[PATCH 2/2] testsuites: Edited tests for sig2str/str2sig methods
Matt Joyce mfjoyce2004 at gmail.com
Wed Jul 7 10:55:59 UTC 2021
Added additional tests to init.c and added psxsignal09.scn and
psxsignal09.doc to conform to RTEMS standards.
 testsuites/psxtests/Makefile.am               |   2 +
 testsuites/psxtests/psxsignal09/init.c        | 207 +++++++++++++-----
 .../psxtests/psxsignal09/psxsignal09.doc      |  34 +++
 .../psxtests/psxsignal09/psxsignal09.scn      |  31 +++
 4 files changed, 223 insertions(+), 51 deletions(-)
 create mode 100644 testsuites/psxtests/psxsignal09/psxsignal09.doc
 create mode 100644 testsuites/psxtests/psxsignal09/psxsignal09.scn
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index b50c9b97cb..b62d5cab59 100755
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -927,6 +927,8 @@ endif
 if HAS_POSIX
 if TEST_psxsignal09
 psx_tests += psxsignal09
+psx_screens += psxsignal09/psxsignal09.scn
+psx_docs += psxsignal09/psxsignal09.doc
 psxsignal09_SOURCES = psxsignal09/init.c
 psxsignal09_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxsignal09) \
 	$(support_includes) -I$(top_srcdir)/include
diff --git a/testsuites/psxtests/psxsignal09/init.c b/testsuites/psxtests/psxsignal09/init.c
index 02ad8a9e45..7025b471aa 100644
--- a/testsuites/psxtests/psxsignal09/init.c
+++ b/testsuites/psxtests/psxsignal09/init.c
@@ -48,7 +48,7 @@
 //#include <sys/signal.h>
-const char rtems_test_name[] = "SIG2STR AND STR2SIG TEST";
+const char rtems_test_name[] = "SIG2STR AND STR2SIG";
 static rtems_task Init(
   rtems_task_argument ignored
@@ -56,72 +56,177 @@ static rtems_task Init(
   rtems_print_printer_fprintf_putc(&rtems_test_printer);
   TEST_BEGIN();
-  printf( "SIG2STR AND STR2SIG TEST\n" );
   char test1[SIG2STR_MAX];
   char test2[SIG2STR_MAX];
   char test3[SIG2STR_MAX];
   char test4[SIG2STR_MAX];
+  char test5[SIG2STR_MAX];
+  char test6[SIG2STR_MAX];
+  char test7[SIG2STR_MAX];
+  char test8[SIG2STR_MAX];
+  char test9[SIG2STR_MAX];
   int res1;
   int res2;
   int res3;
   int res4;
+  int res5;
+  int res6;
+  int res7;
+  int res8;
+  int res9;
   int retval1;
   int retval2;
   int retval3;
   int retval4;
+  int retval5;
+  int retval6;
+  int retval7;
+  int retval8;
+  int retval9;
   int min = SIGRTMIN;
   int max = SIGRTMAX;
-  printf( "sigrtmin is %d and sigrtmax is %d\n", min, max );
-  printf("Calling sig2str: \n");
-  sig2str(31, test1);
-  sig2str(9, test2);
-  sig2str(29, test3);
-  sig2str(2147483647, test4);
-  printf("test1 is now: %s\n", test1);
-  printf("test2 is now: %s\n", test2);
-  printf("test3 is now: %s\n", test3);
-  printf("test4 is now: %s\n", test4);
-  printf("Calling str2sig: \n");
-  retval1 = str2sig("19", &res1);
-  retval2 = str2sig("TSTP", &res2);
-  retval3 = str2sig("RTMIN+12", &res3);
-  retval4 = str2sig("RTMAX-2", &res4);
-  printf("The result of the first call is: %d\n", res1);
-  printf("The second result of the second call is: %d\n", res2);
-  printf("The second result of the third call is: %d\n", res3);
-  printf("The second result of the fourth call is: %d\n", res4);
-  // T_TEST_CASE(a_test_case)
-  //   T_eq_int(res1, 19);
-  printf("retval1 is %d\n", retval1);
-  printf("retval2 is %d\n", retval2);
-  printf("retval3 is %d\n", retval3);
-  printf("retval4 is %d\n", retval4);
-  /* Testing a call to str2sig using a previously successful call to sig2str.
-  * value in pnum should equal signum*/
-  printf("\n");
-  str2sig(test1, &res1);
-  str2sig(test2, &res2);
-  str2sig(test3, &res3);
-  rtems_test_assert(res1 == 31);
-  printf("res1 should equal 31. It is: %d\n", res1);
-  rtems_test_assert(res2 == 9);
-  printf("res2 should equal 9. It is: %d\n", res2);
-  rtems_test_assert(res3 == 29);
-  printf("res3 should equal 29. It is: %d\n", res3);
+  printf( "\n" );
+  printf( "SIGRTMIN is %d and SIGRTMAX is %d\n", min, max );
+  printf( "\n" );
+  printf( "Calling sig2str: \n" );
+  /* Expected pass */
+  retval1 = sig2str( 1, test1 );
+  rtems_test_assert( retval1 == 0 );
+  rtems_test_assert( strcmp( test1, "HUP" )==0 );
+  printf( "The string test1 is: %s\n", test1 );
+  retval2 = sig2str( 3, test2 );
+  rtems_test_assert( retval2 == 0 );
+  rtems_test_assert( strcmp( test2, "QUIT" )==0);
+  printf( "The string test2 is: %s\n", test2 );
+  retval3 = sig2str( 27, test3 );
+  rtems_test_assert( retval3 == 0 );
+  rtems_test_assert( strcmp( test3, "RTMIN" )==0 );
+  printf( "The string test3 is: %s\n", test3 );
+  retval4 = sig2str( 29, test4 );
+  rtems_test_assert( retval4 == 0 );
+  rtems_test_assert( strcmp( test4, "RTMIN+2" )==0 );
+  printf( "The string test4 is: %s\n", test4 );
+  retval5 = sig2str( 31, test5 );
+  rtems_test_assert( retval5 == 0 );
+  rtems_test_assert( strcmp( test5, "RTMAX" )==0);
+  printf( "The string test5 is: %s\n", test5 );
+  retval6 = sig2str( 30, test6 );
+  rtems_test_assert( retval6 == 0 );
+  rtems_test_assert( strcmp( test6, "RTMAX-1" )==0);
+  printf( "The string test6 is: %s\n", test6 );
+  retval7 = sig2str( 9, test7 );
+  rtems_test_assert( retval7 == 0 );
+  rtems_test_assert(strcmp( test7, "KILL" )==0);
+  printf( "The string test7 is: %s\n", test7 );
+  /* Expected fail, invalid signal number */
+  retval8 = sig2str( 200, test8 );
+  rtems_test_assert( retval8 == -1);
+  rtems_test_assert( strcmp( test8, "Unknown signal 200" )==0);
+  printf( "The string test8 is: %s\n", test8 );
+  /* Expected fail, if signum is 0 the output is unspecified */
+  retval9 = sig2str( 0, test9 );
+  rtems_test_assert( retval9 == -1 );
+  printf( "The string test9 is: %s\n", test9 );
+  printf( "\n" );
+  printf( "Calling str2sig: \n" );
+  retval1 = str2sig( "PIPE", &res1 );
+  rtems_test_assert( retval1 == 0);
+  rtems_test_assert( res1 == 13 );
+  printf( "Result 1 is: %d\n", res1 );
+  retval2 = str2sig( "TSTP", &res2 );
+  rtems_test_assert( retval2 == 0);
+  rtems_test_assert( res2 == 18 );
+  printf( "Result 2 is: %d\n", res2 );
+  retval3 = str2sig( "KILL", &res3 );
+  rtems_test_assert( retval3 == 0);
+  rtems_test_assert( res3 == 9 );
+  printf( "Result 3 is: %d\n", res3 );
+  /* Expected pass, String representation of integer */
+  retval4 = str2sig( "10", &res4 );
+  rtems_test_assert( retval4 == 0);
+  rtems_test_assert( res4 == 10 );
+  printf( "Result 4 is: %d\n", res4 );
+  retval5 = str2sig( "RTMIN", &res5 );
+  rtems_test_assert( retval5 == 0);
+  rtems_test_assert( res5 == 27 );
+  printf( "Result 5 is: %d\n", res5 );
+  retval6 = str2sig( "RTMIN+1", &res6 );
+  rtems_test_assert( retval6 == 0);
+  rtems_test_assert( res6 == 28 );
+  printf( "Result 6 is: %d\n", res6 );
+  retval7 = str2sig( "RTMAX-2", &res7 );
+  rtems_test_assert( retval7 == 0);
+  rtems_test_assert( res7 == 29 );
+  printf( "Result 7 is: %d\n", res7 );
+  /* Expected fail, invalid signal name */
+  retval8 = str2sig( "BOSS", &res8 );
+  printf( "Result 8 is: %d\n", res8 );
+  retval9 = str2sig( "RTMIN+1000", &res9 );
+  rtems_test_assert( retval9 == -1);
+  printf( "Result 9 is: %d\n", res9 );
+  printf( "\n" );
+  printf( "Calling str2sig using the result from previous call to sig2str\n" );
+  retval1 = str2sig( test1, &res1 );
+  rtems_test_assert( res1 == 1 );
+  retval2 = str2sig( test2, &res2 );
+  rtems_test_assert( res2 == 3 );
+  retval3 = str2sig( test3, &res3 );
+  rtems_test_assert( res3 == 27 );
+  /* Expected fail, calling using string from invalid sig2str call */
+  retval4 = str2sig( test8, &res4 );
+  rtems_test_assert( retval4 == -1 );
   TEST_END();
   rtems_test_exit( 0 );
diff --git a/testsuites/psxtests/psxsignal09/psxsignal09.doc b/testsuites/psxtests/psxsignal09/psxsignal09.doc
new file mode 100644
index 0000000000..0f11061c4d
--- /dev/null
+++ b/testsuites/psxtests/psxsignal09/psxsignal09.doc
@@ -0,0 +1,34 @@
+ * @file
+ * @brief Test of sig2str and str2sig methods
+ * This test file is used to verify that the methods sig2str and str2sig
+ * are functioning as expected
+ * Copyright (C) 2021 Matthew Joyce
+ * are met:
\ No newline at end of file
diff --git a/testsuites/psxtests/psxsignal09/psxsignal09.scn b/testsuites/psxtests/psxsignal09/psxsignal09.scn
index 0000000000..632e152e9b
--- /dev/null
+++ b/testsuites/psxtests/psxsignal09/psxsignal09.scn
@@ -0,0 +1,31 @@
+*** BEGIN OF TEST SIG2STR AND STR2SIG ***
+SIGRTMIN is 27 and SIGRTMAX is 31
+Calling sig2str:
+The string test1 is: HUP
+The string test2 is: QUIT
+The string test3 is: RTMIN
+The string test4 is: RTMIN+2
+The string test5 is: RTMAX
+The string test6 is: RTMAX-1
+The string test7 is: KILL
+The string test8 is: Unknown signal 200
+The string test9 is: Unknown signal 0
+Calling str2sig:
+Result 1 is: 13
+Result 2 is: 18
+Result 3 is: 9
+Result 4 is: 10
+Result 5 is: 27
+Result 6 is: 28
+Result 7 is: 29
+Result 8 is: 0
+Result 9 is: 0
+Calling str2sig using the result from previous call to sig2str
+Result 1 is: 1
+Result 2 is: 3
+Result 3 is: 27
+*** END OF TEST SIG2STR AND STR2SIG ***
2.31.1
