[PATCH rtems-libbsd 3/3] rtemsbsd: Present all ZynqMP interfaces by default
Kinsey Moore kinsey.moore at oarcorp.com
Fri Jul 9 01:14:18 UTC 2021
Now that the issue with false PHY detection on unterminated MII busses
has been resolved, present all hardware interfaces for use on ZynqMP.
 rtemsbsd/include/bsp/nexus-devices.h                 | 9 ---------
 testsuite/include/rtems/bsd/test/network-config.h.in | 8 --------
 waf_libbsd.py                                        | 4 +---
 3 files changed, 1 insertion(+), 20 deletions(-)
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index cbb3f48b..9486083b 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -38,7 +38,6 @@
 #include <rtems/bsd/bsd.h>
 #include <rtems/bsd/modules.h>
-#include <rtems/bsd/test/network-config.h>
 #include <machine/rtems-bsd-nexus-bus.h>
@@ -116,18 +115,10 @@ RTEMS_BSD_DRIVER_XILINX_ZYNQMP_SLCR;
  * CGEM3 is used for LibBSD because all Zynq Ultrascale+ MPSoC dev boards treat
  * the highest-mapped CGEM as the primary interface.
-#if NET_CFG_ZYNQMP_USE_CGEM0 == '1'
 RTEMS_BSD_DRIVER_XILINX_ZYNQMP_CGEM0(ZYNQMP_IRQ_ETHERNET_0);
-#endif
-#if NET_CFG_ZYNQMP_USE_CGEM1 == '1'
 RTEMS_BSD_DRIVER_XILINX_ZYNQMP_CGEM1(ZYNQMP_IRQ_ETHERNET_1);
-#endif
-#if NET_CFG_ZYNQMP_USE_CGEM2 == '1'
 RTEMS_BSD_DRIVER_XILINX_ZYNQMP_CGEM2(ZYNQMP_IRQ_ETHERNET_2);
-#endif
-#if NET_CFG_ZYNQMP_USE_CGEM3 == '1'
 RTEMS_BSD_DRIVER_XILINX_ZYNQMP_CGEM3(ZYNQMP_IRQ_ETHERNET_3);
-#endif
 RTEMS_BSD_DRIVER_E1000PHY;
 RTEMS_BSD_DRIVER_UKPHY;
diff --git a/testsuite/include/rtems/bsd/test/network-config.h.in b/testsuite/include/rtems/bsd/test/network-config.h.in
index da316e15..39bb5388 100755
--- a/testsuite/include/rtems/bsd/test/network-config.h.in
+++ b/testsuite/include/rtems/bsd/test/network-config.h.in
@@ -64,12 +64,4 @@
 #define NET_CFG_GATEWAY_IP "@NET_CFG_GATEWAY_IP@"
-#define NET_CFG_ZYNQMP_USE_CGEM0 '@NET_CFG_ZYNQMP_USE_CGEM0@'
-#define NET_CFG_ZYNQMP_USE_CGEM1 '@NET_CFG_ZYNQMP_USE_CGEM1@'
-#define NET_CFG_ZYNQMP_USE_CGEM2 '@NET_CFG_ZYNQMP_USE_CGEM2@'
-#define NET_CFG_ZYNQMP_USE_CGEM3 '@NET_CFG_ZYNQMP_USE_CGEM3@'
 #endif /* _RTEMS_BSD_TEST_NETWORK_CONFIG_H_ */
diff --git a/waf_libbsd.py b/waf_libbsd.py
index bb4182e3..e7222a03 100644
--- a/waf_libbsd.py
+++ b/waf_libbsd.py
@@ -289,9 +289,7 @@ class Builder(builder.ModuleManager):
                       (bld.env.NET_CONFIG))
         tags = [
             'NET_CFG_INTERFACE_0', 'NET_CFG_SELF_IP', 'NET_CFG_NETMASK',
-            'NET_CFG_PEER_IP', 'NET_CFG_GATEWAY_IP',
-            'NET_CFG_ZYNQMP_USE_CGEM0', 'NET_CFG_ZYNQMP_USE_CGEM1',
-            'NET_CFG_ZYNQMP_USE_CGEM2', 'NET_CFG_ZYNQMP_USE_CGEM3'
+            'NET_CFG_PEER_IP', 'NET_CFG_GATEWAY_IP'
         try:
             net_cfg_lines = open(bld.env.NET_CONFIG).readlines()
2.20.1
