endif /* RTEMS_BSD_DRIVER_USB_MASS */
+ * USB Template base driver.
+#if !defined(RTEMS_BSD_DRIVER_USB_TEMPLATE)
+ #define RTEMS_BSD_DRIVER_USB_TEMPLATE \
+ SYSINIT_REFERENCE(usb_temp_init); \
+ SYSINIT_DRIVER_REFERENCE(usb_template, usb)
+#endif /* RTEMS_BSD_DRIVER_USB_TEMPLATE */
* USB SAF1761 host controller driver.
@@ -490,6 +499,14 @@ extern "C" {
SYSINIT_DRIVER_REFERENCE(re, pci);
#endif /* RTEMS_BSD_DRIVER_PCI_RE */
+ * CDC Ethernet Driver.
+#if !defined(RTEMS_BSD_DRIVER_CDCE)
+ #define RTEMS_BSD_DRIVER_CDCE \
+ SYSINIT_DRIVER_REFERENCE(cdce, uhub);
+#endif /* RTEMS_BSD_DRIVER_FEC */
** MMI Physical Layer Support.
2.25.1
