[PATCH 1/2] libc: Added implementations for sig2str/str2sig
Joel Sherrill
joel.sherrill at gmail.com
Fri Jul 16 21:38:36 UTC 2021
On Wed, Jul 7, 2021 at 5:46 AM Matt Joyce <mfjoyce2004 at gmail.com> wrote:
> Added function implementations for sig2str() and str2sig() in libc/signal in order
> to improve POSIX compliance.
> newlib/libc/signal/sig2str.c | 156 +++++++++++++++++++++++++++++++++++
> 1 file changed, 156 insertions(+)
> create mode 100644 newlib/libc/signal/sig2str.c
> diff --git a/newlib/libc/signal/sig2str.c b/newlib/libc/signal/sig2str.c
> new file mode 100644
> index 000000000..a07fa2a38
> --- /dev/null
> +++ b/newlib/libc/signal/sig2str.c
> @@ -0,0 +1,156 @@
> +/* Placeholder */
This must be fixed.
> +//#define __GNU_VISIBLE // defining it to have access to SIG2STR_MAX
> +#include <signal.h>
> +#include <string.h>
> +#include <stdio.h>
> +typedef struct sig_name_and_num {
> + const char *sig_name;
> + const int sig_num;
> +} sig_name_and_num;
> +static sig_name_and_num sig_array[] = {
> + #ifdef EXIT
> + { "EXIT", 0 },
> + #endif
The {} part needs indenting
> + #ifdef SIGHUP
> + { "HUP", SIGHUP},
> + #endif
> + #ifdef SIGINT
> + { "INT", SIGINT },
> + #endif
> + #ifdef SIGQUIT
> + { "QUIT", SIGQUIT },
> + #endif
> + #ifdef SIGILL
> + { "ILL", SIGILL },
> + #endif
> + #ifdef SIGTRAP
> + { "TRAP", SIGTRAP },
> + #endif
> + #ifdef SIGABRT
> + { "ABRT", SIGABRT },
> + #endif
> + #ifdef SIGIOT
> + { "IOT", SIGIOT},
> + #endif
> + #ifdef SIGEMT
> + { "EMT", SIGEMT },
> + #endif
> + #ifdef SIGFPE
> + { "FPE", SIGFPE },
> + #endif
> + #ifdef SIGKILL
> + { "KILL", SIGKILL },
> + #endif
> + #ifdef SIGBUS
> + { "BUS", SIGBUS },
> + #endif
> + #ifdef SIGSEGV
> + { "SEGV", SIGSEGV },
> + #endif
> + #ifdef SIGSYS
> + { "SYS", SIGSYS },
> + #endif
> + #ifdef SIGPIPE
> + { "PIPE", SIGPIPE },
> + #endif
> + #ifdef SIGALRM
> + { "ALRM", SIGALRM },
> + #endif
> + #ifdef SIGTERM
> + { "TERM", SIGTERM },
> + #endif
> + #ifdef SIGURG
> + { "URG", SIGURG },
> + #endif
> + #ifdef SIGSTOP
> + { "STOP", SIGSTOP },
> + #endif
> + #ifdef SIGTSTP
> + { "TSTP", SIGTSTP },
> + #endif
> + #ifdef SIGCONT
> + { "CONT", SIGCONT },
> + #endif
> + #ifdef SIGCHLD
> + { "CHLD", SIGCHLD },
> + #endif
> + #ifdef SIGCLD
> + { "CLD", SIGCLD },
> + #endif
> + #ifdef SIGTTIN
> + { "TTIN", SIGTTIN },
> + #endif
> + #ifdef SIGTTOU
> + { "TTOU", SIGTTOU },
> + #endif
> + #ifdef SIGIO
> + { "IO", SIGIO },
> + #endif
> + #ifdef SIGPOLL
> + { "POLL", SIGPOLL },
> + #endif
> + #ifdef SIGWINCH
> + { "WINCH", SIGWINCH },
> + #endif
> + #ifdef SIGUSR1
> + { "USR1", SIGUSR1 },
> + #endif
> + #ifdef SIGUSR2
> + { "USR2", SIGUSR2 },
> + #endif
> + // #ifdef SIGRTMIN
> + // { "RTMIN", SIGRTMIN },
> + // #endif
> + // #ifdef SIGRTMAX
> + // { "RTMAX", SIGRTMAX },
> + // #endif
> + #ifdef SIGPWR
> + { "PWR", SIGPWR },
> + #endif
> + #ifdef SIGXCPU
> + { "XCPU", SIGXCPU },
> + #endif
> + #ifdef SIGXFSZ
> + { "XFSZ", SIGXFSZ },
> + #endif
> + #ifdef SIGVTALRM
> + { "VTALRM", SIGVTALRM },
> + #endif
> + #ifdef SIGPROF
> + { "PROF", SIGPROF },
> + #endif
> + #ifdef SIGLOST
> + { "LOST", SIGLOST }
> + #endif
> +#define NUM_OF_SIGS (sizeof(sig_array) / sizeof(sig_name_and_num))
> +int
> +sig2str(int signum, char *str)
> + for (sig_name_and_num *i = sig_array; i < &sig_array[NUM_OF_SIGS]; i++){
> + if (i->sig_num == signum){
Space between the ) and the {
> + strcpy(str, i->sig_name);
> + return 0;
> + sprintf(str, "Unknown signal %d", signum);
> + return -1;
> +int
> +str2sig(const char *__restrict str, int *__restrict pnum)
> + if (strcmp(i->sig_name, str) == 0){
Two more ){ needing a space.
> + *pnum = i->sig_num;
> + return 0;
> + return -1;
> 2.31.1
> devel mailing list
> devel at rtems.org
