[PATCH 1/2] libc: Added implementations for sig2str/str2sig
Matthew Joyce
mfjoyce2004 at gmail.com
Wed Jul 7 15:18:28 UTC 2021
On Wed, Jul 7, 2021 at 4:04 PM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Jul 7, 2021 at 5:46 AM Matt Joyce <mfjoyce2004 at gmail.com> wrote:
> > Added function implementations for sig2str() and str2sig() in libc/signal in order
> > to improve POSIX compliance.
> > newlib/libc/signal/sig2str.c | 156 +++++++++++++++++++++++++++++++++++
> > 1 file changed, 156 insertions(+)
> > create mode 100644 newlib/libc/signal/sig2str.c
> > diff --git a/newlib/libc/signal/sig2str.c b/newlib/libc/signal/sig2str.c
> > new file mode 100644
> > index 000000000..a07fa2a38
> > --- /dev/null
> > +++ b/newlib/libc/signal/sig2str.c
> > @@ -0,0 +1,156 @@
> > +/* Placeholder */
> Why placeholder? Seems like an odd comment.
I need to include a license / header block here...I think I should use our most
current RTEMS block, but I wanted to check to make sure!
> > +//#define __GNU_VISIBLE // defining it to have access to SIG2STR_MAX
> > +#include <signal.h>
> > +#include <string.h>
> > +#include <stdio.h>
> > +typedef struct sig_name_and_num {
> > + const char *sig_name;
> > + const int sig_num;
> > +} sig_name_and_num;
> > +static sig_name_and_num sig_array[] = {
> This is also const.
Got it, thanks!
> > + #ifdef EXIT
> > + { "EXIT", 0 },
> > + #endif
> I don't think this should be included. And I don't know where you saw it.
It was in the Solaris implementation...I'll take it out!
> > + #ifdef SIGHUP
> > + { "HUP", SIGHUP},
> > + #endif
> Indent the middle line (include the ifdef)
> > + #ifdef SIGINT
> > + { "INT", SIGINT },
> > + #endif
> > + #ifdef SIGQUIT
> > + { "QUIT", SIGQUIT },
> > + #endif
> > + #ifdef SIGILL
> > + { "ILL", SIGILL },
> > + #endif
> > + #ifdef SIGTRAP
> > + { "TRAP", SIGTRAP },
> > + #endif
> > + #ifdef SIGABRT
> > + { "ABRT", SIGABRT },
> > + #endif
> > + #ifdef SIGIOT
> > + { "IOT", SIGIOT},
> > + #endif
> > + #ifdef SIGEMT
> > + { "EMT", SIGEMT },
> > + #endif
> > + #ifdef SIGFPE
> > + { "FPE", SIGFPE },
> > + #endif
> > + #ifdef SIGKILL
> > + { "KILL", SIGKILL },
> > + #endif
> > + #ifdef SIGBUS
> > + { "BUS", SIGBUS },
> > + #endif
> > + #ifdef SIGSEGV
> > + { "SEGV", SIGSEGV },
> > + #endif
> > + #ifdef SIGSYS
> > + { "SYS", SIGSYS },
> > + #endif
> > + #ifdef SIGPIPE
> > + { "PIPE", SIGPIPE },
> > + #endif
> > + #ifdef SIGALRM
> > + { "ALRM", SIGALRM },
> > + #endif
> > + #ifdef SIGTERM
> > + { "TERM", SIGTERM },
> > + #endif
> > + #ifdef SIGURG
> > + { "URG", SIGURG },
> > + #endif
> > + #ifdef SIGSTOP
> > + { "STOP", SIGSTOP },
> > + #endif
> > + #ifdef SIGTSTP
> > + { "TSTP", SIGTSTP },
> > + #endif
> > + #ifdef SIGCONT
> > + { "CONT", SIGCONT },
> > + #endif
> > + #ifdef SIGCHLD
> > + { "CHLD", SIGCHLD },
> > + #endif
> > + #ifdef SIGCLD
> > + { "CLD", SIGCLD },
> > + #endif
> > + #ifdef SIGTTIN
> > + { "TTIN", SIGTTIN },
> > + #endif
> > + #ifdef SIGTTOU
> > + { "TTOU", SIGTTOU },
> > + #endif
> > + #ifdef SIGIO
> > + { "IO", SIGIO },
> > + #endif
> > + #ifdef SIGPOLL
> > + { "POLL", SIGPOLL },
> > + #endif
> > + #ifdef SIGWINCH
> > + { "WINCH", SIGWINCH },
> > + #endif
> > + #ifdef SIGUSR1
> > + { "USR1", SIGUSR1 },
> > + #endif
> > + #ifdef SIGUSR2
> > + { "USR2", SIGUSR2 },
> > + #endif
> > + // #ifdef SIGRTMIN
> > + // { "RTMIN", SIGRTMIN },
> > + // #endif
> > + // #ifdef SIGRTMAX
> > + // { "RTMAX", SIGRTMAX },
> > + // #endif
> > + #ifdef SIGPWR
> > + { "PWR", SIGPWR },
> > + #endif
> > + #ifdef SIGXCPU
> > + { "XCPU", SIGXCPU },
> > + #endif
> > + #ifdef SIGXFSZ
> > + { "XFSZ", SIGXFSZ },
> > + #endif
> > + #ifdef SIGVTALRM
> > + { "VTALRM", SIGVTALRM },
> > + #endif
> > + #ifdef SIGPROF
> > + { "PROF", SIGPROF },
> > + #endif
> > + #ifdef SIGLOST
> > + { "LOST", SIGLOST }
> > + #endif
> Is this the entire set used across all newlib signal.h files?
I've double checked and to my knowledge it has each one from signal.h
and sys/signal.h.
It does not contain __SIGFIRSTNOTRT and __SIGLASTNOTRT. I hesitated to include
those two because in sys/signal.h they were in an #ifdef and mapped to
the values of HUP
and SIGUSR2 respectively. I thought it would not make sense (in the
way I understood it)
to have them in that way, not knowing what would be defined.
Thinking about it, if they should be included, I could keep the former
as HUP, and define the
latter as (SIGRTMIN - 1), correct?
> > +#define NUM_OF_SIGS (sizeof(sig_array) / sizeof(sig_name_and_num))
> > +int
> > +sig2str(int signum, char *str)
> > + for (sig_name_and_num *i = sig_array; i < &sig_array[NUM_OF_SIGS]; i++){
> Declare the variable at the top of the function. I am not sure newlib
> has gone to assuming
> a new enough version of C for this to work on all target
> configurations. This is also in the
> other method.
Understood, thanks!
> > + if (i->sig_num == signum){
> needs a space. This occurs multiple times.
I'm sorry, I don't understand this one...do you mean the brackets? They
seem aligned in my file...or maybe I cleaned them up in the second patch?
> > + strcpy(str, i->sig_name);
> > + return 0;
> > + sprintf(str, "Unknown signal %d", signum);
> > + return -1;
> > +int
> > +str2sig(const char *__restrict str, int *__restrict pnum)
> Dec
Ok, thank you.
> > + if (strcmp(i->sig_name, str) == 0){
> > + *pnum = i->sig_num;
> > + return 0;
> > + return -1;
> > 2.31.1
> > devel mailing list
> > devel at rtems.org
