[PATCH rtems-libbsd 1/3] dev/mii: Handle PHY read timeouts
Fri Jul 9 05:28:32 UTC 2021
On 09/07/2021 03:14, Kinsey Moore wrote:
> PHY read timeouts return 0xffffffff and bypass the current bad/no PHY
> checks. This adds a check specifically for that read timeout to avoid
> probing PHYs that don't exist.
>   freebsd/sys/dev/mii/mii.c | 1 +
>   1 file changed, 1 insertion(+)
> diff --git a/freebsd/sys/dev/mii/mii.c b/freebsd/sys/dev/mii/mii.c
> index d0428f24..8f087cab 100644
> --- a/freebsd/sys/dev/mii/mii.c
> +++ b/freebsd/sys/dev/mii/mii.c
> @@ -474,6 +474,7 @@ mii_attach(device_t dev, device_t *miibus, if_t ifp,
>   		bmsr = MIIBUS_READREG(dev, ma.mii_phyno, MII_BMSR);
>   		if (bmsr == 0 || bmsr == 0xffff ||
> +		    bmsr == 0xffffffff ||
Could you please fix the driver so that it returns 0 or 0xffff in case
of timeouts? This is the general MII module of FreeBSD. If you think
there is a bug in this code, then please report it to FreeBSD first.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
