[PATCH] covoar: Fix errors building on FreeBSD and clang
Alex White
alex.white at oarcorp.com
Thu Jul 15 02:45:01 UTC 2021
On Tue, Jul 6, 2021 at 7:55 PM Chris Johns <chrisj at rtems.org> wrote:
> On 3/7/21 5:56 am, Alex White wrote:
> > On Wed, Jun 30, 2021 at 11:40 PM <chrisj at rtems.org> wrote:
> >> From: Chris Johns <chrisj at rtems.org>
> >> - The member variable `path_` cannot be a reference and initialised to
> >> a const char* type input. To do so would require there is a temporary with
> >> an unspecified life time.
> >> tester/covoar/AddressToLineMapper.h | 2 +-
> >> tester/covoar/Target_aarch64.h | 2 +-
> >> 2 files changed, 2 insertions(+), 2 deletions(-)
> >> diff --git a/tester/covoar/AddressToLineMapper.h
> > b/tester/covoar/AddressToLineMapper.h
> >> index 88bf475..c78aef7 100644
> >> --- a/tester/covoar/AddressToLineMapper.h
> >> +++ b/tester/covoar/AddressToLineMapper.h
> >> @@ -84,7 +84,7 @@ namespace Coverage {
> >> * An iterator pointing to the location in the set that contains the
> >> * source file path of the address.
> >> - const std::string& path_;
> >> + const std::string path_;
> > Ryan alerted me about this issue a couple weeks back. This patch would fix the
> > problem, but it would lead to a second copy of every file path string being
> > stored in memory. This would also take away the usefulness of the set of file
> > path strings maintained by the AddressLineRange class.
> > Instead, I propose we change the empty SourceLine constructor to take a `const
> > std::string&`. This would allow the addition of something like this to the top
> > of AddressToLineMapper::getSource():
> > const std::string unknown = "unknown";
> > const SourceLine default_sourceline = SourceLine(unknown);
> > That should eliminate the issue and preserve the memory conservation efforts of
> > the original design.
> Yes it would but for some reason, that I cannot put my finger on, it seems like
> a breach of boundaries between classes.
> How much data are we talking about? Are you able to see the memory foot print
> with the strings being contained vs what you have now?
Sorry for the late reply.
What I have now yields a peak memory usage for covoar when run on all ARM tests of 219 MB.
Changing `SourceLine::path_` to plain `std::string` results in an increase to 523 MB.
So it is a significant increase.
> If the figures show the strings need to be shared to avoid a memory blow out
> would a std::shared_ptr<std::string> be something to look at where all
> references are a shared pointer? A shared pointer means any changes do not flow
> from one class to other.
I don't think that `std::shared_ptr` would help here. Wouldn't that handle the case of an unknown path the same way as a raw pointer solution? Wouldn't we still have to check the return value of `SourceLine::path()` to make sure that it is not null?
The only other way I see to make it work would be to store some "unknown" string object and hand pointers to it to all `SourceLine` objects with unknown paths. But that seems mostly equivalent to what I propose in my original reply to this patch.
Now that I think about it, maybe making `SourceLine::_path` into an `std::string*` and doing a `nullptr` check in the `SourceLine::path()` would be most elegant?
That way we don't have to do any `nullptr` checks outside of the `SourceLine` implementation. We could just have `SourceLine::path()` return a plain old `std::string` and do something like this:
if (_path == nullptr) {
return "unknown";
else {
return *_path;
Alex
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210715/b061d686/attachment.html>
