[PATCH 1/2] testsuites: Added tests for sig2str/str2sig methods
Matt Joyce
mfjoyce2004 at gmail.com
Wed Jul 7 10:55:58 UTC 2021
Added psxsignal09 in psxtests and compile only test in psxhdrs in order to evaluate
newly added POSIX standard methods in Newlib.
spec/build/testsuites/psxtests/grp.yml | 2 +
spec/build/testsuites/psxtests/libpsxhdrs.yml | 1 +
.../build/testsuites/psxtests/psxsignal09.yml | 20 +++
testsuites/psxtests/Makefile.am | 9 ++
testsuites/psxtests/configure.ac | 1 +
testsuites/psxtests/psxhdrs/signal/sig2str.c | 57 +++++++
testsuites/psxtests/psxsignal09/init.c | 143 ++++++++++++++++++
7 files changed, 233 insertions(+)
create mode 100644 spec/build/testsuites/psxtests/psxsignal09.yml
create mode 100644 testsuites/psxtests/psxhdrs/signal/sig2str.c
create mode 100644 testsuites/psxtests/psxsignal09/init.c
diff --git a/spec/build/testsuites/psxtests/grp.yml b/spec/build/testsuites/psxtests/grp.yml
index fb7ce465ae..f61f45dbe9 100644
--- a/spec/build/testsuites/psxtests/grp.yml
+++ b/spec/build/testsuites/psxtests/grp.yml
@@ -205,6 +205,8 @@ links:
uid: psxsignal07
- role: build-dependency
uid: psxsignal08
+- role: build-dependency
+ uid: psxsignal09
uid: psxspin01
diff --git a/spec/build/testsuites/psxtests/libpsxhdrs.yml b/spec/build/testsuites/psxtests/libpsxhdrs.yml
index 6a0ab6d4f7..5767bcdacd 100644
--- a/spec/build/testsuites/psxtests/libpsxhdrs.yml
+++ b/spec/build/testsuites/psxtests/libpsxhdrs.yml
@@ -513,6 +513,7 @@ source:
- testsuites/psxtests/psxhdrs/signal/sigtimedwait.c
- testsuites/psxtests/psxhdrs/signal/sigwait.c
- testsuites/psxtests/psxhdrs/signal/sigwaitinfo.c
+- testsuites/psxtests/psxhdrs/signal/sig2str.c
- testsuites/psxtests/psxhdrs/stddef/offsetof.c
- testsuites/psxtests/psxhdrs/stdio/clearerr.c
- testsuites/psxtests/psxhdrs/stdio/ctermid.c
diff --git a/spec/build/testsuites/psxtests/psxsignal09.yml b/spec/build/testsuites/psxtests/psxsignal09.yml
new file mode 100644
index 0000000000..5c9a16a7fc
--- /dev/null
+++ b/spec/build/testsuites/psxtests/psxsignal09.yml
@@ -0,0 +1,20 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by:
+- RTEMS_POSIX_API
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/psxtests/psxsignal09/init.c
+stlib: []
+target: testsuites/psxtests/psxsignal09.exe
+type: build
+use-after: []
+use-before: []
\ No newline at end of file
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index a35f00b665..b50c9b97cb 100755
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -924,6 +924,15 @@ psxsignal08_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxsignal08) \
endif
endif
+if HAS_POSIX
+if TEST_psxsignal09
+psx_tests += psxsignal09
+psxsignal09_SOURCES = psxsignal09/init.c
+psxsignal09_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxsignal09) \
+ $(support_includes) -I$(top_srcdir)/include
+endif
+endif
if TEST_psxspin01
psx_tests += psxspin01
psx_screens += psxspin01/psxspin01.scn
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 3f95010cd3..7b9a1027ca 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -138,6 +138,7 @@ RTEMS_TEST_CHECK([psxsignal05])
RTEMS_TEST_CHECK([psxsignal06])
RTEMS_TEST_CHECK([psxsignal07])
RTEMS_TEST_CHECK([psxsignal08])
+RTEMS_TEST_CHECK([psxsignal09])
RTEMS_TEST_CHECK([psxspin01])
RTEMS_TEST_CHECK([psxstack01])
RTEMS_TEST_CHECK([psxstack02])
diff --git a/testsuites/psxtests/psxhdrs/signal/sig2str.c b/testsuites/psxtests/psxhdrs/signal/sig2str.c
index 0000000000..520a0db740
--- /dev/null
+++ b/testsuites/psxtests/psxhdrs/signal/sig2str.c
@@ -0,0 +1,57 @@
+ * @file
+ * @brief Header File Conformance Test
+ * This test file is used to verify that the header files associated with
+ * invoking this function are correct.
+ * Copyright (C) 2021 Matthew Joyce
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <signal.h>
+#define BUFLEN 10
+int test( void );
+int test( void )
+ int result;
+ int signal_number;
+ char signal_name[BUFLEN];
+ signal_number = SIGALRM;
+ result = sig2str(signal_number, signal_name);
+ return result;
diff --git a/testsuites/psxtests/psxsignal09/init.c b/testsuites/psxtests/psxsignal09/init.c
index 0000000000..02ad8a9e45
--- /dev/null
+++ b/testsuites/psxtests/psxsignal09/init.c
@@ -0,0 +1,143 @@
+ * @file
+ * @brief Test of sig2str and str2sig methods
+ * This test file is used to verify that the methods sig2str and str2sig
+ * are functioning as expected
+ * are met:
+/* Defined to have access to SIG2STR_MAX and function prototypes in signal.h*/
+#define _GNU_SOURCE
+#endif
+#include <rtems.h>
+#include <tmacros.h>
+#include <rtems/test.h>
+#include "test_support.h"
+//#include <sys/signal.h>
+const char rtems_test_name[] = "SIG2STR AND STR2SIG TEST";
+static rtems_task Init(
+ rtems_task_argument ignored
+ rtems_print_printer_fprintf_putc(&rtems_test_printer);
+ TEST_BEGIN();
+ printf( "SIG2STR AND STR2SIG TEST\n" );
+ char test1[SIG2STR_MAX];
+ char test2[SIG2STR_MAX];
+ char test3[SIG2STR_MAX];
+ char test4[SIG2STR_MAX];
+ int res1;
+ int res2;
+ int res3;
+ int res4;
+ int retval1;
+ int retval2;
+ int retval3;
+ int retval4;
+ int min = SIGRTMIN;
+ int max = SIGRTMAX;
+ printf( "sigrtmin is %d and sigrtmax is %d\n", min, max );
+ printf("Calling sig2str: \n");
+ sig2str(31, test1);
+ sig2str(9, test2);
+ sig2str(29, test3);
+ sig2str(2147483647, test4);
+ printf("test1 is now: %s\n", test1);
+ printf("test2 is now: %s\n", test2);
+ printf("test3 is now: %s\n", test3);
+ printf("test4 is now: %s\n", test4);
+ printf("Calling str2sig: \n");
+ retval1 = str2sig("19", &res1);
+ retval2 = str2sig("TSTP", &res2);
+ retval3 = str2sig("RTMIN+12", &res3);
+ retval4 = str2sig("RTMAX-2", &res4);
+ printf("The result of the first call is: %d\n", res1);
+ printf("The second result of the second call is: %d\n", res2);
+ printf("The second result of the third call is: %d\n", res3);
+ printf("The second result of the fourth call is: %d\n", res4);
+ // T_TEST_CASE(a_test_case)
+ // T_eq_int(res1, 19);
+ printf("retval1 is %d\n", retval1);
+ printf("retval2 is %d\n", retval2);
+ printf("retval3 is %d\n", retval3);
+ printf("retval4 is %d\n", retval4);
+ /* Testing a call to str2sig using a previously successful call to sig2str.
+ * value in pnum should equal signum*/
+ printf("\n");
+ str2sig(test1, &res1);
+ str2sig(test2, &res2);
+ str2sig(test3, &res3);
+ rtems_test_assert(res1 == 31);
+ printf("res1 should equal 31. It is: %d\n", res1);
+ rtems_test_assert(res2 == 9);
+ printf("res2 should equal 9. It is: %d\n", res2);
+ rtems_test_assert(res3 == 29);
+ printf("res3 should equal 29. It is: %d\n", res3);
+ TEST_END();
+ rtems_test_exit( 0 );
+/* NOTICE: the clock driver is explicitly disabled */
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#include <rtems/confdefs.h>
2.31.1
