[PATCH rtems-libbsd 3/4] nexus-devices: Include CDC Ethernet for Beagle
Christian Mauderer oss at c-mauderer.de
Thu Jul 15 19:55:09 UTC 2021
On 06/07/2021 19:00, Husni Faiz wrote:
> Configure bus for CDC Ethernet
> Include CDC Ethernet in Beagle BSP
> Signed-off-by: Husni Faiz <ahamedhusni73 at gmail.com>
>   rtemsbsd/include/bsp/nexus-devices.h           |  5 +++++
>   rtemsbsd/include/machine/rtems-bsd-nexus-bus.h | 17 +++++++++++++++++
>   2 files changed, 22 insertions(+)
> diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
> index e6487470..6a35632e 100644
> --- a/rtemsbsd/include/bsp/nexus-devices.h
> +++ b/rtemsbsd/include/bsp/nexus-devices.h
> @@ -83,6 +83,11 @@ SYSINIT_REFERENCE(rtwn_rtl8188eufw);
>   RTEMS_BSD_DRIVER_USB;
>   RTEMS_BSD_DRIVER_USB_MASS;
> +#ifdef RTEMS_BSD_MODULE_DEV_USB_TEMPLATE
> +RTEMS_BSD_DRIVER_USB_TEMPLATE;
> +RTEMS_BSD_DRIVER_CDCE;
> +#endif
Same like in patch 2: Shouldn't there be an include for
rtems/bsd/modules.h somewhere?
>   #elif defined(LIBBSP_ARM_LPC32XX_BSP_H)
>   #include <bsp/irq.h>
> diff --git a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> index 50a43873..84f561f5 100644
> --- a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> +++ b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
> @@ -282,6 +282,15 @@ extern "C" {
>       SYSINIT_DRIVER_REFERENCE(umass, uhub)
>   #endif /* RTEMS_BSD_DRIVER_USB_MASS */
> + * USB Template base driver.
> +#if !defined(RTEMS_BSD_DRIVER_USB_TEMPLATE)
> +  #define RTEMS_BSD_DRIVER_USB_TEMPLATE           \
> +    SYSINIT_REFERENCE(usb_temp_init);             \
> +    SYSINIT_DRIVER_REFERENCE(usb_template, usb)
> +#endif /* RTEMS_BSD_DRIVER_USB_TEMPLATE */
>    * USB SAF1761 host controller driver.
> @@ -490,6 +499,14 @@ extern "C" {
>       SYSINIT_DRIVER_REFERENCE(re, pci);
>   #endif /* RTEMS_BSD_DRIVER_PCI_RE */
> + * CDC Ethernet Driver.
> +#if !defined(RTEMS_BSD_DRIVER_CDCE)
> +  #define RTEMS_BSD_DRIVER_CDCE                   \
> +    SYSINIT_DRIVER_REFERENCE(cdce, uhub);
> +#endif /* RTEMS_BSD_DRIVER_FEC */
>    ** MMI Physical Layer Support.
