[PATCH v2] rtems:modify spthread01 testsuites for cond variable signal and broadcast intf rtems:making rectification according to Sebastian Huber's opinions
tianye at sugon.com
tianye at sugon.com
Thu Jul 8 05:49:55 UTC 2021
testsuites/sptests/spthread01/init.c | 86 +++++++++++++++++++++++++++++++-----
1 file changed, 74 insertions(+), 12 deletions(-)
diff --git a/testsuites/sptests/spthread01/init.c b/testsuites/sptests/spthread01/init.c
index 9044ca2..b64d0a5 100644
--- a/testsuites/sptests/spthread01/init.c
+++ b/testsuites/sptests/spthread01/init.c
@@ -165,6 +165,7 @@ static void test_recursive_mutex(void)
typedef struct {
rtems_mutex mtx;
rtems_condition_variable cnd;
+ unsigned int exeting_task_cnt;
} signal_context;
static void signal_task(rtems_task_argument arg)
@@ -173,8 +174,10 @@ static void signal_task(rtems_task_argument arg)
s = (signal_context *) arg;
rtems_mutex_lock(&s->mtx);
- rtems_condition_variable_signal(&s->cnd);
+ rtems_condition_variable_wait(&s->cnd, &s->mtx);
rtems_mutex_unlock(&s->mtx);
+ s->exeting_task_cnt++;
+ rtems_task_exit();
static void test_condition_variable(void)
@@ -183,7 +186,9 @@ static void test_condition_variable(void)
signal_context s;
const char *name;
rtems_status_code sc;
- rtems_id id;
+ rtems_id id1;
+ rtems_id id2;
+ rtems_task_priority task_priority;
name = rtems_condition_variable_get_name(&a);
rtems_test_assert(strcmp(name, "a") == 0);
@@ -201,34 +206,91 @@ static void test_condition_variable(void)
name = rtems_condition_variable_get_name(&s.cnd);
rtems_test_assert(strcmp(name, "c") == 0);
- rtems_condition_variable_signal(&s.cnd);
+ s.exeting_task_cnt = 0;
+ sc = rtems_task_create(
+ rtems_build_name('C', 'O', 'D', '1'),
+ 2,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &id1
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ sc = rtems_task_start(id1, signal_task, (rtems_task_argument) &s);
+ rtems_build_name('C', 'O', 'D', '2'),
+ 2,
+ &id2
+ sc = rtems_task_start(id2, signal_task, (rtems_task_argument) &s);
- rtems_condition_variable_broadcast(&s.cnd);
+ sc = rtems_task_set_priority(rtems_task_self(), RTEMS_MAXIMUM_PRIORITY - 1, &task_priority);
+ sc = rtems_task_wake_after(0);
rtems_mutex_lock(&s.mtx);
+ rtems_condition_variable_signal(&s.cnd);
+ rtems_mutex_unlock(&s.mtx);
+ rtems_test_assert(s.exeting_task_cnt == 1);
+ sc = rtems_task_delete(id1);
+ sc = rtems_task_delete(id2);
+ rtems_condition_variable_destroy(&s.cnd);
+ rtems_mutex_destroy(&s.mtx);
+ sc = rtems_task_set_priority(rtems_task_self(), task_priority, &task_priority);
- rtems_build_name('C', 'O', 'N', 'D'),
2,
- &id
+ &id1
- sc = rtems_task_start(id, signal_task, (rtems_task_argument) &s);
+ 2,
+ &id2
- rtems_condition_variable_wait(&s.cnd, &s.mtx);
- sc = rtems_task_delete(id);
+ rtems_mutex_lock(&s.mtx);
+ rtems_condition_variable_broadcast(&s.cnd);
+ rtems_test_assert(s.exeting_task_cnt == 2);
static void test_counting_semaphore(void)
@@ -319,7 +381,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
-#define CONFIGURE_MAXIMUM_TASKS 2
+#define CONFIGURE_MAXIMUM_TASKS 3
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
1.8.3.1
