[PATCH] covoar: Fix errors building on FreeBSD and clang
Wed Jul 7 00:55:39 UTC 2021
On 3/7/21 5:56 am, Alex White wrote:
> On Wed, Jun 30, 2021 at 11:40 PM <chrisj at rtems.org> wrote:
>> From: Chris Johns <chrisj at rtems.org>
>> - The member variable `path_` cannot be a reference and initialised to
>>   a const char* type input. To do so would require there is a temporary with
>>   an unspecified life time.
>>  tester/covoar/AddressToLineMapper.h | 2 +-
>>  tester/covoar/Target_aarch64.h      | 2 +-
>>  2 files changed, 2 insertions(+), 2 deletions(-)
>> diff --git a/tester/covoar/AddressToLineMapper.h
> b/tester/covoar/AddressToLineMapper.h
>> index 88bf475..c78aef7 100644
>> --- a/tester/covoar/AddressToLineMapper.h
>> +++ b/tester/covoar/AddressToLineMapper.h
>> @@ -84,7 +84,7 @@ namespace Coverage {
>>       *  An iterator pointing to the location in the set that contains the
>>       *  source file path of the address.
>> -    const std::string& path_;
>> +    const std::string path_;
> Ryan alerted me about this issue a couple weeks back. This patch would fix the
> problem, but it would lead to a second copy of every file path string being
> stored in memory. This would also take away the usefulness of the set of file
> path strings maintained by the AddressLineRange class.
> Instead, I propose we change the empty SourceLine constructor to take a `const
> std::string&`. This would allow the addition of something like this to the top
> of AddressToLineMapper::getSource():
> const std::string unknown = "unknown";
> const SourceLine default_sourceline = SourceLine(unknown);
> That should eliminate the issue and preserve the memory conservation efforts of
> the original design.
Yes it would but for some reason, that I cannot put my finger on, it seems like
a breach of boundaries between classes.
How much data are we talking about? Are you able to see the memory foot print
with the strings being contained vs what you have now?
If the figures show the strings need to be shared to avoid a memory blow out
would a std::shared_ptr<std::string> be something to look at where all
references are a shared pointer? A shared pointer means any changes do not flow
from one class to other.
